    Comparing two documents side by side
    3 Posts 3 Posters 5.3k Views
    • Rowan Sylvester-BradleyR
      Can I using Notepad++ to compare two documents side by side, or two copies of the same document (different sections of), so I can copy lines from one side to the other? I can’t see a way to get two windows side by side. Of course, even nicer would be to have the comparison take place automatically, highlighting the sections that are different between the documents. I am trying to merge two sections of a document which were originally copies of the same code, but to which a lot of changes have since been made, resulting in the two sections having a lot of differences.
      Thanks - Rowan
      • Tony BrixT
        Tony Brix
        There is a Compare plugin that should work for you
        • chcgC
          chcg
          Compare plugin is also available from the PluginManager within 32bit N++ for user friendly installation. Additionally you could create a second view of a document if you right click on the corresponding tab and select move of copy it to a second view.
