    Unnamed strange problem (v7.2.2 and previous)
    12 Posts 3 Posters 5.7k Views
    • gstaviG
      gstavi
      Very strange indeed.
      My thoughts:
      • The fact that EOL symbols start appearing in middle of view hints toward Scintilla rendering problem rather than document text corruption. A guess would be some memory overrun bug that among other things turns on the rendering flag.
      • Since same file is opened in second tab I wonder what do you see when you scroll to same location there.
      • What plugins do you have installed?
      • How often does it happen?
      • If you re-ecnode file to UTF8, can you still reproduce this issue?
      • Does it also happen with smaller files?
      • After it happens if you “save as” to different name, relaunch npp and open it, is the file corrupted?
      stabker steepsonS 1 Reply Last reply Reply Quote 0
      • stabker steepsonS
        stabker steepson
        I will check it next time.
        Compare, Converter, MIME Tools, NppExec, NppExport
        Not really often, maybe every ~10 coding seances. But enough to be annoying.
        I don’t know how to reproduce this. I have only a guess that this caused by two tabs of the same document + ‘{’ symbol + enter. Maybe this bug caused by auto-tabulation?
        It never happened with smaller files. But i work really rarely with smaller files and never in two tabs.
        I’ll check next time. But i think no, because when this appears with document on screenshot, i just press Ctrl+Z for a few times, reload Notepad (without saving), and then document looks OK, except two tabs doesn’t synced and behave like two different documents! Then i got to choose, which of them i need to save, and which to close “without saving”.
        There is also one thing that maybe could help. When i scroll document at the end, there is a “}” brace, that added automatically. And as i remember, it adds only to one of tabs. I’ll try to check it next time when bug appears.
        • dailD
          dail
          Turn off periodic backups. It is known to corrupt large files.
          • stabker steepsonS
            stabker steepson @dail
            Can you tell me or better show a screenshot where exactly i got to do that? Because looks like it disabled now.
            • dailD
              dail
              Settings > Preferences > Backup > Enable session snapshot and periodic backups
              • stabker steepsonS
                @dail well… periodic backups were always disabled for me, so this is not a reason. Only session snapshot is enabled.
                • stabker steepsonS
                  stabker steepson
                  At least two other people have confirmed this bug.
                  • stabker steepsonS
                    stabker steepson
                    I taped a bit of coding process and here what i got https://www.youtube.com/watch?v=Y-obRpiFlcQ
                    This thing happened to me for a few times today…
                    • stabker steepsonS
                      stabker steepson @gstavi
                      @gstavi Hey.
                      I deleted all plugins except NppExec. Guess what i got today? Watch this video https://www.youtube.com/watch?v=bZB2cRFAAHY
                      So… will it be fixed?
                      • dailD
                        dail
                        @stabker-steepson
                        As I said before make sure to turn off session snapshot.
                        Here is a reproducible test case for this bug:
                        1. Open a file from disc
                        2. Clone the file to the other view
                        3. Make sure “Remember Current Session” is enabled
                        4. Make sure “Session snapshot and periodic backup” is enabled
                        5. Leave the file in an unsaved state
                        6. Restart N++
                        7. Observe that the files are no longer in “sync” when they are edited
                        Note: If at step 4 “Session snapshot and periodic backup” is disabled, the everything works fine.
                        stabker steepsonS 1 Reply Last reply Reply Quote 1
                        • stabker steepsonS
                          @dail thx, seems like you’re right. I have been disabled all items and everything is alright.
