    Style Configurator: Background color for matching words
    2 Posts 2 Posters 1.4k Views
    • Ronald FischerR
      Ronald Fischer
      If I double click on a word, this word is highlighted with a certain background colour, and if the same word exists in other places, they are highlighted too, though with a different background colour. Note that these colours are NOT the same as the one which is used when I highlight text with click+drag with the mouse. With other words: Selecting a word by double-clicking it, yields a different background colour than click-dragging the mouse over the word.
      My question is: Can I somewhere change the colours of these backgrounds? I first thought it is the entry “Tags match highlight” in the Style Configurator, but obviously this isn’t the right one.
      • Scott SumnerS
        Scott Sumner @Ronald Fischer
        @Ronald-Fischer
        I think the “differences” you are seeing are when the two backgrounds are in effect together–could this be right? For example if you double-click a word (or click+drag select an entire word), you get the “selection” background color as well as the Smart Highlighing color…at the same time. This looks like a third color, but it really isn’t. Of course, maybe I’m misunderstanding…
        But the general answer…to this question… :
        …is:
        See Settings (menu) -> Style Configurator… -> Global Styles and then:
        • Selected text colour
        and
        • Smart Highlighting
        …adjust each one’s Background colour to your liking…
