    Double-Click a word selects more than that word
    9 Posts 5 Posters 11.0k Views 2 Watching
    • Andrew SackettA Offline
      Andrew Sackett
      Before version 7.3.3
      Double-clicking a word wold select that word. The selection would stop at space, tab, punctuation, or end-of-line.
      After upgrading to 7.3.3
      Double-clicking a word selects that word, but the selection continues, and includes spaces, tabs, and other words adjacent to the click on that line.
      The selection only stops at punctuation or end-of-line.
      Please restore the “Before” behaviour.
      Thanks!
      Y 1 Reply Last reply Reply Quote 1
      • Y Offline
        young-developer @Andrew Sackett
        @Andrew-Sackett I check it on ver. 7.3.3 and it is works as expected. Could you send your debug info?
        NPP > ? > Debug Info …
          Andrew Sackett
          Debug Info
          Notepad++ v7.3.3 (32-bit)
          Build time : Mar 8 2017 - 03:37:37
          OS : Windows 10 (64-bit)
          Plugins : mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll PluginManager.dll
          I have a line in my text file like
          [ Another ] [ Print Barcode ] [ Print Bag Slip ]
          I double-click the word Barcode, and " Print Barcode " is selected.
          Everything between the square brackets, including the spaces.
          Thanks in advance
          – Andrew
            Andrew Sackett
            RESOLVED:
            The original (problematic) install of 7.3.3 was done by the auto-updater process.
            I downloaded a fresh copy of 7.7.3 from the website and installed it myself, right over the existing 7.3.3.
            The double-click-on-a-word problem has resolved.
            Debug info for most recent install (below) is identical to what was posted above.
            Keep up the good work!
            – Andrew
            • dzenanzD Offline
              dzenanz
              I had the same problem. When manually installing, I chose 64-bit installer. It offered to uninstall 32-bit version of Notepad++ (I forgot I had 32-bit version), saying custom config files will be kept. That turned out to be true - my open files were reopened after installation.
              Kudos to the authors!
              • V S RawatV Offline
                V S Rawat
                I also noticed today that when I double click no first word of a line, it is ALSO selecting \r\n of previous line immediately before that word.
                That gives problem when pasting that selected-copied word to some other software, because the additional step added to remove that crlf.
                w8-32 bit latest npp
                • Scott HorowitzS Offline
                  Scott Horowitz
                  I just got a new computer (Windows 10) and installed Notepad++ 7.3.3 (32-bit) and I’m having the same problem where it selects a bunch of spaces next to the word in addition to the word when double-clicking. I never had this issue on the version of Notepad++ on my previous computer (Windows 7). I will try reinstalling to see if that helps.
                    Scott Horowitz
                    Wow, I didn’t expect it to work but it actually did! I reinstalled with the exact same installer executable and it now works properly. Hopefully you guys can figure out the issue, but I’m glad to have it working again!
                    • dzenanzD Offline
                      dzenanz
                      Warning: due to selecting 64-bit version of the installer during reinstall, I had to redo OS file associations.
