    Python / Lua Script: Detect if a modifier is pressed when running a script
    60 Posts 5 Posters 56.2k Views
    • YaronY
      Yaron
      If I have a bool altPressed in startup.py, I’d need to set it to false on Alt-UP only after some timeout. Is that correct?
      Or setting it to false only in the altDependentScript.
      I’ll think about it.
      You’ve been very helpful as always. :)
      Thank you very much.
        Claudia Frank @Yaron
        Yaron, in case you want to get the mouse clicks see here.
        Cheers and good night
        • YaronY
          Yaron
          Hello again Claudia,
          Detecting a right-click would be better (i.e. execute the script on both left/right-click and detect the button).
          sorry, I missed this one.
          So you do have defined a button in the toolbar, correct?
          And when clicking with left mouse = normal run but when clicking with right mouse then advanced run?
          That’s correct.
          Getting the specific command/button position would be too much. :)
          Thanks again. Highly appreciated.
          Good night.
          • dailD
            dail
            As far as LuaScript goes you’d probably be alot more limited as you have to use what Scintilla/Notepad++ provides which you can catch double clicks and get the modifier keys but don’t think there’s a way to distinguish between left or right click. You could also register the same function with more than one keyboard shortcut, such as “F5”, “Ctrl+F5”, “Alt+F5”, etc…but this is not ideal.
            Python gives more possibilities as far as interacting with the OS so this is probably your better option depending what you need exactly.
            • YaronY
              Yaron
              Hello @dail,
              Thank you for the additional info. I appreciate it.
              If I understand it correctly, SCN_DOUBLECLICK is only relevant to the editor.
              Double-click could have been useful, but I need it for a command or a toolbar button.
              And thanks again for the great Lua Script plugin.
              BTW, Ctrl+left-click to open the file instead of running the script could be a nice addition to Lua Script.
              What do you think?
              • dailD
                dail
                Oh! Now I see what you are doing. In this case PythonScript is your best option.
                Honestly I don’t even know if would be possible. Since individual functions are registered instead of files, there is nothing that associates where a function is defined.
                • YaronY
                  Yaron
                  Hello @dail,
                  A simple example for what I meant:
                  A script TypeLetter types a letter in the editor. Using Customize Toolbar, I’ve assigned a toolbar button to the script.
                  I want it to normally type A but if Alt is down when pressing the toolbar button type B.
                  Claudia’s suggestion is a good option, but I think I’d have to use some timeout.
                  Using another script Toggle TypeLetter Mode is another option which should work well in Lua Script too.
                  Since individual functions are registered instead of files…
                  I didn’t think about that. :)
                  Thanks again.
                    Hello Yaron
                    a quick script about what I meant with mouse click capture.
                    In one script you intercept the window proc (needs to be called first, startup.py might be good choice)
                    from ctypes import windll, byref, wintypes, WINFUNCTYPE, Structure, sizeof
                    WndProcType = WINFUNCTYPE(wintypes.LONG,
                                              wintypes.HWND,
                                              wintypes.UINT,
                                              wintypes.WPARAM,
                                              wintypes.LPARAM)
                    GWL_WNDPROC = -4
                    WNDENUMPROC = WINFUNCTYPE(wintypes.BOOL,
                                              wintypes.HWND,
                                              wintypes.LPARAM)
                    _g = globals()
                    CAPTURE_MOUSE_CLICK = _g.get('CAPTURE_MOUSE_CLICK', False)
                    OLD_WND_PROC = _g.get('OLD_WND_PROC', None)
                    LEFT_MOUSE_CLICK_MOD = False
                    class Hook():
                        def EnumCallback(self, hwnd, lparam):
                            curr_class = (wintypes.WCHAR * 256)()
                            windll.user32.GetClassNameW(hwnd, curr_class, 256)
                            if curr_class.value.lower() == 'toolbarwindow32':
                                self.toolbar_handle = hwnd
                                return False
                            return True
                        def __init__(self):
                            self.toolbar_handle = None
                            parent = windll.user32.FindWindowA('Notepad++',None)
                            windll.user32.EnumChildWindows(parent, WNDENUMPROC(self.EnumCallback), 0)
                            self.oldWndProc = None
                            self.SHIFT_PRESSED = False
                            self.CTRL_PRESSED = False
                            self.ALT_PRESSED = False
                        def register(self):
                            if self.toolbar_handle:
                                self.new_wnd_proc = WndProcType(self.sciWndProc)
                                windll.kernel32.SetLastError(0)
                                self.oldWndProc = windll.user32.SetWindowLongA(self.toolbar_handle, GWL_WNDPROC, self.new_wnd_proc)
                                if self.oldWndProc:
                                    global OLD_WND_PROC
                                    OLD_WND_PROC = self.oldWndProc
                                else:
                                    _err = 'GetLastError:{}'.format(windll.kernel32.GetLastError())
                                    notepad.messageBox('Could not register hook:\n{}\n'.format(_err) +
                                                        'Shortcuts won\'t work',
                                                        'Register Hook Failure', 0)
                            else:
                                console.write('no toolbar_handle found')
                        def unregister(self):
                            if OLD_WND_PROC:
                                self.oldWndProc = OLD_WND_PROC
                                dummy = windll.user32.SetWindowLongA(self.toolbar_handle, GWL_WNDPROC, self.oldWndProc)
                                if not dummy:
                                    notepad.messageBox('Could not unregister hook:\n{}\n'.format(_err) +
                                                        'It is recommended to save data and restart npp to prevent data loss',
                                                        'Unregister Hook Failure', 0)
                            else:
                                console.write('ERROR no saved window proc found')
                        def sciWndProc(self, hWnd, msg, wParam, lParam):
                            if msg == 0x0201: # WM_LBUTTONDOWN
                                global LEFT_MOUSE_CLICK_MOD
                                if wParam == 5: # 0x0001 LButton + 0x0004 Shift
                                    console.write('left mouse click while holding shift\n')
                                    LEFT_MOUSE_CLICK_MOD = True
                                else:
                                    console.write('left mouse click\n')
                            return windll.user32.CallWindowProcA (self.oldWndProc, hWnd, msg, wParam, lParam)
                    _hook = Hook()
                    if not CAPTURE_MOUSE_CLICK:
                        _hook.register()
                        CAPTURE_MOUSE_CLICK = True
                        console.write('registered')
                    else:
                        _hook.unregister()
                        CAPTURE_MOUSE_CLICK = False
                        console.write('unregistered')
                    in another script something like
                    import datetime
                    print datetime.datetime.now()
                    print 'LEFT_MOUSE_CLICK_MOD:{}'.format(LEFT_MOUSE_CLICK_MOD)
                    The first script gets the handle of the toolbar and hooks it message queue.
                    Once you click a button the global variable is set and the second script gets executed.
                    • YaronY
                      Yaron
                      Hello Claudia,
                      Sorry for the late reply. I was not by my PC.
                      And thank you for the beautiful script. I appreciate your kindness.
                      Now that you capture both the click and the modifier, there’s no need to use timeout and it works like a charm.
                      Two follow-up questions with your permission:
                      1. Customize Toolbar inserts a separator on pressing Shift and left-clicking a toolbar button.
                        Which module should I import in order to use GetKeyState() and detect Alt?
                      2. The little programming experience I have is from Firefox.
                        In that browser adding a right-click functionality to a toolbar button is done as follows:
                      • Get A specific toolbar button object.
                      • Add a click listener to that button and assign your own action to right-click.
                      I suppose this procedure would be more complex in NPP.
                      Actually you can replace in your script
                      with
                      if wParam == 3: # 0x0001 LButton + 0x0002 MK_RBUTTON
                      and then if you hold the right button down and left-click - you can execute the script in “alternative mode”.
                      Another simple (and not as elegant) way to run a script in two modes:
                      In startup (py or lua) add testScriptDefaultMode = True.
                      Create a script Toggle TestScript Default Mode containing two lines:
                      global testScriptDefaultMode
                      testScriptDefaultMode = not testScriptDefaultMode
                      In TestScript check if testScriptDefaultMode:.
                      Assign a simple shortcut (e.g. Alt+Spacebar) to Toggle TestScript Default Mode and use it to quickly toggle the modes…
                      Thanks again.
                      Have a nice weekend.
                        @Yaron
                        The function is also called GetKeyState and is in user32.dll.
                        You need to provide the virtual key code to get the state, so something like
                        alt_state = windll.user32.GetKeyState(0x12)
                        but using wine, I was not able to press alt and do left click with mouse.
                        Would be interesting to see if this works on Windows.
                        I think so too. Out of my mind, you would need to find notepad++ window handle,
                        enumerate child windows to get toolbar, enumerate toolbar child windows to get
                        the button in question (not sure how to identify), register a function which hooks into
                        buttons message queue and I don’t know what happens if another program accesses toolbar
                        to modify (or add/delete) a button?? I’m pretty sure it can be done but I’m not convinced
                        it should be done.
                        Another possible solution to run script in alternate mode would be to use a
                        inputbox (prompt method) ;-) (also not as elegant but most painless version) :-D
                        • YaronY
                          Yaron
                          Hello Claudia,
                          Great. Thank you.
                          if alt_state < 0:
                          Works perfectly.
                          Out of my mind, you would need to find notepad++ window handle…
                          Your confirmation that this is indeed rather complex is important.
                          inputbox
                          So I have multiple choices now. :)
                          Being a “mouse-oriented” user, your script detecting if the right button was down when left-clicking would probably fit me best.
                          Thanks again for your time and clever ideas. I do appreciate it.
                          • Scott SumnerS
                            Scott Sumner @Yaron
                            @Yaron and @Claudia-Frank
                            Oftentimes I find myself writing a Pythonscript that either acts on text above the caret or below the caret. So I need a way to tell it which way to go. An input box would work, but it slows down one’s “workflow”. Often it is an alternate but related keypress (e.g. F10 runs functionality above the caret, Shift+F10 for below the caret) that I want to use. So what I’ve been doing is having 3 scripts, one “common” one, and two others. The two others are tied to F10 and Shift+F10, and call the common script, telling it the direction.
                            So I just wanna say that this thread has gotten me thinking about how to do this cleaner; haven’t done anything about it yet, but definitely thinkin’… :-D
                            • YaronY
                              Yaron
                              Hello Scott,
                              It’s good to know an experienced “Pythoneer” like yourself have been coping with this issue.
                              Our Claudia is really clever, isn’t she? :)
                              Please share with us your preferred solution.
                              Best regards.
                                Alan Kilborn @Scott Sumner
                                @Scott-Sumner
                                I don’t know that this thread will be of any help for that kind of key differentiation. I do see how it might work with a toolbar button assigned to a pythonscript, though, but this seems like it isn’t what you want.
                                • YaronY
                                  Yaron
                                  Hello Claudia and all,
                                  Thanks again for the script. I appreciate it.
                                  I’ve slightly modified it so that right-clicking a toolbar button would execute its command.
                                  Emulating the regular left-click behavior:
                                  • When the right button is down, the toolbar button is “checked”.
                                    default
                                  • The command is executed only when the right button is released.
                                  If anyone can think of a better way to achieve that behavior, please let me know.
                                                            wintypes.HWND,
                                                            wintypes.UINT,
                                                            wintypes.WPARAM,
                                                            wintypes.LPARAM)
                                  GWL_WNDPROC = -4
                                                            wintypes.HWND,
                                                            wintypes.LPARAM)
                                  _g = globals()
                                  RIGHT_CLICK_MODE = False
                                  REAL_RIGHT_UP = False
                                  class Hook():
                                              return False
                                          return True
                                      def __init__(self):
                                          parent = windll.user32.FindWindowA('Notepad++', None)
                                      def register(self):
                                              if self.oldWndProc:
                                                  global OLD_WND_PROC
                                              else:
        'Right-click mode won\'t work',
                                          else:
                                          if OLD_WND_PROC:
                                              if not dummy:
                                          else:
                                  		global REAL_RIGHT_UP
                                  		global RIGHT_CLICK_MODE
                                  		if msg == 0x0204:		# WM_RBUTTONDOWN.
                                  			windll.user32.mouse_event(0x0002, 0, 0, 0, 0)	# Left down. WM_RBUTTONUP is sent although the right button is still down.
                                  		elif msg == 0x0205:	# WM_RBUTTONUP.
                                  			if REAL_RIGHT_UP:		# Another WM_RBUTTONUP is sent when the right button is released. Process it now.
                                  				RIGHT_CLICK_MODE = True
                                  				windll.user32.mouse_event(0x0004, 0, 0, 0, 0)	# Left up.
                                  				windll.user32.SetTimer(hWnd, 1, 1000, 0);	# 1 == TIMER_ID.
                                  			REAL_RIGHT_UP = True
                                  		elif msg == 0x0113 and wParam == 1:		# WM_TIMER.
                                  			windll.user32.KillTimer(hWnd, 1);
                                  _hook = Hook()
                                      _hook.register()
                                  else:
                                      _hook.unregister()
                                  Copy and paste the code in startup.py.
                                  In a script you want to run in two modes, (i.e. left-click and right-click) add modeRightClick = RIGHT_CLICK_MODE and handle it accordingly.
                                  Since a 1 Sec timer is set to revert RIGHT_CLICK_MODE to False, it’s recommended to add modeRightClick = RIGHT_CLICK_MODE at the beginning of the script.
                                  Best regards.
                                  Claudia FrankC 2 Replies Last reply Reply Quote 0
                                    @Yaron
                                    so you are concerned not seeing the pressed/checked button if right clicking on it, aren’t you?
                                      @Yaron
                                      here my solution, not fully error proved and just added without any structure
                                      but I guess you get the point.
                                      You need to import another 4 types from ctypes (pointer, c_ubyte, c_int, c_ulong)
                                      The changed part is
                                          if msg == 0x0201: #0x0201: # WM_LBUTTONDOWN
                                              else:
                                          elif msg == 0x0204:
                                                  class TBBUTTON(Structure):
                                                      _fields_ = [
        ('iBitmap', c_int),
        ('idCommand', c_int),
        ('fsState', c_ubyte),
        ('fsStyle', c_ubyte),
        ('bReserved', c_ubyte * 6), # 2 if win32
        ('dwData', c_ulong),
        ('iString', c_int),
                                                  _point = wintypes.POINT()
                                                  result = windll.user32.GetCursorPos(byref(_point))
                                                  if result:
                                                      _hwnd = windll.user32.WindowFromPoint(_point)
                                                      windll.user32.ScreenToClient(_hwnd,pointer(_point))
                                                      button_id = windll.user32.SendMessageA(_hwnd,
        1024+69, # TB_HITTEST(WM_USER + 69)
        0,
        pointer(_point))
                                                      _tbbutton = TBBUTTON()
                                                      bool = windll.user32.SendMessageA(_hwnd,
        1024+23, # TB_GETBUTTON(WM_USER + 23))
        button_id,
        byref(_tbbutton))
                                                      if bool:
                                                          pressed = windll.user32.SendMessageA(_hwnd,
        1024+2, # TB_CHECKBUTTON(WM_USER + 2)
        _tbbutton.idCommand,
        True)
                                      Seems to work on linux, so should work on windows as well.
                                      • YaronY
                                        Yaron
                                        Hello Claudia,
                                        Thank you very much for the new code. I do appreciate that.
                                        I’m afraid we had some misunderstanding here.
                                        With your permission, let’s start from scratch. :)
                                        As I’ve mentioned in the first post here, my preferred solution is: right-click a toolbar button to execute its command in “alternative mode”.
                                        A simple example: Select and Find Next and Select and Find Previous.
                                        I want to have one toolbar button: Select and Find Next/Previous. - Left-clicking the button would find Next and right-clicking it would find Previous.
                                        My code (that is: your code slightly modified) works perfectly well.
                                        The button is “checked” on right-click and the command is executed on right-up (as the regular left-click behavior).
                                        I just meant that my implementation is a bit tricky and I’d appreciate a better solution.
                                        windll.user32.mouse_event(0x0002, 0, 0, 0, 0) # Left down. invokes a WM_RBUTTONUP message although the right button is still down.
                                        And I want the command to be executed only when the right button is up…
                                        Allow me to ask you to run my version and have a quick look at the code. You’ll get it very quickly. :)
                                        Thank you.
                                        I suppose your new code should make the button “checked”. It does that but the command is not executed.
                                        Again: some misunderstanding.
                                        I assume the following shorter version is adequate If I put the code in startup.py and I’m not interested in toggling the right-click capture. Is that correct?
        wintypes.HWND,
        wintypes.UINT,
        wintypes.WPARAM,
        wintypes.LPARAM)
                                        GWL_WNDPROC = -4
        wintypes.HWND,
        wintypes.LPARAM)
                                        class ToolbarRightClick():
                                        		if curr_class.value.lower() == "toolbarwindow32":
                                        			return False
                                        		return True
                                        	def __init__(self):
                                        		parent = windll.user32.FindWindowA("Notepad++", None)
                                        	def registerRightClick(self):
                                        			msgConsole = "Toolbar Right-Click Mode Registered.\n\n"
                                        		else:
                                        			msgConsole = "Error Registering Toolbar Right-Click Mode.\n\n"
                                        		console.write(msgConsole)
                                        _toolbarRightClick = ToolbarRightClick()
                                        _toolbarRightClick.registerRightClick()
                                        Thanks again.
                                        Have a great day.
                                          @Yaron
                                          I guess I see now but this misunderstanding shows a way to solve it.
                                          When you get the button command id (_tbbutton.idCommand) you are able
                                          to execute it via notepads menuCommand function like
                                          notepad.menuCommand(_tbbutton.idCommand)
                                          so my latest example with the logic like this
                                          if msg == 0x0201: # left
                                          elif msg == 0x0204:
                                              pressed = windll.user32.SendMessageA(self.toolbar_hwnd,
        True)
                                              # execute script
                                          elif msg == 0x0205:
        False)
                                          should do what you want.
                                          • YaronY
                                            Yaron
                                            Hello Claudia,
                                            That’s brilliant. Thanks again for your time.
                                            If you want the command executed on right-up, move
                                            # execute script
                                            to elif msg == 0x0205:.
                                            Also, you can use windll.user32.mouse_event(0x0002, 0, 0, 0, 0) without a timer.
                                            		elif REAL_RIGHT_UP and msg == 0x0201:		# WM_LBUTTONDOWN.
