    Explorer Context don't work in 32bit ++
    2 Posts 2 Posters 1.0k Views
    • Robert HaysR
      Robert Hays
      If running 32bit ++ as Admin. the “Edit with” context menu will not work, do not run as Admin and it works fine. In the 64bit version it works either way.
      Bob
        Claudia Frank @Robert Hays
        @Robert-Hays
        Sure? Because the reason why it isn’t working is the elevation level Microsoft introduced
        some time ago.
        If you run your npp as administrator but the explorer process runs as normal or
        different user then it shouldn’t work - in both versions.
        If both explorer and npp run under on the same level, e.g. both started as administrator,
        then it should work -> 32 as well as on 64 bit
