    How to write parentheses in replacement, using the "Regular expression" mode ?
    4 Posts 3 Posters 10.0k Views
      Hi, @vuvanvui-vui, and All,
      @vuvanvui-vui send me an e-mail, today, saying :
      hello Guy, how are you today,
      hmm i have a question on notepad ++
      in Regular express mode i can’t replace something = “(”, “)”
      exam: i want to replace: Guy = (Guy)
      the () is lost in result
      thanks and sorry for my bad english :D
      As I think that the solution may be useful for others, I prefer to reply on our site !
      Quite easy ! In the Replacement zone, you must simply escape the parentheses with the usual \ symbol ;-)). So :
      SEARCH Guy
      REPLACE \(Guy\) ( or even \x28Guy\x29 )
      Notes :
      • The six characters, which have to be escaped, with the backslash \ symbol, are :
        • The backslash symbol \
        • The left parenthesis (
        • The right parenthesis )
        • The dollar sign $
        • The question mark punctuation sign ?
        • The colon punctuation sign :
      • The above signs have a specific meaning, in the Boost Format String library ! Just refer to :
      http://www.boost.org/doc/libs/1_55_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
      • Most of the time, in replacement, the $, ? and : symbols do not need to be escaped !
      • Vuvanvui VuiV
        Vuvanvui Vui
        thanks a lot ;)
        • 古旮古
          古旮
          Haha. This is a question I asked more than a year ago, to which guy038 also gave valuable reply.
          Seriously, is there a way to edit NPP wiki? I can’t find how to register. And the Regular Expression Page is incomplete and still has some obvious errors.
          • 古旮古
            古旮
            Funny enough: another same question.
