    Regular Expressions LF∉\h LF∈\v
    6 Posts 3 Posters 2.2k Views
    • AZJIO AZJIOA
      AZJIO AZJIO
      [link Regular Expressions](link http://docs.notepad-plus-plus.org/index.php/Regular_Expressions)
      Error for line feed. Look at the description for /h /v
        Hello, @azjio-azjio, and All,
        I confirm that the Line Feed character ( \n ) :
        • Cannot be found with the \h regex, which matches any single horizontal blank character
        • Can be found with the \v regex, which matches any single vertical blank character
        For further information,refer, also, to :
        https://notepad-plus-plus.org/community/topic/15279/unicode-blank-characters-and-the-regexes-h-v-and-s/1
        • AZJIO AZJIOA
          AZJIO AZJIO
          The regular expression does not work
          [a-z][\t\v]+[a-z]
          Divide the word with the Enter key and test the regular expression
          With this began reading the reference, while the problem remained
          MAPJe71M 1 Reply Last reply Reply Quote 0
          • MAPJe71M
            MAPJe71 @AZJIO AZJIO
            @AZJIO-AZJIO did you follow and read the link posted by @guy038 especially his explanation of the difference between \v and [\v]?
            • AZJIO AZJIOA
              AZJIO AZJIO
              I read on the diagonal, not understanding with what it is connected, because I just asked to correct the error in the help. If there is a difference in behavior, this should be indicated in the description, so that everyone does not ask the same question again.
              • MAPJe71M
                MAPJe71
                AFAIK you just indicated there is an error on the linked page, you didn’t ask for a correction :-)
                Furthermore, there is no error on the page.
                Agreed, although keep in mind that the difference wasn’t known of by many (AFAIK, well at least not by me) until @guy038 posted his topic.
