    Notepad++ doesn't remember docked window position
    4 Posts 3 Posters 3.4k Views 2 Watching
    • Nathan GriffithsN Offline
      Nathan Griffiths
      Notepad++ doesn’t remember docked window position (Windows 7)
      I have used Metapad for years, and have just discovered Notepad++.
      Notepad++ is vastly superior, aside from a crucial difference in that Metapad remembers docked window position. So I have Metapad docked to right-hand side of screen at all times, which is remembered after closing and re-opening. This is very helpful when working with docked windows (which I always do), because theres a consistency. Chrome browser is another example, it always remembers the docked window position.
      Metapad was written in C++ and is open source (though no longer supported), here are the source files. I dont know anything of C++ language, but could this feature not be any easily transferred to Notepad++ ?
      • MAPJe71M Offline
        MAPJe71
        The docked position of Notepad++ in relation the Windows screen or any of the ‘dockable’ windows (e.g. Project panel) within Notepad++?
          Nathan Griffiths
          Sorry, in relation to the Windows screen.
          • Nathan Griffiths141N Offline
            Nathan Griffiths141
            I have solved my problem with DisplayFusion.
            A native fix would still be desirable.
