    Double click links no longer work
    13 Posts 6 Posters 12.7k Views
      Claudia Frank @mkupper
      @mkupper
      thank you very much, that is exactly the kind of information which was needed.
      I can reproduce it as well and I guess I understand why it happens.
      When changing the lexer (by using a different language from menu) the text gets styled newly
      and therefore the underline gets removed. When adding a char npp does seem to call the link style again to create it.
      Not sure if this can be easily solved but I know what to look for and will open an
      issue at github once I find which part needs to be modified.
      • mkupperM
        mkupper
        Is the double-click to follow a link stuff done by npp itself, Scintilla, or the language parsers?
        If I have a .htm file where the links are not working and rename it to .txt then npp recognizes and color codes it as HTML and links don’t work. Thus it seems like a glitch related to the HTML language.
        • I was running v7.3.3 32-bit
        • Disabled all plugins - no joy.
        • v7.2 - Works
        • v7.2.1 - Works
        • v7.2.2 - Works
        • v7.3 - Does not work
        • v7.3.1 - Does not work
        • v7.3.2 - Does not work
        • v7.3.3 - Does not work
        By “does not work” I mean that links don’t work in .htm files. They work fine in .bat .css, .txt, etc. It looks like they broke starting with v7.3
        By links I mean:
        • file://c:/some/path/to/a/file/or/folder
        • np://c:/some/path/to/a/file/or/folder np is my own protocol. It runs npp to open the file. I mainly use it in links to .bat and .htm files as I want double click to open the file for editing in npp and not to run the batch script or to open the file in a browser.
        • http://www.domain-name.com/…
        • outlook://… Another of my own protocols. It launches Microsoft Outlook in a folder or message.
        Normally I can double click a link to view or launch the file.
          Hi, Jean Heck, mkupper and Claudia,
          Please, read my post to Don :
          https://notepad-plus-plus.org/community/topic/13415/v7-3-3-fix-cia-hacking-notepad-issue/14
            @mkupper
            Not by the parser but by npp and scintilla.
            Scintilla does the underlying coloring etc… (basically how it looks like) but
            npp needs to trigger it.
            Guy already confirmed your findings so do I.
            • chcgC
              chcg
              Maybe introduced with https://github.com/notepad-plus-plus/notepad-plus-plus/commit/911fd9a7bdade5953302159bfaa066114197e6a1.
              The part of the code setting the style for links deals with scintilla deprecated code:
              SCI_SETSTYLEBITS(int bits) Deprecated
              SCI_GETSTYLEBITS → int Deprecated
              SCI_GETSTYLEBITSNEEDED → int Deprecated
              INDIC0_MASK, INDIC1_MASK, INDIC2_MASK, INDICS_MASK Deprecated
              Scintilla no longer supports style byte indicators. The last version to support style byte indicators was 3.4.2. Any use of these symbols should be removed and replaced with standard indicators. SCI_GETSTYLEBITS and SCI_GETSTYLEBITSNEEDED always return 8, indicating that 8 bits are used for styling and there are 256 styles.
              In a lexer specific way and especially html with js is special. See Notepad_plus::addHotSpot() and there
              if (type == L_HTML || type == L_PHP || type == L_ASP || type == L_JSP)
              	mask = INDIC2_MASK;
              I already failed on removing this. Hopefully the issue is not related to that part.
              • dailD
                dail
                @chcg
                Since that was my commit I figured I should check it out.
                I used the v7.3.3 and reverted that single commit and it still has the bug, so looks like I’m off the hook :) I’ll do a git bisect and try to track down the commit that introduced it.
                • dailD
                  dail
                  Hmmm maybe I spoke to soon…
                  • dailD
                    dail
                    I’ve opened https://github.com/notepad-plus-plus/notepad-plus-plus/pull/3019 which solves the issue with clicking links in certain file types.
                    mkupperM 1 Reply Last reply Reply Quote 2
                    • chcgC
                      chcg
                      @dail
                      thanks for checking it. The thing with the stylebit usage for URL links works, but as the documentation on it is not existing it is hard to deal with it and to understand. Especially as it doesn’t follow the normal scintilla way from my point of view and the embedded stuff in HMTL which is handled different most other lexers.
                      • mkupperM
                        mkupper @dail
                        Thank you @dail I think you would have been safe leaving the style variable typed as auto and to change line 924
                        < if (not notifyView->execute(SCI_STYLEGETHOTSPOT, style))
                        > if (not notifyView->execute(SCI_STYLEGETHOTSPOT, static_cast<uint8_t>(style)))
                        It appears there’s a Scintilla bug in that it’s storing the style index bytes as int8_t rather than uint8_t. When a document has more than 127 styles then SCI_GETSTYLEAT, which returns an int, sign-extends the style byte index 128 to 255 into negative values when converting the int8_t into an int. That bug should not have mattered for most of the old npp code except line 924 where Scintilla expected you to pass a style index value from 0 to 255 to SCI_STYLEGETHOTSPOT. When you passed a negative value to SCI_STYLEGETHOTSPOT it returned false.
