    Problem with syntax highlighting when restoring sessions for SessionMgr.dll plugin
    2 Posts 1 Posters 907 Views
    • Fade To-GrayF
      Fade To-Gray
      I recently had to perform a clean windows install on a new drive due to warnings of impending drive failure on my 8 year old machine.
      I’ve got np++ back-up-and-running with my can’t-do-without SessionMgr.dll, but the sessions I’ve restored that were originally created with it won’t automatically apply the syntax highlighting for the user defined language that I use.
      I had created several sessions, each with many AutoHotkey scripts open but when opening the sessions they’re all in plain text.
      The udl works fine when opening a script from the file menu or opening with np++ from explorer’s r/c menu, but I need to manually select it from the Language menu for every file opened with each session.
      Can anyone suggest how I can avoid having to manually re apply the udl for dozens of scripts?
      Thank you.
      • Fade To-GrayF
        Fade To-Gray
        My bad - I failed to copy over the global.xml file :-/
