    npp.7.5.4.Installer.x64.exe installed and worked for a few days then won't start
    3 Posts 2 Posters 2.1k Views
    • Steffan RhoadsS
      Steffan Rhoads
      Removed 7.5.4 and installed npp.7.5.3.Installer.x64.exe. Same situation - won’t start.
      This on a fairly new HP Laptop with i7 & 16GB RAM, SSD. Just switching over to the personal laptop as I have to return the work laptop (where Notepad++ is working fine).
      The only similar issue I found was someone was opening a very large .xml file. In my case before the last boot I had only 6 to 12 small text files open.
      I need my Notepad++!
      Lots of errors in the Windows Application Event Log:
      Log Name: Application
      Source: Application Error
      Date: 2018-02-18 09:54:09 PM
      Event ID: 1000
      Task Category: (100)
      Level: Error
      Keywords: Classic
      User: N/A
      Computer: kerpluf
      Description:
      Faulting application name: notepad++.exe, version: 7.5.4.0, time stamp: 0x5a4986ed
      Faulting module name: notepad++.exe, version: 7.5.4.0, time stamp: 0x5a4986ed
      Exception code: 0xc000041d
      Fault offset: 0x000000000001a815
      Faulting process id: 0x2054
      Faulting application start time: 0x01d3a9460da708bb
      Faulting application path: C:\Program Files\Notepad++\notepad++.exe
      Faulting module path: C:\Program Files\Notepad++\notepad++.exe
      Report Id: 415f1342-891d-41d4-af4e-3f237581ac51
      Faulting package full name:
      Faulting package-relative application ID:
      Event Xml:
      <Event xmlns=“http://schemas.microsoft.com/win/2004/08/events/event”>
      <System>
      <Provider Name=“Application Error” />
      <EventID Qualifiers=“0”>1000</EventID>
      <Level>2</Level>
      <Task>100</Task>
      <Keywords>0x80000000000000</Keywords>
      <TimeCreated SystemTime=“2018-02-19T05:54:09.759199100Z” />
      <EventRecordID>3503</EventRecordID>
      <Channel>Application</Channel>
      <Computer>kerpluf</Computer>
      <Security />
      </System>
      <EventData>
      <Data>notepad++.exe</Data>
      <Data>7.5.4.0</Data>
      <Data>5a4986ed</Data>
      <Data>c000041d</Data>
      <Data>000000000001a815</Data>
      <Data>2054</Data>
      <Data>01d3a9460da708bb</Data>
      <Data>C:\Program Files\Notepad++\notepad++.exe</Data>
      <Data>415f1342-891d-41d4-af4e-3f237581ac51</Data>
      <Data>
      </Data>
      <Data>
      </Data>
      </EventData>
      </Event>
      Source: Windows Error Reporting
      Event ID: 1001
      Task Category: None
      Level: Information
      Keywords: Classic
      User: N/A
      Computer: kerpluf
      Description:
      Fault bucket 1613001502981743052, type 4
      Event Name: APPCRASH
      Response: Not available
      Cab Id: 0
      Problem signature:
      P1: notepad++.exe
      P2: 7.5.4.0
      P3: 5a4986ed
      P4: notepad++.exe
      P5: 7.5.4.0
      P6: 5a4986ed
      P7: c0000005
      P8: 000000000001a815
      P9:
      P10:
      \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER8FAC.tmp.dmp
      \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER93A5.tmp.WERInternalMetadata.xml
      \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER93B3.tmp.csv
      \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER93D3.tmp.txt
      These files may be available here:
      C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_notepad++.exe_5f7b3376ec92d88c0fe49418bed128f26bb7da_63375654_42899a0c
      Analysis symbol:
      Rechecking for solution: 0
      Report Id: c0fea1b1-650a-4f67-992a-c7626568a51c
      Report Status: 268435456
      Hashed bucket: 6279cd70c93a53cc566288522765e1cc
      Event Xml:
      <System>
      <Provider Name=“Windows Error Reporting” />
      <EventID Qualifiers=“0”>1001</EventID>
      <Level>4</Level>
      <Task>0</Task>
      <TimeCreated SystemTime=“2018-02-19T05:54:09.544443400Z” />
      <EventRecordID>3502</EventRecordID>
      <Security />
      </System>
      <EventData>
      <Data>1613001502981743052</Data>
      <Data>4</Data>
      <Data>APPCRASH</Data>
      <Data>Not available</Data>
      <Data>0</Data>
      <Data>c0000005</Data>
      <Data>
      </Data>
      <Data>
      </Data>
      <Data>
      \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER93D3.tmp.txt</Data>
      <Data>C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_notepad++.exe_5f7b3376ec92d88c0fe49418bed128f26bb7da_63375654_42899a0c</Data>
      <Data>
      </Data>
      <Data>0</Data>
      <Data>c0fea1b1-650a-4f67-992a-c7626568a51c</Data>
      <Data>268435456</Data>
      <Data>6279cd70c93a53cc566288522765e1cc</Data>
      </EventData>
      </Event>
        Claudia Frank @Steffan Rhoads
        @Steffan-Rhoads
        shot in the dark - I assume you do have the default installation where the user
        specific configuration is saved under %APPDATA%\notepad++ directory, if so,
        stop npp, open explorer and goto %APPDATA% directory and rename notepad++ to something else. Restart npp and new directory notepad++ and the default configuration
        files should have been created.
        Steffan RhoadsS 1 Reply Last reply Reply Quote 0
        • Steffan RhoadsS
          Steffan Rhoads @Claudia Frank
          @Claudia-Frank : that was the trick. I presume I set something that was causing the problem myself (seems odd to manifest that way). Thank-you, I was trying Visual Code & Sublime but really prefer Notepad++. Thank you!
