    Replace In Files not working for me using Extended Mode
    2 Posts 1 Posters 938 Views
    • Dan EdwardsD
      Dan Edwards
      I am trying to replace a given line of text in many files with two lines of text
      e.g. replace
      #include “folder\somefile.h”;
      with
      #include “folder\otherfile.h”;
      If I use extended mode it will find all occurrences just fine looking for
      #include “folder\\somefile.h”;
      But when I try to perform the Replace In Files action using this for the replace with
      #include “folder\\somefile.h”;\n#include “folder\\otherfile.h”;
      It fails just ends up doing nothing with
      Replace in Files: 0 occurrences were replaced.
      • Dan EdwardsD
        Dan Edwards
        Turns out that this was because the files were read-only. I was counting on the Perforce Plugin to automatically check them out but I guess that is not going to work. I will have to manually checkout everything and then perform the replacement.
