    Copy leaded data to clipboard without leading tabs or spaces while document stays the same
    1 Posts 1 Posters 1.4k Views 1 Watching
    • Ben TulozB Offline
      Ben Tuloz
      How to strip leading tabs and leading spaces from data copied to clipboard from Notepad++? In other words: I want that the data copied to clipboard won’t include leads that appear in the Notepad++ document itself.
      If you want to make sure you understand my need, I further detailed this with illustration images here.
      Do you know a way to do so?
