    RegEx Replace button doesn't work as expected with a look-behind.
    5 Posts 4 Posters 3.3k Views
    • Joe FurlongJ
      Joe Furlong
      Today I found that when using the “Replace” button when using a positive lookahead and a capture group Notepad++ doesn’t replace anything. It only iterates through like “Find Next”.
      For example in the Changelog for the latest version If I wanted to remove the new lines between all the plugin versions with a regex.
      Excerpt from Changelog to remove newline characters:
      1. NppExport v0.2.8
      2. Plugin Manager 1.3.5
      3. Converter 3.0
      4. Mime Tool 1.9
        use the regex: (?<=.\d)(\r\n)
        Set the replace with as a space or comma.
      If I press “Replace All” the replace works on all 4 lines as expected. But, if I just try the “Replace” no replacements are made.
      If I don’t use a lookahead the “Replace” button works as expected.
      Is there a reason for this behavior?
        Hello Joe,
        The behaviour of the N++ regex engine is quite bugged, if your regex contains “backward” assertions, as \A or look-behind, as (?<=xxx) and also if you use the \K syntax . In that case, the step by step replacement, with the Replace button, will NEVER work :-(( Therefore, you must use the Replace All button, exclusively !
        Just note that “forward” assertions, as \z and positive or negative look-ahead, as (?=xxxx) or (?!xxxx), work fine and that the use of the Replace button is effective !
        BTW, many thanks to you for your regex, as a reply to greg marshall. Refer to the address, below :
        https://notepad-plus-plus.org/community/topic/12362/duplicate-rows-according-to-whats-in-a-column/4
        Indeed, it helped me to find out a general regex, to get all the work done, in one go !
        • Scott SumnerS
          Scott Sumner
          Reading this posting, it strikes me that perhaps the title should be
          “RegEx Replace button doesn’t work as expected with a look-behind.”
          rather than
          “RegEx Replace button doesn’t work as expected with a positive lookahead.”
          • Joe FurlongJ
            Joe Furlong
            Scott,
            You are correct on the title of the post. I posted too late, and did mean the look-behind as you mentioned. When i tried to edit the post, I was given an error stating it can only be edited withing 180 seconds. I’ll poke around a bit, and see if I have any luck to correct the title.
            Guy038 thanks for the response. I did notice that other regex did appear to work. Was curious why the look behind didn’t work.
            Thanks again.
            Joe–
            • dailD
              dail
              Title updated.
