    want Edge not IE in RUN - Launch
    8 Posts 5 Posters 5.5k Views
    • Dave DunlavyD
      Dave Dunlavy
      One of the choices on the Run tab is Launch in IE. I’d like to Launch in Edge. How do I change it? or add another choice so I choose Edge? Thank you in advance.
      • Scott SumnerS
        Scott Sumner @Dave Dunlavy
        @Dave-Dunlavy
        The Run menu stuff is located in the shortcuts.xml file. Follow the pattern for the other entries there.
        • Dave DunlavyD
          Dave Dunlavy
          Thanks Scott, Found the file but don’t understand how to “address” the Edge program. Found where edge is in the System Apps but the .exe file doesn’t run. Appreciate the try but am giving up.
            Claudia Frank @Dave Dunlavy
            @Dave-Dunlavy
            Edge is, what MS calls a, modern app which means it needs to be started under
            some kine of context like the explorer. This basically means you cannot start the exe
            for itself. What you can try to do is to use a command shell or tools like RunEdge.exe
            to make it work.
            • Casey CrockettC
              Casey Crockett
              This worked from the Run (F5) menu option for me.
              microsoft-edge:http://www.google.com
                Claudia Frank @Casey Crockett
                @Casey-Crockett
                but this doesn’t work for files, I assume. Did you try that?
                Casey CrockettC 1 Reply Last reply Reply Quote 0
                • Casey CrockettC
                  Casey Crockett @Claudia Frank
                  @Claudia-Frank
                  Hmm. No, it doesn’t. Even if I copy and paste a URL for a file that I opened using Open With option from Windows Explorer context which has all the spaces and things converted to %20 and all that. I might try to look for that context menu entry in regedit some time to see if it is something usable.
                  • Jim Gerland243J
                    Jim Gerland243
                    This works for me:
                    1. Download the MicrosoftEdgeLauncher.exe from https://github.com/MicrosoftEdge/edge-launcher/releases/tag/1.0.0.0 to your C:\Program Files (x86) folder
                    2. Edit your C:/Users/<put your username here>/AppData/Roaming/Notepad++/shortcuts.xml file
                    3. In the <UserCommand> secton add this line:
                      <Command name=“Launch in Edge” Ctrl=“yes” Alt=“yes” Shift=“yes” Key=“83”>“C:\Program Files (x86)\MicrosoftEdgeLauncher.exe” "$(FULL_CURRENT_PATH)</Command>
                    4. Exit and reload Notepad++
                    5. Open an HTML file and try it.
                      Jim…
