Notedpad missing from the context of mouse right click
Hi
Attached error occurred
https://imgur.com/a/DXzqu -
sorry, you must supply the installation path of notepad++.
regsvr32.exe C:\Program ...\NppShell_06.dllif there are spaces within your path encase it with double quotes like
regsvr32.exe "C:\Program ...\NppShell_06.dll"… of course must be replaced with your installation path.
And the file NppShell_06.dll MUST be within the installation directory, of course - please double check if this is the case.
Claudia -
Thanks Claudia for your help
Installation path for my Notepad++ is
C:\Program Files\Notepad++
I executed the command (regsvr32) while I am in C:\Windows\System32 directory as shown in the screen shot below :
Am I missing something ?
Thx
Yes, my hint about the spaces in the path :-)
Your call should look like this
regsvr32 "C:\Program Files\Notepad++\NppShell_06.dll"The double quotes are needed as some programs, like regsvr32, determine the parameters
by using a space as a divider. By encasing in double quotes regsvr takes the whole path
as one parameter.Cheers
Claudia -
Thanks Claudia
Yes, my hint about the spaces in the path :-)<<
Although i did last time but I forgot to send you the snapshot.
Below is the screenshot with double quotes
did you run this in an elevated command prompt?
As in Run as administrator?Cheers
Claudia -
Let me try it again and see
Thx -
Thx
Yes Administrator’s privilege was missing and now it is completed successfully , restarted the computer still the option in the mouse right context is not there -
sorry but this means either MS has changed something in regards to shell extension or
your setup has something special about it.
And as I do not have Windows operating system anymore I cannot really try to find out
what is going on.
I’m sorry but I hope someone other with a Windows 10 Installation and knowledge about
what needs to be done reads this and picks up this question.Cheers
Claudia -
Hi,
Just wanted to thank ZillaZilla for posting the problem. I learned from what you were having problems with. I had downloaded Notepad++ and expected it to work right off. Through your post I fixed it and it is working. The only problem was I took off work to do this assignment and wasted all day trying to get this to work.Thanks again!!
