    Help with Basic Regular Expression Search
    regex
    5 Posts 3 Posters 3.3k Views 2 Watching
    • Marshall MedoffM Offline
      Marshall Medoff
      OK, folks, I’ve never used regular expressions before and it’s high time I started.
      I’m trying to edit a large txt file that has text at the end of many lines that I want to completely remove. I was able to build a search expression to remove text (actually replace it with other text) at the beginning of the lines, but, removing the ending text is proving to be a bit more difficult. I’m sure there’s a way to do it via regexp but I’m not seeing it.
      Each of the lines I want to edit has the same text in the middle of the line. I want to remove that text and the rest of the text all the way to the end of the line, preserving the CR/LF.
      Any suggestions?
      Thanks in advance!
      Colby
      • 古旮古 Offline
        古旮
        You should describe your request more clearly, better give some examples. Then we’ll be easier to help you.
        • dailD Offline
          dail
          This is actually much more clear than most posts asking for regex help.
          You can use a regex like: some text.*?$
          The important part here is the .*?$ at the end which will match the text after “some text” all the way right up until it reaches the end of the line (which is what the $ represents).
          Keep in mind that if your “some text” has special characters in it such as a period, parenthesis, etc then you will need to escape the character.
            Marshall Medoff
            So Dail, that worked! Thank you!
            In the best Reddit practice, I upvoted your response, but, does this site have the equivalent of Karma or gold?
            Best to you and yours!
            Colby
            dailD 1 Reply Last reply Reply Quote 0
            • dailD Offline
              dail @Marshall Medoff
              @Marshall-Medoff
              I’m not really sure how the reddit system works. The reputation here doesn’t really have much value, I think mostly just to weed out spam accounts.
