    FunctionList.xml Regular Expressions not parsing properly
    17 Posts 3 Posters 9.2k Views 3 Watching
    • MAPJe71M Offline
      MAPJe71
      Should have tested it with your examples before posting it.
      Uses the exclamation mark as the comment character though.
      			|   https://notepad-plus-plus.org/community/topic/11059/custom-functions-list-rules
      			<parser
      				displayName="[TODO] Fortran 90/95/2k - FORmula TRANslation Free Form style"
      				id         ="fortran_function"
      				commentExpr="(?x)                                               # Utilize inline comments (see `RegEx - Pattern Modifiers`)
      								(?m-s:!.*$)                                     # Single Line Comment
      				<function
      					mainExpr="(?x)                                              # Utilize inline comments (see `RegEx - Pattern Modifiers`)
      							(?i:FUNCTION|SUBROUTINE)\s+
      							\K                                                  # keep the text matched so far, out of the overall match
      							\w+
      								\s*
      					<!-- comment out the following node to display the method with its parameters -->
      					<functionName>
      						<nameExpr expr="\w+" />
      					</functionName>
      				</function>
      			</parser>
      • Brian ZeltB Offline
        Brian Zelt
        I guess I’m not doing this correctly:
        here {star} means asterix
        “^([^c]).{star}(function|FUNCTION|subroutine|SUBROUTINE)[\s]{star}\K([\w]+)”
        • MAPJe71M Offline
          MAPJe71
          @brian-zelt
          Enclose the text in back ticks in stead of double quotes or read the manual for markdown syntax .
            Brian Zelt
            Thanks, for the example. It, however, does not match all of the examples I listed.
            My point also, however, was not requesting a Fortran parser (although appreciated) but rather that NP++ was not parsing the RE as expected. That is, there appears to be a bug(s) in the implementation of RE in NP++ or how NP++ is sending text strings to be parsed.
            • MAPJe71M Offline
              MAPJe71
              My bad, retry …
              I tried your RE ^([^c]).*(function|FUNCTION|subroutine|SUBROUTINE)[\s]*\K([\w]+)
              on regex101.com with flags/options m and g set (even tried different combinations) but was not able to get all the subroutine names from following examples (I presumed the double quotes had to be excluded):
               SUBROUTINE bob(a,b,c)
               SUBROUTINE bob()
               SUBROUTINE bob( )
               SUBROUTINE bob
               SUBROUTINE bob
              c SUBROUTINE bob(a,b,c)
               PRIVATE SUBROUTINE bob(a,b,c) return(d)
              i.e. the second example does not give a match.
              This was actually what I expected after reading your RE i.e. I did not expect regex101.com to
              correctly provide the subroutine name for all of examples
              just as N++ does not.
              This one will …
              (?m-s)^(?!c).*(?i:FUNCTION|SUBROUTINE)\s*\K\w+
              • Use these options for the whole regular expression (?m-s)
                • ^$ match at line breaks m
                • (hyphen inverts the meaning of the letters that follow) -
                • Dot doesn’t match line breaks s
              • Assert position at the beginning of a line (at beginning of the string or after a line break character) (carriage return and line feed, form feed) ^
              • Assert that it is impossible to match the regex below starting at this position (negative lookahead) (?!c)
                • Match the character “c” literally (case sensitive) c
              • Match any single character that is NOT a line break character (line feed, carriage return, form feed) .*
                • Between zero and unlimited times, as many times as possible, giving back as needed (greedy) *
              • Match the regex below with these options (?i:FUNCTION|SUBROUTINE)
                • Case insensitive i
                • Match this alternative (attempting the next alternative only if this one fails) FUNCTION
                  • Match the character string “FUNCTION” literally (case insensitive) FUNCTION
                • Or match this alternative (the entire group fails if this one fails to match) SUBROUTINE
                  • Match the character string “SUBROUTINE” literally (case insensitive) SUBROUTINE
              • Match a single character that is a “whitespace character” (any space in the active code page, tab, line feed, carriage return, vertical tab, form feed) \s*
              • Keep the text matched so far out of the overall regex match \K
              • Match a single character that is a “word character” (letter, digit, or underscore in the active code page) \w+
                • Between one and unlimited times, as many times as possible, giving back as needed (greedy) +
              Created with RegexBuddy
              S 1 Reply Last reply Reply Quote 0
                Brian Zelt
                Thanks. I forgot about regexbuddy. Correct, the RE I supplied did not work on the one example. I believe I missed an additional asterix after the initial group when I used the wrong quotes. However, your proposal works better, with the addition of:
                (?m-s)^(?!c|C).*(?i:FUNCTION|SUBROUTINE)\s*\K\w+
                The point remains, however, that when this RE is inserted in functionlist.xml, NP++ does not parse the subroutines properly as described in the original inquiry.
                • S Offline
                  Scott Sumner @MAPJe71
                  @MAPJe71
                  So…I’ve kinda wondered in the past about what you did in your post, so it is a good time to ask. You posted RegexBuddy output. So people get the benefit of RB’s “wisdom” without paying for it (like we have - :) ). It sorta seems wrong to me, a little bit, but is it OK to do? Maybe a question best for Jan…
                  So here’s a great example. Yesterday I answered a regex question (https://notepad-plus-plus.org/community/topic/13556/replace-last-value-in-row-with-0), and I supplied my own explanation, but I was tempted to use RB to generate the explanation, but in the end I didn’t.
                    Brian Zelt
                    Thanks S.S., I haven’t read RB policy’s with respect to re-posting the RB output. RB was correctly referenced to being the source.
                    Again, the point this thread is whether or not NP++ has a bug in the RE processing for FunctionList.xml.
                    Has anybody looked at the source code for NP++ for FunctionList?
                    • MAPJe71M Offline
                      MAPJe71
                      @Scott-Sumner
                      Uhm…to be honest it hadn’t even crossed my mind to look up RB’s policy on posting a copy of the RegEx Tree.
                      @Brian-Zelt
                      Yes, I’ve looked at NP++'s FunctionList code in the past (SourceForge era). I created a patch for it that never got merged. On request I am in the process of re-creating that patch on current code base in addition to cleaning up and adding RE explanation as comment to functionList.xml.
                      There are known issues with the RE engine (as explained by @guy038 here). Both “Search (& Replace)” and FunctionList use the same RE engine. When a RE works with “Search (& Replace)” it will work with FunctionList.
                      However, defining a parser in FunctionList can be tricky.
                      Maybe you can post the complete parser so I (or anyone else) can check it.
                        Brian Zelt
                        Interesting…I played with the commentExpr RE. And now the parser seems to be working. I can’t duplicate the original commentExpr but it was copied from someone’s posted example that included only the fortran ! comment and not the start of line c comment. The original seemed harmless.
                        So, the final fortran parser I have is listed below. I contains a possible flaw that only a single space is allowed between the ‘end’ and ‘function’, whereas a good RE should allow for any number of spaces, but the RE doesn’t permit \s* in the code below.
                        		<association langID="25" id="fortran_function"/>
                        		<parser id="fortran_function" displayName="Fortran" commentExpr="(!.*?$|^(?i:c).*?$)">
                        			<function
                        				mainExpr="(?m-s)^(?!c|C).*(?i:(?<!END\s)FUNCTION|(?<!END\s)SUBROUTINE)\s*\K(\w+)"
                        				displayMode="$functionName$">
                        				<functionName>
                        					<nameExpr expr="[\w]+"/>
                        				</functionName>
                        			</function>
                        		</parser
                        For testing, the following fortran code:
                        c----------------------------------------------------------------------
                        subroutine MYSUB1(iunit0,i,lprt,lnfl2)
                        return
                        end
                          subroutine MYSUB2( )
                          return
                          end
                          subroutine MYSUB3 (
                          return
                          end
                          subroutine MYSUB4()
                          return
                          end
                          subroutine MYSUB5
                          return
                          end
                          subroutine MYSUB6
                          return
                          end
                        c subroutine MYSUB7(a,b,c)
                        return
                        end
                          private subroutine MYSUB8(a,b,c) return(d)
                          end
                        subroutine MYSUB9
                        return
                        end
                          subroutine MYSUB10
                          return
                          end subroutine MYSUB10a
                          !   subroutine MYSUB11(a,b,c)
                          return
                          end
                        should produce, a list:
                        MYSUB1
                        MYSUB2
                        MYSUB3
                        MYSUB4
                        MYSUB5
                        MYSUB6
                        MYSUB8
                        MYSUB9
                        MYSUB10
                        Note that MYSUB7 and MYSUB11 are commented and are correctly not in the list.
                        Using the functionList.xml on existing code files now appears to work for fixed form or free form fortran. For some files, however, the parser only works if I select language ‘fortran free form’ even though the formatting is language ‘fortran fixed form’. Copying the contents of such a file to a new file, corrects the issue, so I suspect there may be a file encoding error embedded in the file that is not otherwise apparent.
                        So… the solution appeared to be related to multiple levels RE in the functionList.xml processing. In this case, perhaps the comment vs the function name (although, I can’t duplicate my original issue).
                        • MAPJe71M Offline
                          MAPJe71
                          Hi @Brian-Zelt
                          Are END and SUBROUTINE (or FUNCTION) allowed to be on separate lines?
                          e.g.
                          subroutine MYSUB12
                          return
                          end
                            subroutine MYSUB12a
                          FYI:
                          1. With the updated commentExpr it’s no longer needed to have (?!c|C) in the mainExpr;
                          2. Using a (numbered-)capturing group for the identifier ((\w+) in the mainExpr) doesn’t add functionality;
                          3. The nameExpr can be simplified to \w+;
                          4. Make sure to encode special XML characters i.e. change < to &lt;
                          5. Free form style uses langID="25" and fixed form style uses langID="59". You could create separate (dedicated) parsers or have both styles associated with the same parser.
                            Brian Zelt
                            Thanks MAPje71,
                            All good points. I couldn’t find a listing of the langID but assumed there must be a better list. Thanks for langID=59.
                            Yes, “end function” must be on a single line.
                            • MAPJe71M Offline
                              MAPJe71
                              FYI: The newest functionList.xml has a language ID table as comment at the top of the associationMap-node.
