    Monitor function seems a bit bugged
    2 Posts 1 Posters 801 Views
    • NexusTheBronyN
      NexusTheBrony
      The monitor function seems a bit bugged. It does monitor the file and update as the file changes, but only just after it is brought into focus. If there is even a second between the last monitor update and the current time, it stops updating and will not update until I bring N++ back into focus. Normally this wouldn’t be a problem for me, but since I primarily use N++ as a log watcher, even a single missed line could cause me to not know when an error occurred, and therefore unable to correlate it easily to what caused the error
      • NexusTheBronyN
        NexusTheBrony
        I just found a plugin that I assume enhances the Monitor function to always update every 3 seconds. Hope this fixes it (if this plugin works that does not mean the issue is resolved)
