    When case insensitive sorting will be added in Notepad++ x64 (without TextFX)?
    insensitivesort
    9 Posts 3 Posters 6.4k Views
    • PiotrMP006P
      PiotrMP006
      insensitive sorting vs sensitive sorting
      A A
      a B
      B C
      b a
      C b
      c c
      • Gogo NeatzaG
        Gogo Neatza
        Before posting have you tested the ‘Column sorting’ plugin ?
          Hello, @piotr-Przeklasa and All,
          I’ve deeply thought about your problem, since a week and, finally, I found out a work-round to change the default behaviour of the N++ sort ;-)
          While elaborating my solution, I read some documentation about sorting and ,to my mind, it’s quite difficult to chose which sorting method is the best one, as it mainly depends on the kind of data, that you have to sort ! So, I tried to find a “middle” solution, which, sometimes, should be modified for a specific sorting way.
          Referring to the links, below, it appears, to everyone, that sorting things are quite complex if you consider all countries, using Latin languages, and, even if you restrict your goal to American-English language, several sorting methods are still possible !
          https://en.wikipedia.org/wiki/Alphabetical_order
          https://en.wikipedia.org/wiki/List_of_precomposed_Latin_characters_in_Unicode
          For instance, here is a list of some streets of the Great London area :
          NON sorted :                             NOTEPAD++ Sort :                            Sort B :
          Oakworth                                 Oak Avenue                                  Oak Avenue
          Oak Ridge                                Oak Bank Croy                               Oak Bank Croy
          Oak Hill Way                             Oak Gardens                                 Oakcroft Road
          Oakwood                                  Oak Hill                                    Oak Gardens
          Oak Hill                                 Oak Hill Close                              Oak Hill
          Oak Bank Croy                            Oak Hill Way                                Oak Hill Close
          Oakhill Drive                            Oak Lane                                    Oakhill Drive
          Oakley River                             Oak Loadge Avenue                           Oak Hill Way
          Oak Rise                                 Oak Ridge                                   Oaklands Avenue
          Oak Avenue                               Oak Rise                                    Oak Lane
          Oakway Close                             Oak Road                                    Oakleigh Park
          Oakcroft Road                            Oakcroft Road                               Oakley Avenue
          Oak Hill Close                           Oakhill Drive                               Oakley Park
          Oak Gardens                              Oaklands Avenue                             Oakley River
          Oak Lane                                 Oakleigh Park                               Oak Loadge Avenue
          Oakleigh Park                            Oakley Avenue                               Oak Ridge
          Oakley Avenue                            Oakley Park                                 Oak Rise
          Oak Loadge Avenue                        Oakley River                                Oak Road
          Oakley Park                              Oakway Close                                Oakway Close
          Oaklands Avenue                          Oakwood                                     Oakwood
          Oak Road                                 Oakworth                                    Oakworth
          • The unsorted list is displayed in the first column
          • The list sorted with the Notepad++ sort, according to Unicode values of characters, is in the second column
          • An alternate sort, generally used, in street indexes, where spaces are not taken in account, during the sort process, is added in the third column
          Personally, in that matter, the N++ sort seems to give better results :-)
          Now, we must discuss of all symbols, which may occur inside words. Here is a short list of some English/ American abbreviations :
          NON sorted :                             N++ Sort :                                  Sort B :
          Corp                                     C-in-C                                      CAT
          cp                                       C.E.N.T.O                                   C.E.N.T.O
          C.O.I.                                   C.O.I.                                      cert
          C-in-C                                   C.S.                                        C-in-C
          CAT                                      C.S.E.                                      c/o
          C.S.                                     CAT                                         C.O.I.
          c/o                                      Co-op                                       Co-op
          C.S.E.                                   Corp                                        Corp
          Co-op                                    c/o                                         cp
          C.E.N.T.O                                cert                                        C.S.
          cert                                     cp                                          C.S.E.
          • The N++ sorted list, in the second column, is rather difficult to read, because words with symbols appear, first !
          • This time, the alternate list, in the third column, where symbols are not taken in account, gives better results, indeed !
          Finally, we have to talk about upper/lower case letters and about Latin accentuated characters, very common in many European languages !
          For instance, here is, below, a list of the given and family names of some “celebrities”, taken from the general list, below :
          https://en.wikipedia.org/wiki/Lists_of_people_by_nationality#By_nationality
          İshak Alaton                             Abdi İpekçi                                 Abdi İpekçi
          şükrü Gülesin                            Jón Ásgeir Jóhannesson                      aleksandrs čaks
          đorđe Petrović                           León Ávalos y Vez                           antoni józef śmieszek
          Thích Quảng độ                           Nazan Öncel                                 bela Čikoš Sesija
          Nazan Öncel                              Olgierd łukaszewicz                         đorđe Petrović
          sezer öztürk                             Radoje đerić                                eduardo Úrculo
          žarko Čabarkapa                          Thích Quảng độ                              Éric millot
          saúl Canelo Álvarez                      Tróndur í gøtu                              finn øglænd
          Þóra Magnúsdóttir                        Viktorija Čmilytė                           henryk Średnicki
          aleksandrs čaks                          aleksandrs čaks                             İshak Alaton
          eduardo Úrculo                           antoni józef śmieszek                       Jón Ásgeir Jóhannesson
          Radoje đerić                             bela Čikoš Sesija                           León Ávalos y Vez
          antoni józef śmieszek                    eduardo Úrculo                              łukasz załuska
          øystein sunde                            finn øglænd                                 mạc đăng Dung
          učimir                                   henryk Średnicki                            mia Čorak Slavenska
          henryk Średnicki                         mia Čorak Slavenska                         Nazan Öncel
          Éric millot                              mạc đăng Dung                               Olgierd łukaszewicz
          Șerban Andrei                            saúl Canelo Álvarez                         Óscar Muñoz oviedo
          mia Čorak Slavenska                      sezer öztürk                                øystein sunde
          Olgierd łukaszewicz                      učimir                                      Radoje đerić
          Viktorija Čmilytė                        václav černý                                saúl Canelo Álvarez
          Jón Ásgeir Jóhannesson                   władysław ślebodziński                      Șerban Andrei
          władysław ślebodziński                   Éric millot                                 sezer öztürk
          Tróndur í gøtu                           Óscar Muñoz oviedo                          şükrü Gülesin
          václav černý                             Ümit Özat                                   Thích Quảng độ
          łukasz załuska                           Þóra Magnúsdóttir                           Tróndur í gøtu
          Óscar Muñoz oviedo                       øystein sunde                               učimir
          León Ávalos y Vez                        đorđe Petrović                              Ümit Özat
          Ümit Özat                                İshak Alaton                                václav černý
          finn øglænd                              łukasz załuska                              Viktorija Čmilytė
          mạc đăng Dung                            şükrü Gülesin                               władysław ślebodziński
          bela Čikoš Sesija                        žarko Čabarkapa                             žarko Čabarkapa
          Abdi İpekçi                              Șerban Andrei                               Þóra Magnúsdóttir
          • Again, the unsorted list is displayed in the first column
          • The N++ sorted list, in the second column, is, obviously, poorly sorted, as :
            • Words, beginning with a NON-accentuated uppercase letter, come first
            • Words, beginning with a NON-accentuated lowercase letter, come in second
            • Words, beginning with a accentuated letter, come last, according to the Unicode value of its first char.
          • The alternate list, in the third column, seems much more readable, as :
            • The case of letters is not taken in account, in first approach
            • The accentuated letters are sorted, right after their corresponding NON-accentuated letter !
          Of course, a lot of other parameters, about sorting, could be discussed and my previous discussion just shows the complexity of the sort problem ;-)) For instance, I did NOT study sorting, involving RTL languages ( such as Hebrew or Arabic languages ) and, also, Asian languages using ideographic characters !
          My word-around is based on a simple idea : to customize a sort process, I simply add a specific text, in front of any line of the text to be sorted !
          Here is my method :
          • First, with a first simple regex, I copy, with a simple regex, each line of text to be sorted, twice, separating these identical blocks with a specific character, not used, anywhere else
          • Secondly, with a second regex S/R, I modify the first part of each line, located before the separator character
          • Thirdly, I perform a classical N++ sort, using the menu option Edit > Line Operations > Sort Lines Lexicographically Ascending
          • Finally, I get rid of that temporary sorting key, as well as the separator, for each line, with a third simple regex
          In my first attempts, I used the # symbol as a separator. However, I quickly realized that this could break a correct sort. Indeed, just imagine the two consecutive lines, obtained at the end of phase 2
          alvaro uribe velez#álvaro uribe Vélez
          alvaro uribe#álvaro Uribe
          It’s obvious that, using N++ sort, then deleting part till the # char, leave you with the NON sorted text :
          álvaro uribe Vélez
          álvaro Uribe
          because the Unicode value of the # symbol ( 0023 ) is higher than the 0020 ( space char )
          Now, replacing the # separator with, for instance, the  control character ( code 001f ) implies a correct sort, because the 001F value comes before the 0020 value of the space character. Hence the two records are correctly displayed :
          álvaro Uribe
          álvaro uribe Vélez
          So, according to what I said before, in each part of line, laying before the separator, the regex, used in phase 2, will :
          • Keep the Space character as a significant character for sorting
          • Get rid of any NON-word character ( NO-significant character )
          • Change any NBSP character, of Unicode value 00A0, with a common Space char
          • Change any Latin letter, accentuated or NOT, whatever its case, by its corresponding lowercase letter
          The fourth point can be reached, with a special regex feature, called an equivalence class of characters, with the syntax [[=X=]], where X is any single word character !
          For instance :
          • The regex [[=O=]] would match any single character of the list :
          OoºÒÓÔÕÖØòóôõöøŌōŎŏŐőƟƠơƢƣǑǒǪǫǬǭǾǿȌȍȎȏɵɶɷṌṍṎṏṐṑṒṓỌọỎỏỐốỒồỔổỖỗỘộỚớỜờỞởỠỡỢợℴ⒪ⓄⓞOo
          • The regex [[=X=]][[=O=]] would match any two char. string, as ẌƟ, Ⓧṑ or xƣ
          • The regex [[=X=][=O=]] would match any single character of the list :
          OoºÒÓÔÕÖØòóôõöøŌōŎŏŐőƟƠơƢƣǑǒǪǫǬǭǾǿȌȍȎȏɵɶɷṌṍṎṏṐṑṒṓỌọỎỏỐốỒồỔổỖỗỘộỚớỜờỞởỠỡỢợℴ⒪ⓄⓞOoXxẊẋẌẍ⒳ⓍⓧXx
          • The regex [[=X=]0-9] would match any single character of the list :
          0123456789XxẊẋẌẍ⒳ⓍⓧXx
          • And the regex [[=X=]]-[0-9]-[[=O=]] would match any three char. strings as Ẋ-2-Ⓧ, Ẍ-4-⒳ or x-0-Ẋ
          Remark :
          I intend, shortly, to create an other post, with the tables of all characters, involved in the [[=X=]] feature ! Just be patient !
          So, given, for instance, the seven family and given names, below :
          đorđe Petrović
          žarko Čabarkapa
          øystein sunde
          Șerban Andrei
          Tróndur í gøtu
          łukasz załuska
          Óscar Muñoz oviedo
          We’ll obtain, at the end of phase 2, after performing the regex, containing [[=X=]] blocks :
          dorde petrovicđorđe Petrović
          zarko Cabarkapažarko Čabarkapa
          oystein sundeøystein sunde
          serban andreiȘerban Andrei
          trondur i gotuTróndur í gøtu
          lukasz zaluskałukasz załuska
          oscar munoz oviedoÓscar Muñoz oviedo
          As you can see, in the first part, before the US separator ( unfortunately not displayed ), all the Latin accentuated characters are changed into their based equivalent lowercase letter, in the [a-z] range
          Now, it’s easy to understand why, after the N++ Unicode sort, we get the well sorted text, below ;-))
          dorde petrovicđorđe Petrović                                                     đorđe Petrović
          lukasz zaluskałukasz załuska                                                     łukasz załuska
          oscar munoz oviedoÓscar Muñoz oviedo                                             Óscar Muñoz oviedo
          oystein sundeøystein sunde                    giving finally the lines  :        øystein sunde
          serban andreiȘerban Andrei                                                       Șerban Andrei
          trondur i gotuTróndur í gøtu                                                     Tróndur í gøtu
          zarko Cabarkapažarko Čabarkapa                                                   žarko Čabarkapa
          Note that if two primary keys are the same as, for instance, in :
          guy Thevenotguy THEVENOT
          guy ThevenotGuy Thevenot
          it would give, after the Unicode N++ sort :
          As letter G of Guy comes before letter g of guy !
          See next post, as any post has a maximum size of 16Ko ;-))
            So, here is my complete method :
            • Phase 1 On your list to be sorted, perform the simple regex S/R :
            SEARCH (?-s).+
            REPLACE $0\x1F$0
            • Phase 2 Now, use this ( more complicated ! ) regex S/R :
            SEARCH (?i)(?=.*\x1F)(?:([A-Z0-9]+)|([[=a=]])|([[=b=]])|([[=c=]])|([[=d=]])|([[=e=]])|([[=f=]])|([[=g=]])|([[=h=]])|([[=i=]])|([[=j=]])|([[=k=]])|([[=l=]])|([[=m=]])|([[=n=]])|([[=o=]])|([[=p=]])|([[=q=]])|([[=r=]])|([[=s=]])|([[=t=]])|([[=u=]])|([[=v=]])|([[=w=]])|([[=x=]])|([[=y=]])|([[=z=]])|(\x{00C6})|(\x{0152})|(\x{0218}|\x{0219})|(\x{021A}|\x{021B})|(\x{00A0})|[^\x1F\x20\xDE\r\n])
            REPLACE (?1\L\1)(?2a)(?3b)(?4c)(?5d)(?6e)(?7f)(?8g)(?9h)(?10i)(?11j)(?12k)(?13l)(?14m)(?15n)(?16o)(?17p)(?18q)(?19r)(?20s)(?21t)(?22u)(?23v)(?24w)(?25x)(?26y)(?27z)(?28ae)(?29oe)(?30s)(?31t)(?32\x20)
            • Phase 3 Run a classical N++ sort using the menu option Edit > Line Operations > Sort Lines Lexicographically Ascending
            • Phase 4 Perform a last regex S/R, in order to delete the primary temporary key :
            SEARCH ^.+\x1F
            REPLACE Leave EMPTY
            Notes :
            In search, until the US separator character is reached, the regex searches for :
            • Any range of consecutive word characters of group 1, ( part ([A-Z0-9]+) ), whatever its case, replaced by the same range of characters, in lower case, due to the conditional replacement (?1\L\1)
            • Then, from group 2 to group 27 ( part ([[=x=]]) ), any accentuated Latin letter x is changed into a classical lower-case letter with the conditional replacement (?##x)
            • Now, group 28, ( part (\x{00C6}) ), rewrites the Æ and æ ligatures as the two lowercase letters ae
            • And group 29, ( part (\x{0152}) ), rewrites the Œ and œ ligatures as the two lowercase letters oe
            • Now, the Romanian letters Ș and ș, of group 30 ( part (\x{0218}|\x{0219}) ), are changed into the lowercase s letter
            • And the Romanian letters Ț and ț, of grouip 31 ( part (\x{021A}|\x{021B}) ), are changed into the lowercase t letter
            Note : The Œ ligature and the Romanian letters Ș and Ț are not handled by the [[=X=]] feature !
            • Then the group32 ( the NBSP character = (\x{00A0}) ) is rewritten as a single Space character
            • Finally, the regex [^\x1F\x20\xDE\r\n] matches any signle character, different from :
              • All the characters previously matched
              • The US control character separator
              • The SPACE character
              • The lower and upper case THORN letters, which are unchanged by this S/R
              • Of course, the line-break characters, too
              which are simply deleted because not stored in any existing group !
            P.S. :
            By the way, this method may be used when you want to sort a text, either :
            • From a specific colum c
            • On specific blocks of text, from columns c1 to c2, c3 to c4, and so on…
            For instance, assuming that you would like to sort a list, with :
            • A primary key, from colums 20 to 22
            • A secondary key, from colums 8 to 12
            • A third key, using all text starting at column 30
            Just build a regex which :
            • Copy the 3 characters, in columns 20 ,21 and 22, at beginning of each line
            • Then, adds the 5 characters, present between columns 8 to 12 of each line
            • Then, adds the remaining text, of each line, starting with column 30
            • And, finally, adds the US control character as a separator, followed with each initial line, in order to create a pseudo fourth key ( the entire contents of each line ) in the case that the first three keys would be identical, in several lines !
            That is to say, the following regex :
            SEARCH (?-s)^.{7}(.....).......(...).......(.*)
            REPLACE \2\1\3\x1F$0
                  Hello, All,
                  As promised, in my previous post, here are below some tables, summarizing all the Latin word characters which are matched with the regex syntax [[=X=]], where X is any single character of the second column of each table, which is NOT surrounded with square brackets !
                  For instance, the table, regarding the Latin letter M, with :
                  • The Unicode value of a similar M character in the first column
                  • The character, itself, in the second column
                  is the following :
                  | Code | Char. |
                  | 004D |   M   |
                  | 006D |   m   |
                  | 019C |   Ɯ   |
                  | 026F | [ ɯ ] |
                  | 0270 | [ ɰ ] |
                  | 0271 | [ ɱ ] |
                  | 1E3E |   Ḿ   |
                  | 1E3F |   ḿ   |
                  | 1E40 |   Ṁ   |
                  | 1E41 | [ ṁ ] |
                  | 1E42 | [ Ṃ ] |
                  | 1E43 | [ ṃ ] |
                  | 2133 |   ℳ   |
                  | 24A8 |   ⒨   |
                  | 24C2 |   Ⓜ   |
                  | 24DC |   ⓜ   |
                  | FF2D |   M   |
                  | FF4D |   m   |
                  This means that the regex [[=M=]] matches any single character of the list :
                  [MmƜɯɰɱḾḿṀṁṂṃℳ⒨ⓂⓜMm]
                  Notes :
                  • Any similar M character of that list, that is NOT between square brackets ( IMPORTANT ), may be inserted in the regex syntax [[==]] ! For instance the regex [[=Ɯ=]] or the regex [[=M=]] would also match any char of the list above !!
                  • Any character, between square brackets, in the table above, gives wrong results when used inside an equivalence class ( [[==]] ) Can’t explain exactly why, anyway !
                  • Probably, depending of your current font, some characters of the tables, below, may be replaced by a question mark ( ? ), a small square box ( □ ) or a black square box ( ■ ) because your current font cannot display the glyph of these characters !
                  • You may download, just for test, a suitable font, as Fixedsys Excelsior 2.00, which correctly displays all these characters, from the link :
                  http://www.fixedsysexcelsior.com/fonts/FSEX2.ttf
                  No need to install that font, on your system ! Simply :
                  • Double-click on that .ttf file to open it
                  • Close and re-open Notepad++
                  • Select the default style ( Settings > Style Configurator… Global Styles > Default Style )
                  • Choose the Fixedsys Excelsior 2.00 font, in the drop-down list, in the Font style zone
                  • Click on the Save & Close button
                  So, here are, below, the different tables of characters, matched by an equivalence class ( [[=X=]] )
                  Notes :
                  • Due to a maximum size of 16Ko for a post, these tables must be split over several posts !
                  • The vertical lines, will not be, exactly, aligned because of the specific width of some characters :-(
                  • Last info :
                  When using the SciLexer.dll library of François-R Boyer, with N++ version v6.9.0, containing many improvements of the regex engine, with search processed in true 32 bit code-points ( instead of UTF-16 ), even the Latin characters, between square brackets give correct results !
                  Again, it’s really a pity that this improved regex engine can’t be implemented and updated with recent versions of N++ :-((( So many regex issues would disappear !
                              Different characters X found, when using an EQUIVALENCE CLASS [[=X=]] :
                  | Code | Char. |      | Code | Char. |      | Code | Char. |      | Code | Char. |      | Code | Char. |
                  | 0041 |   A   |      | 0042 |   B   |      | 0043 |   C   |      | 0044 |   D   |      | 0045 |   E   |
                  | 0061 |   a   |      | 0062 |   b   |      | 0063 |   c   |      | 0064 |   d   |      | 0065 |   e   |
                  | 00AA |   ª   |      | 0180 |   ƀ   |      | 00C7 |   Ç   |      | 00D0 |   Ð   |      | 00C8 |   È   |
                  | 00C0 |   À   |      | 0181 |   Ɓ   |      | 00E7 |   ç   |      | 00F0 |   ð   |      | 00C9 |   É   |
                  | 00C1 |   Á   |      | 0182 |   Ƃ   |      | 0106 |   Ć   |      | 010E |   Ď   |      | 00CA |   Ê   |
                  | 00C2 |   Â   |      | 0183 |   ƃ   |      | 0107 |   ć   |      | 010F |   ď   |      | 00CB |   Ë   |
                  | 00C3 |   Ã   |      | 0184 |   Ƅ   |      | 0108 |   Ĉ   |      | 0110 |   Đ   |      | 00E8 |   è   |
                  | 00C4 |   Ä   |      | 0185 |   ƅ   |      | 0109 |   ĉ   |      | 0111 |   đ   |      | 00E9 |   é   |
                  | 00C5 |   Å   |      | 0253 | [ ɓ ] |      | 010A |   Ċ   |      | 018A |   Ɗ   |      | 00EA |   ê   |
                  | 00E0 |   à   |      | 0299 |   ʙ   |      | 010B |   ċ   |      | 018B |   Ƌ   |      | 00EB |   ë   |
                  | 00E1 |   á   |      | 1E02 |   Ḃ   |      | 010C |   Č   |      | 018C |   ƌ   |      | 0112 |   Ē   |
                  | 00E2 |   â   |      | 1E03 |   ḃ   |      | 010D |   č   |      | 018D |   ƍ   |      | 0113 |   ē   |
                  | 00E3 |   ã   |      | 1E04 |   Ḅ   |      | 0186 |   Ɔ   |      | 0256 | [ ɖ ] |      | 0114 |   Ĕ   |
                  | 00E4 |   ä   |      | 1E05 |   ḅ   |      | 0187 |   Ƈ   |      | 0257 | [ ɗ ] |      | 0115 |   ĕ   |
                  | 00E5 |   å   |      | 1E06 |   Ḇ   |      | 0188 |   ƈ   |      | 02A4 |   ʤ   |      | 0116 |   Ė   |
                  | 0100 |   Ā   |      | 1E07 |   ḇ   |      | 0254 | [ ɔ ] |      | 1E0A |   Ḋ   |      | 0117 |   ė   |
                  | 0101 |   ā   |      | 212C |   ℬ   |      | 0255 | [ ɕ ] |      | 1E0B |   ḋ   |      | 0118 |   Ę   |
                  | 0102 |   Ă   |      | 249D |   ⒝   |      | 0297 |   ʗ   |      | 1E0C |   Ḍ   |      | 0119 |   ę   |
                  | 0103 |   ă   |      | 24B7 |   Ⓑ   |      | 1E08 |   Ḉ   |      | 1E0D |   ḍ   |      | 011A |   Ě   |
                  | 0104 |   Ą   |      | 24D1 |   ⓑ   |      | 1E09 |   ḉ   |      | 1E0E |   Ḏ   |      | 011B |   ě   |
                  | 0105 |   ą   |      | FF22 |   B   |      | 2102 |   ℂ   |     | 1E0F |   ḏ   |      | 018E |   Ǝ   |
                  | 01CD |   Ǎ   |      | FF42 |   b   |      | 2103 |   ℃   |     | 1E10 |   Ḑ   |      | 018F |   Ə   |
                  | 01CE |   ǎ   |      •------•-------•      | 212D |   ℭ   |      | 1E11 |   ḑ   |      | 0190 |   Ɛ   |
                  | 01DE |   Ǟ   |                            | 249E |   ⒞   |      | 1E12 |   Ḓ   |      | 01DD |   ǝ   |
                  | 01DF |   ǟ   |                            | 24B8 |   Ⓒ   |      | 1E13 |   ḓ   |      | 0204 |   Ȅ   |
                  | 01E0 |   Ǡ   |                            | 24D2 |   ⓒ   |      | 249F |   ⒟   |      | 0205 |   ȅ   |
                  | 01E1 |   ǡ   |                            | FF23 |   C   |      | 24B9 |   Ⓓ   |     | 0206 |   Ȇ   |
                  | 01FA |   Ǻ   |                            | FF43 |   c   |      | 24D3 |   ⓓ   |     | 0207 |   ȇ   |
                  | 01FB |   ǻ   |                            •------•-------•      | FF24 |   D   |      | 0258 | [ ɘ ] |
                  | 0200 |   Ȁ   |                                                  | FF44 |   d   |      | 0259 | [ ə ] |
                  | 0201 |   ȁ   |                                                  •------•-------•      | 025A | [ ɚ ] |
                  | 0202 |   Ȃ   |        | 025B |   ɛ   |
                  | 0203 |   ȃ   |        | 025C |   ɜ   |
                  | 0250 | [ ɐ ] |        | 025D |   ɝ   |
                  | 0251 | [ ɑ ] |      •------•-------•      •------•-------•      •------•-------•      | 025E |   ɞ   |
                  | 0252 | [ ɒ ] |      | Code | Char. |      | Code | Char. |      | Code | Char. |      | 0283 |   ʃ   |
                  | 1E00 |   Ḁ   |      •------•-------•      •------•-------•      •------•-------•      | 0285 |   ʅ   |
                  | 1E01 |   ḁ   |      | 0046 |   F   |      | 0047 |   G   |      | 0048 |   H   |      | 0286 |   ʆ   |
                  | 1E9A |   ẚ   |      | 0066 |   f   |      | 0067 |   g   |      | 0068 |   h   |      | 029A |   ʚ   |
                  | 1EA0 |   Ạ   |      | 0191 |   Ƒ   |      | 011C |   Ĝ   |      | 0124 |   Ĥ   |      | 1E14 |   Ḕ   |
                  | 1EA1 |   ạ   |      | 0192 |   ƒ   |      | 011D |   ĝ   |      | 0125 |   ĥ   |      | 1E15 |   ḕ   |
                  | 1EA2 |   Ả   |      | 1E1E |   Ḟ   |      | 011E |   Ğ   |      | 0126 |   Ħ   |      | 1E16 |   Ḗ   |
                  | 1EA3 |   ả   |      | 1E1F |   ḟ   |      | 011F |   ğ   |      | 0127 |   ħ   |      | 1E17 |   ḗ   |
                  | 1EA4 |   Ấ   |      | 2109 |   ℉   |      | 0120 |   Ġ   |      | 0195 |   ƕ   |      | 1E18 |   Ḙ   |
                  | 1EA5 |   ấ   |      | 2131 |   ℱ   |      | 0121 |   ġ   |      | 0265 | [ ɥ ] |      | 1E19 |   ḙ   |
                  | 1EA6 |   Ầ   |      | 2132 |   Ⅎ   |      | 0122 |   Ģ   |      | 0266 | [ ɦ ] |      | 1E1A |   Ḛ   |
                  | 1EA7 |   ầ   |      | 24A1 |   ⒡   |      | 0123 |   ģ   |      | 029C |   ʜ   |      | 1E1B |   ḛ   |
                  | 1EA8 |   Ẩ   |      | 24BB |   Ⓕ   |      | 0193 |   Ɠ   |      | 1E22 |   Ḣ   |      | 1E1C |   Ḝ   |
                  | 1EA9 |   ẩ   |      | 24D5 |   ⓕ   |      | 0194 |   Ɣ   |      | 1E23 |   ḣ   |      | 1E1D |   ḝ   |
                  | 1EAA |   Ẫ   |      | FF26 |   F   |      | 01E4 |   Ǥ   |      | 1E24 |   Ḥ   |      | 1EB8 |   Ẹ   |
                  | 1EAB |   ẫ   |      | FF46 |   f   |       | 01E5 |   ǥ   |      | 1E25 |   ḥ   |      | 1EB9 |   ẹ   |
                  | 1EAC |   Ậ   |      •------•-------•      | 01E6 |   Ǧ   |      | 1E26 |   Ḧ   |      | 1EBA |   Ẻ   |
                  | 1EAD |   ậ   |                            | 01E7 |   ǧ   |      | 1E27 |   ḧ   |      | 1EBB |   ẻ   |
                  | 1EAE |   Ắ   |                            | 01F4 |   Ǵ   |      | 1E28 |   Ḩ   |      | 1EBC |   Ẽ   |
                  | 1EAF |   ắ   |                            | 01F5 |   ǵ   |      | 1E29 |   ḩ   |      | 1EBD |   ẽ   |
                  | 1EB0 |   Ằ   |                            | 0260 | [ ɠ ] |      | 1E2A |   Ḫ   |      | 1EBE |   Ế   |
                  | 1EB1 |   ằ   |                            | 0261 | [ ɡ ] |      | 1E2B |   ḫ   |      | 1EBF |   ế   |
                  | 1EB2 |   Ẳ   |                            | 0262 | [ ɢ ] |      | 1E96 |   ẖ   |      | 1EC0 |   Ề   |
                  | 1EB3 |   ẳ   |                            | 0263 | [ ɣ ] |      | 210B |   ℋ   |      | 1EC1 |   ề   |
                  | 1EB4 |   Ẵ   |                            | 0264 | [ ɤ ] |      | 210C |   ℌ   |      | 1EC2 |   Ể   |
                  | 1EB5 |   ẵ   |                            | 029B |   ʛ   |      | 210D |   ℍ   |      | 1EC3 |   ể   |
                  | 1EB6 |   Ặ   |                            | 1E20 |   Ḡ   |      | 210E |   ℎ   |      | 1EC4 |   Ễ   |
                  | 1EB7 |   ặ   |                            | 1E21 |   ḡ   |      | 210F |   ℏ   |      | 1EC5 |   ễ   |
                  | 212B |   Å   |                            | 210A |   ℊ   |      | 24A3 |   ⒣   |      | 1EC6 |   Ệ   |
                  | 249C |   ⒜   |                            | 24A2 |   ⒢   |      | 24BD |   Ⓗ   |      | 1EC7 |   ệ   |
                  | 24B6 |   Ⓐ   |                            | 24BC |   Ⓖ   |      | 24D7 |   ⓗ   |      | 2107 |   ℇ   |
                  | 24D0 |   ⓐ   |                           | 24D6 |   ⓖ   |     | FF28 |   H   |      | 212E |   ℮   |
                  | FF21 |   A   |                            | FF27 |   G   |     | FF48 |   h   |      | 212F |   ℯ   |
                  | FF41 |   a   |                            | FF47 |   g   |      •------•-------•      | 2130 |   ℰ   |
                  •------•-------•                            •------•-------•                            | 24A0 |   ⒠   |
        | 24BA |   Ⓔ   |
        | 24D4 |   ⓔ   |
        | FF25 |   E   |
        | FF45 |   e   |
                  | 0049 |   I   |      | 004A |   J   |      | 004B |   K   |      | 004C |   L   |      | 004D |   M   |
                  | 0069 |   i   |      | 006A |   j   |      | 006B |   k   |      | 006C |   l   |      | 006D |   m   |
                  | 00CC |   Ì   |      | 0134 |   Ĵ   |      | 0136 |   Ķ   |      | 0139 |   Ĺ   |      | 019C |   Ɯ   |
                  | 00CD |   Í   |      | 0135 |   ĵ   |      | 0137 |   ķ   |      | 013A |   ĺ   |      | 026F | [ ɯ ] |
                  | 00CE |   Î   |      | 01F0 |   ǰ   |      | 0138 |   ĸ   |      | 013B |   Ļ   |      | 0270 | [ ɰ ] |
                  | 00CF |   Ï   |      | 025F |   ɟ   |      | 0198 |   Ƙ   |      | 013C |   ļ   |      | 0271 | [ ɱ ] |
                  | 00EC |   ì   |      | 0284 |   ʄ   |      | 0199 |   ƙ   |      | 013D |   Ľ   |      | 1E3E |   Ḿ   |
                  | 00ED |   í   |      | 029D |   ʝ   |      | 01E8 |   Ǩ   |      | 013E |   ľ   |      | 1E3F |   ḿ   |
                  | 00EE |   î   |      | 24A5 |   ⒥   |      | 01E9 |   ǩ   |      | 013F |   Ŀ   |      | 1E40 |   Ṁ   |
                  | 00EF |   ï   |      | 24BF |   Ⓙ   |      | 029E |   ʞ   |      | 0140 |   ŀ   |      | 1E41 | [ ṁ ] |
                  | 0128 |   Ĩ   |      | 24D9 |   ⓙ   |      | 1E30 |   Ḱ   |      | 0141 | [ Ł ] |      | 1E42 | [ Ṃ ] |
                  | 0129 |   ĩ   |      | FF2A |   J   |      | 1E31 |   ḱ   |      | 0142 | [ ł ] |      | 1E43 | [ ṃ ] |
                  | 012A |   Ī   |      | FF4A |   j   |       | 1E32 |   Ḳ   |      | 019A |   ƚ   |      | 2133 |   ℳ   |
                  | 012B |   ī   |      •------•-------•      | 1E33 |   ḳ   |      | 019B |   ƛ   |      | 24A8 |   ⒨   |
                  | 012C |   Ĭ   |                            | 1E34 |   Ḵ   |      | 026B | [ ɫ ] |      | 24C2 |   Ⓜ   |
                  | 012D |   ĭ   |                            | 1E35 |   ḵ   |      | 026C |   ɬ   |      | 24DC |   ⓜ   |
                  | 012E |   Į   |                            | 24A6 |   ⒦   |     | 026D | [ ɭ ] |       | FF2D |   M   |
                  | 012F |   į   |                            | 24C0 |   Ⓚ   |     | 026E | [ ɮ ] |      | FF4D |   m   |
                  | 0130 |   İ   |                            | 24DA |   ⓚ   |      | 029F |   ʟ   |      •------•-------•
                  | 0131 |   ı   |                            | FF2B |   K   |      | 1E36 |   Ḷ   |
                  | 0196 |   Ɩ   |                             | FF4B |   k   |      | 1E37 |   ḷ   |
                  | 0197 |   Ɨ   |                            •------•-------•      | 1E38 |   Ḹ   |
                  | 01CF |   Ǐ   |                                                  | 1E39 |   ḹ   |
                  | 01D0 |   ǐ   |                                                  | 1E3A |   Ḻ   |
                  | 0208 |   Ȉ   |                                                  | 1E3B |   ḻ   |
                  | 0209 |   ȉ   |                                                  | 1E3C |   Ḽ   |
                  | 020A |   Ȋ   |                                                  | 1E3D |   ḽ   |
                  | 020B |   ȋ   |                                                  | 2112 |   ℒ   |
                  | 0268 | [ ɨ ] |                                                  | 2113 |   ℓ   |
                  | 0269 |   ɩ   |                                                  | 24A7 |   ⒧   |
                  | 026A | [ ɪ ] |                                                  | 24C1 |   Ⓛ   |
                  | 1E2C |   Ḭ   |                                                  | 24DB |   ⓛ   |
                  | 1E2D |   ḭ   |                                                   | FF2C |   L   |
                  | 1E2E |   Ḯ   |                                                   | FF4C |   l   |
                  | 1E2F |   ḯ   |                                                  •------•-------•
                  | 1EC8 |   Ỉ   |
                  | 1EC9 |   ỉ   |
                  | 1ECA |   Ị   |
                  | 1ECB |   ị   |
                  | 2110 |   ℐ   |
                  | 2111 |   ℑ   |
                  | 24A4 |   ⒤   |
                  | 24BE |   Ⓘ   |
                  | 24D8 |   ⓘ   |
                  | FF29 |   I   |
                  | FF49 |   i   |
                    Hi, All,
                    Continuation of the tables, with, also, some Latin ligatures and various letters and symbols :
                    | 004E |   N   |      | 004F |   O   |      | 0050 |   P   |      | 0051 |   Q   |      | 0052 |   R   |
                    | 006E |   n   |      | 006F |   o   |      | 0070 |   p   |      | 0071 |   q   |      | 0072 |   r   |
                    | 00D1 |   Ñ   |      | 00BA |   º   |      | 01A4 |   Ƥ   |      | 02A0 |   ʠ   |      | 0154 | [ Ŕ ] |
                    | 00F1 |   ñ   |      | 00D2 |   Ò   |      | 01A5 |   ƥ   |      | 211A |   ℚ   |      | 0155 | [ ŕ ] |
                    | 0143 | [ Ń ] |      | 00D3 |   Ó   |      | 0278 | [ ɸ ] |      | 24AC |   ⒬   |      | 0156 | [ Ŗ ] |
                    | 0144 | [ ń ] |      | 00D4 |   Ô   |      | 1E54 | [ Ṕ ] |      | 24C6 |   Ⓠ   |      | 0157 | [ ŗ ] |
                    | 0145 | [ Ņ ] |      | 00D5 |   Õ   |      | 1E55 | [ ṕ ] |      | 24E0 |   ⓠ   |      | 0158 | [ Ř ] |
                    | 0146 | [ ņ ] |      | 00D6 |   Ö   |      | 1E56 | [ Ṗ ] |      | FF31 |   Q   |      | 0159 | [ ř ] |
                    | 0147 | [ Ň ] |      | 00D8 |   Ø   |      | 1E57 | [ ṗ ] |      | FF51 |   q   |      | 01A6 |   Ʀ   |
                    | 0148 | [ ň ] |      | 00F2 |   ò   |      | 2118 |   ℘   |      •------•-------•      | 0210 |   Ȑ   |
                    | 0149 | [ ʼn ] |      | 00F3 |   ó   |      | 2119 |   ℙ   |                            | 0211 |   ȑ   |
                    | 019D |   Ɲ   |      | 00F4 |   ô   |      | 24AB |   ⒫   |                            | 0212 |   Ȓ   |
                    | 019E |   ƞ   |      | 00F5 |   õ   |      | 24C5 |   Ⓟ   |                            | 0213 |   ȓ   |
                    | 0272 | [ ɲ ] |      | 00F6 |   ö   |      | 24DF |   ⓟ   |                            | 0279 | [ ɹ ] |
                    | 0273 | [ ɳ ] |      | 00F8 |   ø   |      | FF30 |   P   |                            | 027A | [ ɺ ] |
                    | 0274 | [ ɴ ] |      | 014C | [ Ō ] |      | FF50 |   p   |                            | 027B |   ɻ   |
                    | 1E44 | [ Ṅ ] |      | 014D | [ ō ] |      •------•-------•                            | 027C |   ɼ   |
                    | 1E45 | [ ṅ ] |      | 014E | [ Ŏ ] |                                                  | 027D |   ɽ   |
                    | 1E46 | [ Ṇ ] |      | 014F |   ŏ   |                                                  | 027E |   ɾ   |
                    | 1E47 | [ ṇ ] |      | 0150 | [ Ő ] |                                                  | 027F |   ɿ   |
                    | 1E48 | [ Ṉ ] |      | 0151 | [ ő ] |      •------•-------•      •------•-------•      | 0280 |   ʀ   |
                    | 1E49 | [ ṉ ] |      | 019F |   Ɵ   |      | Code | Char. |      | Code | Char. |      | 0281 |   ʁ   |
                    | 1E4A | [ Ṋ ] |      | 01A0 |   Ơ   |      •------•-------•      •------•-------•      | 1E58 | [ Ṙ ] |
                    | 1E4B | [ ṋ ] |      | 01A1 |   ơ   |      | 0053 |   S   |      | 0054 |   T   |      | 1E59 | [ ṙ ] |
                    | 2115 |   ℕ   |      | 01A2 |   Ƣ   |      | 0073 |   s   |      | 0074 |   t   |      | 1E5A | [ Ṛ ] |
                    | 24A9 |   ⒩   |      | 01A3 |   ƣ   |      | 015A | [ Ś ] |      | 0162 | [ Ţ ] |      | 1E5B |   ṛ   |
                    | 24C3 |   Ⓝ   |      | 01D1 |   Ǒ   |      | 015B |   ś   |      | 0163 | [ ţ ] |      | 1E5C |   Ṝ   |
                    | 24DD |   ⓝ   |      | 01D2 |   ǒ   |      | 015C |   Ŝ   |      | 0164 | [ Ť ] |      | 1E5D |   ṝ   |
                    | FF2E |   N   |      | 01EA |   Ǫ   |     | 015D |   ŝ   |      | 0165 | [ ť ] |      | 1E5E |   Ṟ   |
                    | FF4E |   n   |      | 01EB |   ǫ   |      | 015E |   Ş   |      | 01AB |   ƫ   |      | 1E5F |   ṟ   |
                    •------•-------•      | 01EC |   Ǭ   |      | 015F |   ş   |      | 01AC |   Ƭ   |      | 211B |   ℛ   |
                                          | 01ED |   ǭ   |      | 0160 |   Š   |      | 01AD |   ƭ   |      | 211C |   ℜ   |
                                          | 01FE |   Ǿ   |      | 0161 | [ š ] |      | 01AE |   Ʈ   |      | 211D |   ℝ   |
                                          | 01FF |   ǿ   |      | 01A7 |   Ƨ   |      | 0287 |   ʇ   |      | 24AD |   ⒭   |
                                          | 020C |   Ȍ   |      | 01A8 |   ƨ   |      | 0288 |   ʈ   |      | 24C7 |   Ⓡ   |
                                          | 020D |   ȍ   |      | 01A9 |   Ʃ   |      | 02A7 |   ʧ   |      | 24E1 |   ⓡ   |
                                          | 020E |   Ȏ   |      | 01AA |   ƪ   |      | 02A8 |   ʨ   |      | FF32 |   R   |
                                          | 020F |   ȏ   |      | 0282 |   ʂ   |      | 1E6A | [ Ṫ ] |      | FF52 |   r   |
                                          | 0275 | [ ɵ ] |      | 1E60 |   Ṡ   |      | 1E6B | [ ṫ ] |      •------•-------•
                                          | 0276 | [ ɶ ] |      | 1E61 | [ ṡ ] |      | 1E6C | [ Ṭ ] |
                                          | 0277 | [ ɷ ] |      | 1E62 | [ Ṣ ] |      | 1E6D | [ ṭ ] |
                                          | 1E4C | [ Ṍ ] |      | 1E63 | [ ṣ ] |      | 1E6E | [ Ṯ ] |
                                          | 1E4D | [ ṍ ] |      | 1E64 | [ Ṥ ] |      | 1E6F | [ ṯ ] |
                                          | 1E4E | [ Ṏ ] |      | 1E65 | [ ṥ ] |      | 1E70 | [ Ṱ ] |
                                          | 1E4F | [ ṏ ] |      | 1E66 | [ Ṧ ] |      | 1E71 | [ ṱ ] |
                                          | 1E50 | [ Ṑ ] |      | 1E67 | [ ṧ ] |      | 1E97 |   ẗ   |
                                          | 1E51 | [ ṑ ] |      | 1E68 | [ Ṩ ] |      | 24AF |   ⒯   |
                                          | 1E52 | [ Ṓ ] |      | 1E69 | [ ṩ ] |      | 24C9 |   Ⓣ   |
                                          | 1E53 | [ ṓ ] |      | 24AE |   ⒮   |      | 24E3 |   ⓣ   |
                                          | 1ECC |   Ọ   |      | 24C8 |   Ⓢ   |     | FF34 |   T   |
                                          | 1ECD |   ọ   |      | 24E2 |   ⓢ   |     | FF54 |   t   |
                                          | 1ECE |   Ỏ   |      | FF33 |   S   |      •------•-------•
                                          | 1ECF |   ỏ   |      | FF53 |   s   |
                                          | 1ED0 |   Ố   |      •------•-------•
                                          | 1ED1 |   ố   |
                                          | 1ED2 |   Ồ   |
                                          | 1ED3 |   ồ   |
                                          | 1ED4 |   Ổ   |
                                          | 1ED5 |   ổ   |
                                          | 1ED6 |   Ỗ   |
                                          | 1ED7 |   ỗ   |
                                          | 1ED8 |   Ộ   |
                                          | 1ED9 |   ộ   |
                                          | 1EDA |   Ớ   |
                                          | 1EDB |   ớ   |
                                          | 1EDC |   Ờ   |
                                          | 1EDD |   ờ   |
                                          | 1EDE |   Ở   |
                                          | 1EDF |   ở   |
                                          | 1EE0 |   Ỡ   |
                                          | 1EE1 |   ỡ   |
                                          | 1EE2 |   Ợ   |
                                          | 1EE3 |   ợ   |
                                          | 2134 |   ℴ   |
                                          | 24AA |   ⒪   |
                                          | 24C4 |   Ⓞ   |
                                          | 24DE |   ⓞ   |
                                          | FF2F |   O   |
                                          | FF4F |   o   |
                    | 0055 |   U   |      | 0056 |   V   |      | 0057 |   W   |      | 0058 |   X   |      | 0059 |   Y   |
                    | 0075 |   u   |      | 0076 |   v   |      | 0077 |   w   |      | 0078 |   x   |      | 0079 |   y   |
                    | 00D9 |   Ù   |      | 01B2 |   Ʋ   |      | 0174 | [ Ŵ ] |      | 1E8A |   Ẋ   |      | 00DD |   Ý   |
                    | 00DA |   Ú   |      | 028B |   ʋ   |      | 0175 | [ ŵ ] |      | 1E8B |   ẋ   |      | 00FD |   ý   |
                    | 00DB |   Û   |      | 028C |   ʌ   |      | 01BF |   ƿ   |      | 1E8C |   Ẍ   |      | 00FF |   ÿ   |
                    | 00DC |   Ü   |      | 1E7C |   Ṽ   |      | 028D |   ʍ   |      | 1E8D |   ẍ   |      | 0176 | [ Ŷ ] |
                    | 00F9 |   ù   |      | 1E7D |   ṽ   |      | 1E80 |   Ẁ   |      | 24B3 |   ⒳   |      | 0177 | [ ŷ ] |
                    | 00FA |   ú   |      | 1E7E |   Ṿ   |      | 1E81 |   ẁ   |      | 24CD |   Ⓧ   |      | 0178 | [ Ÿ ] |
                    | 00FB |   û   |      | 1E7F |   ṿ   |      | 1E82 |   Ẃ   |      | 24E7 |   ⓧ   |      | 01B3 |   Ƴ   |
                    | 00FC |   ü   |      | 24B1 |   ⒱   |     | 1E83 |   ẃ   |      | FF38 |   X   |      | 01B4 |   ƴ   |
                    | 0168 | [ Ũ ] |      | 24CB |   Ⓥ   |     | 1E84 |   Ẅ   |      | FF58 |   x   |      | 028E |   ʎ   |
                    | 0169 | [ ũ ] |      | 24E5 |   ⓥ   |      | 1E85 |   ẅ   |      •------•-------•      | 028F |   ʏ   |
                    | 016A | [ Ū ] |      | FF36 |   V   |      | 1E86 |   Ẇ   |                           | 1E8E |   Ẏ   |
                    | 016B | [ ū ] |      | FF56 |   v   |      | 1E87 |   ẇ   |                            | 1E8F |   ẏ   |
                    | 016C | [ Ŭ ] |      •------•-------•      | 1E88 |   Ẉ   |                            | 1E99 |   ẙ   |
                    | 016D | [ ŭ ] |                            | 1E89 |   ẉ   |                            | 1EF2 |   Ỳ   |
                    | 016E | [ Ů ] |                            | 1E98 |   ẘ   |                            | 1EF3 |   ỳ   |
                    | 016F | [ ů ] |                            | 24B2 |   ⒲   |                            | 1EF4 |   Ỵ   |
                    | 0170 | [ Ű ] |                            | 24CC |   Ⓦ   |                            | 1EF5 |   ỵ   |
                    | 0171 | [ ű ] |                            | 24E6 |   ⓦ   |                            | 1EF6 |   Ỷ   |
                    | 0172 | [ Ų ] |                            | FF37 |   W   |                           | 1EF7 |   ỷ   |
                    | 0173 | [ ų ] |                            | FF57 |   w   |                           | 1EF8 |   Ỹ   |
                    | 01AF |   Ư   |                            •------•-------•                            | 1EF9 |   ỹ   |
                    | 01B0 |   ư   |        | 24B4 |   ⒴   |
                    | 01B1 |   Ʊ   |        | 24CE |   Ⓨ   |
                    | 01D3 |   Ǔ   |        | 24E8 |   ⓨ   |
                    | 01D4 |   ǔ   |        | FF39 |   Y   |
                    | 01D5 |   Ǖ   |        | FF59 |   y   |
                    | 01D6 |   ǖ   |        •-------•-------•
                    | 01D7 |   Ǘ   |
                    | 01D8 |   ǘ   |      •------•-------•      •------•-------•      •------•-------•      •------•-------•
                    | 01D9 |   Ǚ   |      | Code | Char. |      | Code | Char. |      | Code | Char. |      | Code | Char. |
                    | 01DA |   ǚ   |      •------•-------•      •------•-------•      •------•-------•      •------•-------•
                    | 01DB |   Ǜ   |      | 005A |   Z   |      | 00C6 |   Æ   |      | 00DE |   Þ   |      | 005E |   ^   |
                    | 01DC |   ǜ   |      | 007A |   z   |      | 00E6 |   æ   |      | 00FE |   þ   |      | 02C6 |   ˆ   |
                    | 0214 |   Ȕ   |      | 0179 | [ Ź ] |      | 01E2 |   Ǣ   |     •------•-------•      | FF3E |   ^   |
                    | 0215 |   ȕ   |      | 017A |   ź   |      | 01E3 |   ǣ   |      | 00DF |   ß   |      •------•-------•
                    | 0216 |   Ȗ   |      | 017B |   Ż   |      | 01FC |   Ǽ   |      •------•-------•      | 005F |   _   |
                    | 0217 |   ȗ   |      | 017C |   ż   |      | 01FD |   ǽ   |      | 017F |   ſ   |      | FF3F |   _   |
                    | 0289 |   ʉ   |      | 017D |   Ž   |      •------•-------•      •------•-------•      •------•-------•
                    | 028A |   ʊ   |      | 017E |   ž   |      | 0132 |   IJ   |      | 01B7 |   Ʒ   |      | 0060 |   `   |
                    | 1E72 | [ Ṳ ] |      | 01B5 |   Ƶ   |      | 0133 |   ij   |      | 0292 |   ʒ   |      | 02CB |   ˋ   |
                    | 1E73 | [ ṳ ] |      | 01B6 |   ƶ   |       •------•------•      | 01B8 |   Ƹ   |       | FF40 |   `   |
                    | 1E74 | [ Ṵ ] |      | 0290 |   ʐ   |      | 01C4 |   DŽ   |      | 01B9 |   ƹ   |      •------•-------•
                    | 1E75 |   ṵ   |      | 0291 |   ʑ   |      | 01C6 |   dž   |      | 01BA |   ƺ   |      | 00AF |   ¯   |
                    | 1E76 | [ Ṷ ] |      | 1E90 |   Ẑ   |      | 01C5 |   Dž   |      | 01EE |   Ǯ   |      | 02C9 |   ˉ   |
                    | 1E77 | [ ṷ ] |      | 1E91 |   ẑ   |      | 01F1 |   DZ   |     | 01EF |   ǯ   |       | FFE3 |    ̄   |
                    | 1E78 | [ Ṹ ] |      | 1E92 |   Ẓ   |      | 01F3 |   dz   |      | 0293 |   ʓ   |      •------•-------•
                    | 1E79 | [ ṹ ] |      | 1E93 |   ẓ   |      | 01F2 |   Dz   |      •------•-------•      | 00B4 |   ´   |
                    | 1E7A | [ Ṻ ] |      | 1E94 |   Ẕ   |      •------•-------•      | 01BC |   Ƽ   |      | 02CA |   ˊ   |
                    | 1E7B |   ṻ   |      | 1E95 |   ẕ   |      | 01C7 |   LJ   |      | 01BD |   ƽ   |      •------•-------•
                    | 1EE4 |   Ụ   |      | 2124 |   ℤ   |      | 01C9 |   lj   |      •------•-------•      | 01BE |   ƾ   |
                    | 1EE5 |   ụ   |      | 2125 |   ℥   |      | 01C8 |   Lj   |                            | 0294 |   ʔ   |
                    | 1EE6 |   Ủ   |      | 2128 |   ℨ   |      •------•-------•                            | 0295 |   ʕ   |
                    | 1EE7 |   ủ   |      | 24B5 |   ⒵   |      | 01CA |   NJ   |                            | 0296 |   ʖ   |
                    | 1EE8 |   Ứ   |      | 24CF |   Ⓩ   |      | 01CC |   nj   |                            | 02A1 |   ʡ   |
                    | 1EE9 |   ứ   |      | 24E9 |   ⓩ   |      | 01CB |   Nj   |                            | 02A2 |   ʢ   |
                    | 1EEA |   Ừ   |      | FF3A |   Z   |      •------•-------•                            •------•-------•
                    | 1EEB |   ừ   |      | FF5A |   z   |      | 02A3 |   ʣ   |                            | 02C7 |   ˇ   |
                    | 1EEC |   Ử   |      •------•-------•      | 02A5 |   ʥ   |                            | 02D8 |   ˘   |
                    | 1EED |   ử   |                            •------•-------•                            •------•-------•
                    | 1EEE |   Ữ   |                            | 02A6 |   ʦ   |
                    | 1EEF |   ữ   |                            •------•-------•
                    | 1EF0 |   Ự   |                            | FB05 |   ſt   |
                    | 1EF1 |   ự   |                            •------•-------•
                    | 24B0 |   ⒰   |                            | FB06 |   st   |
                    | 24CA |   Ⓤ   |                            •------•-------•
                    | 24E4 |   ⓤ   |
                    | FF35 |   U   |
                    | FF55 |   u   |
                      Hi, All,
                      In addition to all the Latin letters, matched by an equivalence class ( [[=X=]] ), in my two previous posts, here are the last tables, about :
                      • The digit characters
                      • Some currency symbols
                      • The Greek letters and some symbols
                      | 0030 |   0   |      | 0035 |   5   |      | 2469 | [ ⑩ ] |      | 246F | [ ⑯ ] |      | 00A2 |   ¢   |
                      | 24EA |   ⓪   |     | 2464 | [ ⑤ ] |     | 247D |   ⑽   |     | 2483 |   ⒃   |      | FFE0 |   ¢   |
                      | FF10 |   0   |      | 2478 | [ ⑸ ] |     | 2491 |   ⒑   |     | 2497 |   ⒗   |     •------•-------•
                      •------•-------•      | 248C |   ⒌   |      •------•-------•      •------•-------•      | 00A3 |   £   |
                      | 0031 |   1   |      | FF15 |   5   |      | 246A | [ ⑪ ] |     | 2470 | [ ⑰ ] |     | FFE1 |   £   |
                      | 00B9 |   ¹   |      •------•-------•      | 247E |   ⑾   |      | 2484 |   ⒄   |      •------•-------•
                      | 2460 |   ①   |      | 0036 |   6   |      | 2492 |   ⒒   |      | 2498 |   ⒘   |      | 00A5 |   ¥   |
                      | 2474 | [ ⑴ ] |     | 2465 | [ ⑥ ] |     •------•-------•      •------•-------•      | FFE5 |   ¥   |
                      | 2488 |   ⒈   |      | 2479 | [ ⑹ ] |      | 246B | [ ⑫ ] |      | 2471 | [ ⑱ ] |      •------•-------•
                      | FF11 |   1   |      | 248D |   ⒍   |     | 247F |   ⑿   |     | 2485 |   ⒅   |     | 20A9 |   ₩   |
                      •------•-------•      | FF16 |   6   |      | 2493 |   ⒓   |     | 2499 |   ⒙   |     | FFE6 |   ₩   |
                      | 0032 |   2   |      •------•-------•      •------•-------•      •------•-------•      •------•-------•
                      | 00B2 |   ²   |      | 0037 |   7   |      | 246C | [ ⑬ ] |      | 2472 | [ ⑲ ] |
                      | 01BB |   ƻ   |      | 2466 | [ ⑦ ] |      | 2480 |   ⒀   |      | 2486 |   ⒆   |
                      | 2461 | [ ② ] |      | 247A | [ ⑺ ] |      | 2494 |   ⒔   |      | 249A |   ⒚   |
                      | 2475 | [ ⑵ ] |      | 248E |   ⒎   |      •------•-------•      •------•-------•
                      | 2489 |   ⒉   |     | FF17 |   7   |      | 246D | [ ⑭ ] |     | 2473 | [ ⑳ ] |
                      | FF12 |   2   |      •------•-------•      | 2481 |   ⒁   |     | 2487 |   ⒇   |
                      •------•-------•      | 0038 |   8   |      | 2495 |   ⒕   |      | 249B |   ⒛   |
                      | 0033 |   3   |      | 2467 | [ ⑧ ] |      •------•-------•      •------•-------•
                      | 00B3 |   ³   |      | 247B | [ ⑻ ] |      | 246E | [ ⑮ ] |
                      | 2462 | [ ③ ] |      | 248F |   ⒏   |      | 2482 |   ⒂   |
                      | 2476 | [ ⑶ ] |     | FF18 |   8   |      | 2496 |   ⒖   |
                      | 248A |   ⒊   |      •------•-------•      •------•-------•
                      | FF13 |   3   |      | 0039 |   9   |
                      •------•-------•      | 2468 | [ ⑨ ] |
                      | 0034 |   4   |      | 247C | [ ⑼ ] |
                      | 2463 | [ ④ ] |      | 2490 |   ⒐   |
                      | 2477 | [ ⑷ ] |     | FF19 |   9   |
                      | 248B |   ⒋   |      •------•-------•
                      | FF14 |   4   |
                      | 0386 |   Ά   |      | 0389 |   Ή   |      | 039C |   Μ   |      | 03A3 |   Σ   |      | 03A8 |   Ψ   |
                      | 0391 |   Α   |      | 0397 |   Η   |      | 03BC |   μ   |      | 03C2 |   ς   |      | 03C8 |   ψ   |
                      | 03AC |   ά   |      | 03AE |   ή   |      •------•-------•      | 03C3 |   σ   |      •------•-------•
                      | 03B1 |   α   |      | 03B7 |   η   |      | 039D |   Ν   |      | 03F2 |   ϲ   |      | 038F |   Ώ   |
                      •------•-------•      •------•-------•      | 03BD |   ν   |      •------•-------•      | 03A9 |   Ω   |
                      | 0392 |   Β   |      | 0398 |   Θ   |      •------•-------•      | 03A4 |   Τ   |      | 03C9 |   ω   |
                      | 03B2 |   β   |      | 03B8 |   θ   |      | 039E |   Ξ   |      | 03C4 |   τ   |      | 03CE |   ώ   |
                      | 03D0 |   ϐ   |      | 03D1 |   ϑ   |      | 03BE |   ξ   |      •------•-------•      | 2126 |   Ω   |
                      •------•-------•      •------•-------•      •------•-------•      | 038E |   Ύ   |      | 2127 |   ℧   |
                      | 0393 |   Γ   |      | 038A |   Ί   |      | 038C |   Ό   |      | 03A5 |   Υ   |      | 2129 |   ℩   |
                      | 03B3 |   γ   |      | 0390 |   ΐ   |      | 039F |   Ο   |      | 03AB |   Ϋ   |      •------•-------•
                      •------•-------•      | 0399 |   Ι   |      | 03BF |   ο   |      | 03B0 |   ΰ   |      | 03DA |   Ϛ   |
                      | 0394 |   Δ   |      | 03AA |   Ϊ   |      | 03CC |   ό   |      | 03C5 |   υ   |      | 03DB |   ϛ   |
                      | 03B4 |   δ   |      | 03AF |   ί   |      •------•-------•      | 03CB |   ϋ   |      •------•-------•
                      •------•-------•      | 03B9 |   ι   |      | 03A0 |   Π   |      | 03CD |   ύ   |      | 03DC |   Ϝ   |
                      | 0388 |   Έ   |      | 03CA |   ϊ   |      | 03C0 |   π   |      | 03D2 |   ϒ   |      | 03DD |   ϝ   |
                      | 0395 |   Ε   |      •------•-------•      | 03D6 |   ϖ   |      | 03D3 |   ϓ   |      •------•-------•
                      | 03AD |   έ   |      | 039A |   Κ   |      •------•-------•      | 03D4 |   ϔ   |      | 03DE |   Ϟ   |
                      | 03B5 |   ε   |      | 03BA |   κ   |      | 03A1 |   Ρ   |      •------•-------•      | 03DF |   ϟ   |
                      •------•-------•      | 03F0 |   ϰ   |      | 03C1 |   ρ   |      | 03A6 |   Φ   |      •------•-------•
                      | 0396 |   Ζ   |      •------•-------•      | 03F1 |   ϱ   |      | 03C6 |   φ   |      | 03E0 |   Ϡ   |
                      | 03B6 |   ζ   |      | 039B |   Λ   |      •------•-------•      | 03D5 |   ϕ   |      | 03E1 |   ϡ   |
                      •------•-------•      | 03BB |   λ   |                            •------•-------•      •------•-------•
                                            •------•-------•                            | 03A7 |   Χ   |
        | 03C7 |   χ   |
