    help with Oxygen Basic syntax definition
    1 Posts 1 Posters 612 Views
    • Eduardo JorgeE
      Eduardo Jorge
      Hello
      I started using notepad ++ yesterday
      I am trying to configure for Oxygen Basic (O2H) syntax
      the problem is that it has a lot of polymorphism
      accepting C, Basic syntax and assembler
      I want to have a different formatting, for things not to confuse too much
      so I would like to know if it has a different formatting for the folds
      I am also having problems separating formatting and certain keywords and functions with the same name
      example
      dim ss as string
      ss = string(6, “f”)
      can differentiate words with “(”?
      thank you
