    function list - need help with regular expression
    18 Posts 4 Posters 7.5k Views
    • MAPJe71M
      MAPJe71
      Function List searches with dot matches newline enabled.
      Furthermore,
      1. the displayName="[TBD] Wiki" should be displayName="Wiki";
      2. make sure you have defined a “User Defined Language” named Wiki i.e. same value (incl. case) as that of displayName.
      • Christian11235C
        Christian11235
        Hello,
        to 1: Yes - I assumed this.
        to 2: Yes - this was the case from the beginning.
        To clarify: the problem ist not that the parsing is not working at all - the problem ist that not all headlines are found. Till now I only have regular expressions which either find
        • the first headline
          expr=“(?-s)^=+.*=+$”
        • all headlines but take them for one headline
          expr=“^=+.*=+$”
        Thanks,
        Christian
        • MAPJe71M
          MAPJe71
          What about (?m)^=+.*=+$ or (?-s)=+.*?=+ ?
          • Christian11235C
            Christian11235
            Hi,
            both expressions only show the first header. All headlines after the first header are ignored.
            My testfile has the name tst.wik and looks like this
            = header 1 =
            text
            == sub header 1 ==
            text
            CU
            Christian
            • Christian11235C
              Christian11235
              Sorry - I need to correct me - both expressions show the last header
              • MAPJe71M
                MAPJe71
                Are you applying the changes to the correct functionList.xml?
                There might be more then one functionList.xml file on your system.
                  Hello Christian 11235, Claudia, MAPJe71 and All,
                  Christian, I suppose that you’re speaking about the Wikimarkup, used in Wikipedia, aren’t you ?
                  https://en.wikipedia.org/wiki/Help:Wiki_markup
                  For a rapid test of your parser, you may, simply, use a usual text file. You don’t need to create any UDL language !
                  So, in a new tab, add the test lines, below :
                  = Header 1 =
                  Line 1
                  Line 2
                  Line 3
                  == sub header 002 ==
                  Line 4
                  Line 5
                  Line 6
                  === sub header_3 ===
                  Line 7
                  Line 8
                  Line 9
                  ==== sub header     4 ====
                  Line 10
                  line 11
                  line 12
                  ===== TEST =====
                  Line 13
                  Line 14
                  Line 15
                  ====== sub header 6 ======
                  Line 16
                  Line 17
                  Line 18
                  =			Last test  ab___c     d            ==
                  Line 19
                  Line 20
                  Line 21
                  ======= Should NOT be displayed =======
                  Line 22
                  Line 23
                  Line 24
                  • Save it as a .txt file
                  Then, in your functionList.xml file :
                  • In the associationMap node, add the line :
                    <association langID= “0” id=“wiki_syntax” />
                  • And, at the beginning of the parser node, add the parser, below :
                  <parser id="wiki_syntax" displayName="wiki">
                      <function
                          mainExpr="^(={1,6})\h+\K(\w| )+(?=\h+\1)">
                      </function>
                  </parser>
                  You should see, in the Function List panel, each header of the different sections of my example:
                  Header 1
                  sub header 002
                  sub header_3
                  sub header     4
                  TEST
                  sub header 6
                  Last test ab___c     d
                  NOTES :
                  • In the value of mainExpr, there is a space between the alternative sign | and the ending round bracket )
                  • I supposed that a header, of a section, is a non-empty string, which contains, ONLY :
                    • Usual word characters ( Upper and lower letters, digits and the underscore _ )
                    • Space characters
                  • I didn’t consider the tabulation character. Indeed, if a header is, for instance, the string A[Tab][Tab][Tab][Tab][Tab]B, it is, simply, displayed as the string AB, in the FunctionList panel, anyway !
                  => The middle part of the regex = (\w| )+
                  • From beginning of line, each section header :
                    • Begins with one to six equal sign(s), followed by, at least, one space character ( => the first part of the regex = ^(={1,6})\h+\K )
                    • Ends with the same number of equal signs, than, at beginning of line, preceded by, at least, one space character ( => the final part of the regex = (?=\h+\1) )
                  • As this regex does NOT use the dot character, at all, the ``dot matches new line` way of search, of the functionList feature, doesn’t matter :-))
                  • Christian11235C
                    Christian11235
                    Hi,
                    @all: thanks a lot for you effort.
                    @MAPJe71: As the changes show different results I think I edited the right xml file. There are also three languages in my functionsList.xml which I use in daily work - without problems.
                    @uy038: I copied all your steps - and maybe I have done something wrong - because I don’t see anything.
                    I took two screenshots:
                    This one show the functionsList.xml and the test-file and the resulting function List:
                    https://www.dropbox.com/s/z1cms3khiqmbe02/npp_screenshot01.jpg?dl=0
                    This screenshot shows the same but the focus is now on the functionList.xml - and there you can see a working functions list (just to proof its working at all).
                    https://www.dropbox.com/s/1uxii4mqhgw4vwz/npp_screenshot02.jpg?dl=0
                    In my functionList.xml are three other languages - for these three languages the function list works.
                    As said - thanks a lot for your effort. Maybe I am doing something wrong - but in the moment I cannot see it.
                    Christian
                      Hi, Christian 11235,
                      Thanks for your two screenshots. I just noticed that your .txt file is an Unix file ( with \n End of Line character )
                      with an ANSI encoding. So I changed my Windows file, with UTF8 encoding to test but, of course, this makes NO difference. I mean : I did get the expected list of sections in the Function List panel !
                      So, at first sight, I, really, do NOT understand what happens ???. An idiotic question, to be sure ! Of course, you may modify and save the functionList.xml file from within Notepad++. But you need to close and re-start N++ to get it working !
                      Now, could you do an other simple test :
                      • Use the SAME example text, of my previous post
                      • In your functionList.xml file, in the “Wiki” parser, just change the line :
                      by the line, below, which contains a very simple regex :
                          mainExpr="^Line \d+">
                      • Close and re-start N++
                      • In the Function List panel, after selecting the test file, you should see the obvious list, below !
                        Line 1
                        Line 2
                        Line 3
                        Line 4
                        Line 5
                        Line 6
                        Line 7
                        Line 8
                        Line 9
                        Line 10
                        line 11
                        line 12
                        Line 13
                        Line 14
                        Line 15
                        Line 16
                        Line 17
                        Line 18
                        Line 19
                        Line 20
                        Line 21
                        Line 22
                        Line 23
                        Line 24
                      Tested with N++ v7.2 and N++ v7.3.2 => Both OK
                      • MAPJe71M
                        MAPJe71
                        @guy038 is there a specific reason you use (\w| )+ instead of [\w ]+?
                          Hi, MAPJe71,
                          Good question : Absolutely no reason, indeed ! The syntaxes (\w| )+ and ([\w ]+) are equivalent !
                          I did a rapid test, comparing the two S/R, below
                          SEARCH (\w| )
                          REPLACE \1\1
                          and
                          SEARCH ([\w ])
                          REPLACE \1\1
                          After 722,970 replacements, in both cases, your method seems a bit quicker than mime : 71s instead of 73s for my solution !
                          • Christian11235C
                            Christian11235
                            Hello,
                            1. Unix / Ansi is the default at the place I work at. I should have mentioned that.
                              Now that I think about it - at work I have to use Windows 7 32 bit (please don’t make me explain this *1) and also n++ 32bit.
                            2. Yes I always closed and restarted n++.
                            3. mainExpr=“^Line \d+”> shows nothing in the Function List (edited functionList.xml, saved, closed n++, started n++, n++ 7.3.2 (32 bit, Build Feb 12 2017) )
                            Then i did some expermenting: Added my initial setup in functionList.xml, changed the test-file to UTF-8 BOM, Windows CR-LF. Result: only the first header is shown (no improvement).
                            Maybe it has something to do with n++ 32bit ? Later I will try this at home (windows 10, 64 bit).
                            Thanks,
                            Christian
                            *1 The company I work at believes in putting money in managers and outsourcing. Not in hired software engineers.
                            • Christian11235C
                              Christian11235
                              Hi,
                              I am sorry - I just made a mistake and used the wrong functionList.xml. Now that I am doing it correct
                              <function mainExpr=“^(={1,6})\h+\K(\w| )+(?=\h+\1)”/>
                              is working and shows the correct functions.
                              I can only apologize and thank you for all the help,
                              Christian
