    Help needed with column mode editing
    12 Posts 7 Posters 9.7k Views
    • Christopher WagnerC
      Christopher Wagner
      Thanks Claudia. I did try starting fresh with the %APPDATA% folder. I also un-installed and reinstalled and it doesn’t seem to work. I still can’t make ‘column mode’ selections. Any additional guidance would be appreciated.
      Here is my debug information:
      Notepad++ v7.5.1 (32-bit)
      Build time : Aug 29 2017 - 02:35:41
      OS : Windows 10 (64-bit)
      Plugins : mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll
      Claudia FrankC Scott SumnerS 2 Replies Last reply Reply Quote 0
        Claudia Frank @Christopher Wagner
        @Christopher-Wagner
        just to be sure, did you check whether notepad++ directory has been recreated
        once you started npp?
        Would you mind test the zipped version? Just download, unpack to whatever folder you like and doubleclick notepad++.exe.
        • Scott SumnerS
          Scott Sumner @Christopher Wagner
          @Christopher-Wagner
          Okay, so what exactly are you doing? “Alt+click” maybe isn’t descriptive enough for anyone to tell what is happening for you–it makes me think you aren’t dragging (see below), which is key to column-mode selection with the mouse. Also, “alt+shift+arrow” makes me think you might be doing this all one one line, which would make it not look like a column block, but just like a standard selection.
          Try this to test mouse operation:
          • Copy this text into a new editor window:
            aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
            bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
            cccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc
            dddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd
            eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
          • Hold an Alt key down and Left-Click (and hold) on the third a in the first line
          • Now (with Alt and the Left mouse button still down), drag the mouse down and to the right, and if you move down into the line of e characters, the result should be something like this:
          Imgur
          The above is what a proper column block might look like–notice the first 2 columns of each line are NOT part of the block selection, nor are the non-highlighted columns to the right of the block.
          Try this to test keyboard operation:
          • Use the same text in the same editor buffer
          • Use the arrow keys (alone) to get the caret (cursor) positioned in column 3 of line 1 (it will look like it is between the second and third a on the first line)
          • You should have no highlighted selection at the moment
          • Press and hold Shift+Alt while you press and release the down arrow key 4 times. You should obtain a “tall, skinny” caret/cursor…something like this (ignore the green–something specific to my setup, you won’t have it):
          Imgur
          • Without doing anything else first (you should still be holding Shift+Alt), next press and release the right arrow key a number of times; here’s how it should look:
          Imgur
          Okay, so that ends the column mode tutorial–report back if you don’t achieve the same results and we’ll try to help further.
          Christopher WagnerC 1 Reply Last reply Reply Quote 1
            Christopher Wagner @Scott Sumner
            @Claudia-Frank:
            I did check, and yes, the directory was re-created.
            @Claudia-Frank:
            I downloaded and tested the zipped version of the software. Still no dice.
            @Scott-Sumner said:
            @Christopher-Wagner
            Thanks for the tutorial. I am endeavoring to use the feature correctly. On a previous computer on a previous project I used this feature all the time. I did try using both [alt] + [click] (and drag) as well as [alt] + [shift] + [arrow keys] to make selections. I am able to turn on “multiple editing” in the settings which enables [ctrl] + [click], but this is not as convenient for the blocks of text I am working on.
            Thanks for your continued help.
              Have you checked the Settings > Shortcut Mapper > Scintilla commands, for the
              I would expect to see
              • SCI_LINEDOWNRECTEXTEND = Alt+Shift+Down
              • SCI_LINEUPRECTEXTEND = Alt+Shift+Up
              • SCI_CHARLEFTRECTEXTEND = Alt+Shift+Left
              • SCI_CHARRIGHTRECTEXTEND = Alt+Shift+Right
              with no shortcut conflicts found.
                Christopher Wagner
                Thanks for the suggestion. I can confirm that those shortcuts are correctly listed with no conflicts.
                  @Christopher-Wagner
                  really strange, does the alt key work anyway?
                  What if you press alt+end, does the cursor jump to the end of the line?
                  Do you have some special mouse software in use (One which can configure different actions
                  for different mouse buttons)?
                  • Nauduri Venkata Ravi Rama SastryN
                    Hi, faced a similar problem. i got resolved only after a System restart
                    • vij4ydV
                      vij4yd
                      I know its frowned upon to reply to old threads, but seeing that this topic was never resolved, and to help anyone else reaching here after googling:
                      If the alt key on the left side of your keyboard does not work, try with the one on the right. That worked for me, I don’t know why it doesn’t like the one on the left. :/
                      I had to signup just to comment this.
                        Alan Kilborn @vij4yd
                        @vij4yd
                        I don’t know that this is true, at least here…
                        Yes, you did. Is that a problem?
                        I’ve never heard of this making a difference, but what does make a difference, and isn’t mentioned in this thread, is using the dedicated arrow keys (works) versus using the shared arrow keys on the numeric keypad (doesn’t work). So…if any future readers are trying to get column selecting to work with the numeric keypad arrows, it isn’t going to.
