    Help needed :) Automate deleting number and spacing
    5 Posts 4 Posters 3.1k Views 2 Watching
    • Nazrulsyah Firaz Fauzee AndylimN Offline
      Hi,
      I have files with the below format. FYI, there is a spacing between ‘2’ and '10:00:01:00 ', it is some sort induced by the ‘Tab’ key.
      2 10:00:01:00 10:00:02:07
      When I was a child,
      How can I change it to this format without having to do it manually?
      When I was a child,
      I really appreciate your advise and assistance! Thanking you in advance :)
      • Claudia FrankC Offline
        Claudia Frank @Nazrulsyah Firaz Fauzee Andylim
        @Nazrulsyah-Firaz-Fauzee-Andylim
        What does mean automate in this context?
        You open the file and it should magically disappear?
        You wanna click a button/execute a script?
        Anything else?
        There are several solutions I can think of.
        1. Record a macro which puts the cursor into the start of the line, press
          delete twice, move cursor to the next line - done - save macro and run it multiple times.
        2. Use search and replace with a regex like
          ^\d+\s+
        keep replace field empty press replace.
        3) Use column mode by pressing left ALT key and select the columns to be removed,
        press delete.
        4) …
        If non of these answer the question, please be more specific what you want and
        how data could look like.
          Thank you Claudia. Allow me to rephrase my query.
          These files are in TXT format and I want to have it either in TXT or SRT as the final format.
          The original TXT file looks like this.
          When I was a child,
          This is how I want it to look like.
          When I was a child,
          I have 62 files to work on and I am not that sure how to do it in the fastest way. Btw, I tried using your #2 suggestion (regex), but it did not work. I am using Mac.
            FIND = ^\d\s+(\d+:)
            REPLACE = \1
            Input:
            1 10:18:75 20:17:21
            blah blah
            blah blah
            2 11:13:55.555  12:13:14
            one
            3 11:16:21 15:22:34,356
            more than one
            line in the SRT
            goes here
            Output
            10:18:75 20:17:21
            blah blah
            blah blah
            one
            more than one
            line in the SRT
            goes here
            But if you happen to have text in your caption that looks like a number followed by the time,
            2 10:15:16 10:20:30
            normal caption
            And my song goes
            1 1:21 in the afternoon,
            even though that's a silly song
            … it will also match the “1 1:21” and change it to “1:21”. If that’s a remote possibility for your captions, @-mention guy038, and ask him how to modify my regex to require either beginning of file or a blank line followed by my regex. I know such things are possible in regex (using lookbehinds, etc), I’m just not that good.
            • guy038G Offline
              Hello Nazrulsyah Firaz Fauzee Andylim, Peter Jones and All
              If I fully understand the problem, your first line begins with one or more digits, followed by any spacing, followed by two time values, each of them, separated by a space and written with the template HH:MM:SS:CC ( CC = hundredth of second , from 00 to 99 )
              And you would like to delete the first number, at beginning of each line, containing the templates HH:MM:SS:CC, on 62 files, wouldn’t you ? If so :
              • Backup your 62 TXT files, as the same 62 SRT files ( IMPORTANT )
              • Open the Find in files dialog ( Ctrl + Shift + F )
              • In the Find What : zone, type ^\d+\h+(?=\d\d:\d\d:\d\d:\d\d)
              • Leave the Replace with : zone EMPTY
              • In the Filters zone, type *.SRT
              • In the Directory zone, type the absolute location of these 62 SRT files
              • Uncheck, if necessary, the In all sub-folders and In hidden folders options
              • Click on the Replace in Files button and click on the OK button to valid that S/R
              Et voilà !
              Remark : If anything goes wrong, NO panic : just, delete the 62 SRT files, as you STILL get the 62 original TXT files :-)
              For instance, from the text below :
              2 15:25:23:80 15:25:25:37
              Blah, blah
              Blah, blah
              Blah, blah
              7     10:00:01:00 10:00:02:07
              When I was a child, I used to go,
              2 times per week, to Mr Parker's work-shop
              to contemplate, with fascination, all the
              automatons, build by the old man. More than
              1 hundred, with their sparkling colours, lay
              on numerous shelves...
              11 03:07:59:77 03:08:01:13
              more than one
              line in the SRT
              goes here
              you would obtain, the replaced text below :
              Blah, blah
              Blah, blah
              Blah, blah
              more than one
              line in the SRT
              goes here
              Notes :
              • Only, the three numbers 2, 7 and 11, at beginning of lines, and the following spacing characters, are deleted
              • Luckily, the lines, which begin with a number, but not followed by a template, of the form HH:MM:SS:CC, remain unchanged !
              • From beginning of line ( ^ ), the regex engine looks for a non null range of digits ( \d+ ), followed by some non null spacing characters ( \h+ ).
              • Then, due to the syntax (?=\d\d:\d\d:\d\d:\d\d), named a positive look-ahead, the regex engine, verifies that, at cursor position, a time value, with the template HH:MM:SS:CC can be found. If so, the overall regex matches that initial number and the spacing, after it.
              • And, as the Replace zone is EMPTY, it’s , simply, deleted, from the file’s contents
              P.S. :
              BTW, are my two sentences, at middle of the text, looks like “fair” English prose ?!
