    Notepad+ 7.2 (32bit) Installation of Tidy2 (v 0.2) fails.
    2 Posts 1 Posters 8.1k Views
    • Syamala TadigadapaS
      Syamala Tadigadapa
      I have even removed the notepad++ and reinstalled and tried afresh. same issue.
      Any idea how to get over with this problem?
        Syamala Tadigadapa
        At https://sourceforge.net/p/notepad-plus/discussion/482781/thread/2eeba3f3/ I found a solution. I have downloaded the zip file https://github.com/downloads/davegb3/NppTidy2/Tidy2_0.2.zip. Expanding this zip folder has Tidy2.dll. I copied this Tidy2.dll file to C:\Program Files (x86)\Notepad++\plugins. Then I verified that this plug in is showing up in the nodepad++ menu.
        But I am interested to know 1. why it fails to install as a plugin from notepad++ menu? 2. Is there a solution than the above hack I mentioned?
