    Save default installation settings for next install?
    2 Posts 2 Posters 922 Views
    • colonellockeC
      colonellocke
      Just a random thought/feature suggestion: How about saving all the default install settings so the each update can pretty much be installed hands-free.
      I mean, sure, you could set it so that if the install options change, then the user would have to interact, otherwise, just hit install and let it roll.
        Claudia Frank @colonellocke
        @colonellocke
        I assume you get a better chance having this done by following this FAQ.
