    Python / Lua Script: Detect if a modifier is pressed when running a script
    60 Posts 5 Posters 60.7k Views
      Claudia Frank @Yaron
      Yaron,
      no I meant using the GetWindowLongA as I did.
      Btw. it looks like 32bit Python has to use GetWindowLong whereas 64bit Python
      uses GetWindowLongPtr.
      So make a normal script, use my code and print something to the console at the very end of the script just to see if the output is seen. If this is the case run another time and see if something changes. If so we have to change the logic about exstlye…
      • YaronY
        Yaron
        It does write to the console.
        Indeed. :)
        Thank you.
        • YaronY
          Yaron
          exStyle = exStyle & (~WS_EX_LAYOUTRTL)
          I’m testing it.
          Thank you.
            Claudia Frank
            Could you do me a favor and run the following script
            WNDENUMPROC = WINFUNCTYPE(wintypes.BOOL,
                                      wintypes.HWND,
                                      wintypes.LPARAM)
            python_script_hwnd = None
            python_script_sci_handle = None
            GWL_EXSTYLE = -20
            WS_EX_LAYOUTRTL = 0x00400000
            def EnumCallback(hwnd, lparam):
                global python_script_hwnd
                global python_script_sci_handle
                curr_class = (wintypes.WCHAR * 256)()
                curr_name = (wintypes.WCHAR * 256)()
                windll.user32.GetClassNameW(hwnd, curr_class, 256)
                windll.user32.GetWindowTextW(hwnd, curr_name, 256)
                console.write('name:{}\n'.format(curr_name.value.lower()))
                console.write('class:{}\n'.format(curr_class.value.lower()))
                if curr_name.value.lower() == 'python script':
                    python_script_hwnd = hwnd
                else:
                    if python_script_hwnd is not None:
                        if curr_class.value.lower() == 'scintilla':
                            if windll.user32.GetParent(hwnd) == python_script_hwnd:
                                python_script_sci_handle = hwnd
                                return False
                return True
            parent = windll.user32.FindWindowA('Notepad++', None)
            console.write('parent:{}\n'.format(parent))
            windll.user32.EnumChildWindows(parent, WNDENUMPROC(EnumCallback), 0)
            console.write('{}\n'.format('-'*20))
            console.write('python_script_hwnd:{}\n'.format(python_script_hwnd))
            windll.user32.EnumChildWindows(python_script_hwnd, WNDENUMPROC(EnumCallback), 0)
            exStyle = windll.user32.GetWindowLongA(python_script_sci_handle, GWL_EXSTYLE) # GWL_EXSTYLE
            console.write('exStyle:{}\n'.format(exStyle))
            if (exStyle & WS_EX_LAYOUTRTL):
                console.write('exStyle & WS_EX_LAYOUTRTL:{}\n'.format(exStyle & WS_EX_LAYOUTRTL))
                exStyle = exStyle & WS_EX_LAYOUTRTL
            else:
                console.write('exStyle | WS_EX_LAYOUTRTL:{}\n'.format(exStyle | WS_EX_LAYOUTRTL))
                exStyle = exStyle | WS_EX_LAYOUTRTL
            windll.user32.SetWindowLongA(python_script_sci_handle, GWL_EXSTYLE, exStyle);
            console.write('test\n')
            and please post the output
              Claudia Frank
              Maybe XOR
              exStyle = exStyle ^ WS_EX_LAYOUTRTL
              • YaronY
                Yaron
                parent:11404816
                class:#32770
                class:button
                name:
                class:static
                class:#32770
                class:#32770
                class:button
                name:
                class:static
                class:#32770
                class:scintilla
                python_script_hwnd:4392424
                class:#32770
                class:button
                name:
                class:static
                class:#32770
                class:#32770
                class:button
                name:
                class:static
                class:#32770
                c
                class:scintilla
                exStyle:4194304
                exStyle & WS_EX_LAYOUTRTL:4194304
                test
                Both exStyle = exStyle & (~WS_EX_LAYOUTRTL) and exStyle = exStyle ^ WS_EX_LAYOUTRTL do change the the layout.
                I have to clear the output first. Otherwise it’s gibberish.
                Thank you.
                  Claudia Frank
                  Yaron,
                  this seems to be my waterloo in terms of understanding bitwise operations.
                  I always confuse when to use OR and when XOR.
                  So, just to clarify, this works?
                      console.write('exStyle & WS_EX_LAYOUTRTL: {}\n'.format('exStyle & WS_EX_LAYOUTRTL'))
                  else:
                    Claudia Frank
                    and there seem to be a trap. The console changes it output only if something is
                    written to the output. So the initial state will be RTL until something gets written.
                    • YaronY
                      Yaron
                      Yes, it does.
                      If I put the code in startup.py it doesn’t work even after writing to the console.
                      Thanks again. :)
                        Claudia Frank
                        Strange - works for me.
                        Could it be that you already have some ctypes based code in startup.py?
                        Variable overwriting?
                        May you share your startup.py?
                        Or maybe comment everything except the LTR code if you have already ctypes code.
                        • YaronY
                          Yaron
                          Claudia,
                          Do you mean the output is RTL when you open the console?
                          I’ve removed my other code for testing it.
                          Actually I don’t need it on startup. I can write a “Show Console” script.
                          Thank you.
                            yes, on my side it is.
                            When I run a second time from my test script it doesn’t change until
                            another write statement happens, then it is back to LTR.
                            • YaronY
                              Yaron
                              Interesting.
                              I missed that. Sorry.
                              # The lines up to and including sys.stderr should always come first
                              # Then any errors that occur later get reported to the console
                              # If you'd prefer to report errors to a file, you can do that instead here.
                              import sys
                              from Npp import *
                              # Set the stderr to the normal console as early as possible, in case of early errors
                              sys.stderr = console
                              # Define a class for writing to the console in red
                              class ConsoleError:
                              	def __init__(self):
                              		global console
                              		self._console = console;
                              	def write(self, text):
                              		self._console.writeError(text);
                              # Set the stderr to write errors in red
                              sys.stderr = ConsoleError()
                              # This imports the "normal" functions, including "help"
                              import site
                              # This sets the stdout to be the currently active document, so print "hello world",
                              # will insert "hello world" at the current cursor position of the current document
                              sys.stdout = editor
                              from ctypes import windll, byref, wintypes, WINFUNCTYPE, Structure, sizeof
                                                        wintypes.HWND,
                                                        wintypes.LPARAM)
                              GWL_EXSTYLE = -20
                                  else:
                                                  return False
                                  return True
                              else:
                              Thank you.
                              • YaronY
                                Yaron
                                On my machine it changes immediately. It’s gibberish until writing again.
                                Thanks.
                                  Yaron,
                                  strange - might be linux/windows related.
                                  I’ve copied your startup.py - cleaned mine (commented everything)
                                  and now I have your behavior. Phew …
                                  Yaron, it is already half past 4 here and I have to go to late shift today.
                                  Need to have some sleep ;-) I will follow up on this in ~16 hours.
                                  Maybe earlier if we don’t have to do much at work and I can have look.
                                  Good night.
                                  • YaronY
                                    Yaron
                                    Claudia,
                                    Thank you very much. You are great!
                                    default
                                    Sorry for keeping you up so late.
                                    Sleep well and have a nice day. :)
                                      Claudia Frank
                                      Thank you :-D
                                      Did some last test - looks like it a
                                      console.show()
                                      before the code
                                      and if you wish
                                      console.hide()
                                      afterwards does the trick.
                                      Good night.
                                      • YaronY
                                        Yaron
                                        Very nice.
                                        Thanks again. Highly appreciated.
                                        Good night. :)
                                          Claudia Frank
                                          Yaron,
                                          did try to understand what the difference could be but …
                                          While investigating the python script code I assume I found what needs to be changed in
                                          order to force a LTR layout.
                                          The file StaticDialog.cpp has a function makeRTLResource.
                                          Within the function there is this if condition
                                          if (pMyDlgTemplateEx->signature == 0xFFFF)
                                          	pMyDlgTemplateEx->exStyle |= WS_EX_LAYOUTRTL;
                                          else
                                          	(*ppMyDlgTemplate)->dwExtendedStyle |= WS_EX_LAYOUTRTL;
                                          what about giving a try to use
                                          	pMyDlgTemplateEx->exStyle;
                                          else
                                          	(*ppMyDlgTemplate)->dwExtendedStyle;
                                          Yaron, sorry, I would love to see why our machines behave differently but without a debugging environment it’s hard to track down the issue maybe this little code change is a better alternative.
                                          • YaronY
                                            Yaron
                                            Hello Claudia,
                                            I would love to see why our machines behave differently but without a debugging environment it’s hard to track down the issue…
                                            I apologize for not being clear enough in my last post.
                                            In “Very nice” I meant to confirm the issue was solved by adding console.show(). :)
                                            Thank you very much for that too.
                                            A couple of years ago Dave uploaded a PythonScript v1.1.1 without committing the changes.
                                            As your script works perfectly, I’d rather keep using v1.1.1.
                                            Many thanks again for your kind help. I do appreciate it.
                                            Best regards.
