    [vi simulator] how to highlight a word
    55 Posts 5 Posters 64.4k Views
    • bycn82 bbbbB
      bycn82 bbbb
      I am trying to enhance my visimulator plugin, when I am searching the text with “/abc” or “?abc”, I want to highlight the matched words. i want to the effect to be exactly same as highlighting when double clicking on the word.
      Currently I only noticed SCI_COLOURISE. any advice?
      Regards,
      • dailD
        dail
        SCI_COLOURISE is to have the lexer (e.g. C++, HTML, JavaScript, etc) re-parse and determine styles.
        What you would want are indicators. This is what N++ uses for its smart highlighting. They are fairly easy to use and give you a wide range of options. Keep in mind Notepad++ uses a handful of indicators itself so make sure not to accidentally reuse ones already in use.
        • bycn82 bbbbB
          bycn82 bbbb
          I just find a way to highlight a word, but I met another issue.
          After I highlight a word, and I notice it did not automatically clear when I double click on another word.
          • dailD
            dail
            There’s nothing “automatic” about it, you have to manually handle everything. See: SCI_INDICATORCLEARRANGE
            • bycn82 bbbbB
              bycn82 bbbb
              I thought it will be cleaned automatically if I use the same indicator as the one used when double clicked
              • dailD
                dail
                I guess in theory if you use the same indicator number then it should be cleared but I can’t say for certain. What indicator number are you using? Maybe provide an example/code of what you are trying to do?
                • bycn82 bbbbB
                  bycn82 bbbb
                  SendMessage(nppData._scintillaMainHandle, SCI_INDICSETFORE,INDICATOR_CURRENT, 0x00FF00); // green #00d000 SendMessage(nppData._scintillaMainHandle, SCI_INDICSETALPHA, INDICATOR_CURRENT, 100); SendMessage(nppData._scintillaMainHandle, SCI_INDICSETSTYLE,INDICATOR_CURRENT, INDIC_ROUNDBOX); SendMessage(nppData._scintillaMainHandle, SCI_SETINDICATORCURRENT, INDICATOR_CURRENT, 0); SendMessage(nppData._scintillaMainHandle, SCI_INDICATORFILLRANGE,5, 7);
                  and I tried to set the value of indicator_current to 31 and 27. and hoping it will be automatically cleaned when double clicked on an word.
                  • dailD
                    dail
                    Notepad++ uses 29 for its smart highlighting.
                    • bycn82 bbbbB
                      bycn82 bbbb
                      Is it possible to invoke the npp’s methods?
                      I was thinking why I need to reinvent the wheel.
                      e.g. How can I call the find function? I did not find any sample about it, is it possible?
                      • dailD
                        dail
                        In some cases yes but in this case no.
                        Luckily it is a small wheel.
                        Here is the Notepad++ code that does the smarthighlighting. Unfortunately it isn’t as simple as copy/paste.
                        If you want to see a “leaner” version of how to do something similar to smarthighlighting take at this Lua code. This isn’t perfect but works under alot of circumstances. You can even incorporate some of the things Notepad++ is doing as well. I understand you are writing it in C but most of the lines of Lua translates into a single line of C.
                        For example something like:
                        editor.FirstVisibleLine
                        Is equivalent to:
                        SendMessage(nppData._scintillaMainHandle, SCI_GETFIRSTVISIBLELINE, 0, 0);
                        The one caveat being editor:findtext() which you can take a look at SCI_FINDTEXT
                        • bycn82 bbbbB
                          bycn82 bbbb
                          Anyway! I will just use the Ctrl+F3.
                          Don’t have much time to work on a editor plugin.
                          I use command line for most of time.
                          • Scott SumnerS
                            Scott Sumner @dail
                            Hi dail, I took a look at the code found at the link you provided, and although I don’t use Luascript with Notepad++ I think I can follow the logic well-enough. Knowing Pythonscript and how the callback mechanism works there, it appears your intent in this code is to fire it off every time an “update UI” event is generated. The problem is (and again I’m thinking of my Pythonscript familiarity) I think that the code itself will cause more of those “update UI” events to be generated, thus spiraling somewhat out of control (at least while the caret is on a “word”), calling your callback many many times. Am I missing something here?
                            dailD 1 Reply Last reply Reply Quote 1
                            • dailD
                              dail @Scott Sumner
                              Hi @Scott-Sumner
                              That is actually a really good question. I’ve always gone under the assumption that it doesn’t fire off another “updateUI” event.
                              Looking at the Scintilla documentation for SCN_UPDATEUI states:
                              Either the text or styling of the document has changed or the selection range or scroll position has changed.
                              Note: “style” is separate from “indicators”
                              There are separate notifications when indicators have changes (i.e. SCN_MODIFIED). If you take a look at the Notepad++ source code you will also see that it does the “highlighting” during the SCN_UPDATEUI event. See this line of code
                              So it appears that doing this is safe.
                              • Scott SumnerS
                                Scott Sumner @dail
                                @dail
                                So for some fun I ported the code to Pythonscript on my lunch break. Due to limited time, I left out the callback stuff, and am just putting the caret on a word and running the script and seeing all occurrences in the currently visible window of the editor tab become highlighted. However, I have another script that tells me which callbacks are happening (I run that first). When I invoke the “highlight” script, I see MODIFIED callbacks occur with SC_PERFORMED_USER | SC_MOD_CHANGEINDICATOR flags set (which seems correct), but I also see UPDATEUI callbacks occurring as well, after the MODIFIED ones. Thus this leads me back to suspecting that it would just generate something of a big callback loop if actually set up as part of a UPDATEUI callback; I’ll try that out soon.
                                  Claudia Frank @Scott Sumner
                                  @Scott-Sumner
                                  Hi Scott,
                                  dail is correct, as long as you take care that your callback function doesn’t generate ui updates it is save to use.
                                  I’m using it in my updated regextester script for some weeks now without a problem.
                                  • Scott SumnerS
                                    Scott Sumner
                                    So last night I actually tried it out with it installed as an update-ui callback. After installation, putting the caret inside a word results in the FIRST occurrence of that word flashing rapidly. It seems like what I feared would happen is actually happening–something in itself is triggering multiple re-calling of the callback, and it is clearing and setting the indicator over and over.
                                    Maybe there is something wrong with my Pythonscript port of this code; it is short enough so I have included it below. Perhaps someone can see a deficiency? I see dail used “return False” a few places in the original code; I never heard of a callback returning a boolean; however I included it in the port (along with some “else” placements which would permit removing the return statements without affecting functionality).
                                    Anyway, here’s the code:
                                    INDICATOR_TO_USE = 12
                                    editor1.indicSetStyle(INDICATOR_TO_USE, INDICATORSTYLE.ROUNDBOX)
                                    editor2.indicSetStyle(INDICATOR_TO_USE, INDICATORSTYLE.ROUNDBOX)
                                    editor1.indicSetAlpha(INDICATOR_TO_USE, 55)
                                    editor2.indicSetAlpha(INDICATOR_TO_USE, 55)
                                    editor1.indicSetOutlineAlpha(INDICATOR_TO_USE, 255)
                                    editor2.indicSetOutlineAlpha(INDICATOR_TO_USE, 255)
                                    def callback_sci_UPDATEUI(args):
                                    	def getRangeOnScreen():
                                    		firstLine = editor.getFirstVisibleLine()
                                    		lastLine = firstLine + editor.linesOnScreen()
                                    		startPos = editor.positionFromLine(firstLine)
                                    		endPos = editor.getLineEndPosition(lastLine)
                                    		return (startPos, endPos)
                                    	def clearIndicatorOnScreen():
                                    		(s, e) = getRangeOnScreen()
                                    		editor.indicatorClearRange(s, e - s)
                                    	editor.setIndicatorCurrent(INDICATOR_TO_USE)
                                    	if not editor.getSelectionEmpty():
                                    		return False
                                    	else:
                                    		startWord = editor.wordStartPosition(editor.getCurrentPos(), True)
                                    		endWord = editor.wordEndPosition(startWord, True)
                                    		if startWord == endWord:
                                    			return False
                                    		else:
                                    			word = editor.getTextRange(startWord, endWord)
                                    			(startPos, endPos) = getRangeOnScreen()
                                    			temp = editor.findText(FINDOPTION.WHOLEWORD | FINDOPTION.MATCHCASE, startPos, endPos, word)
                                    			while temp != None:
                                    				(s, e) = temp
                                    				editor.indicatorFillRange(s, e - s)
                                    				temp = editor.findText(FINDOPTION.WHOLEWORD | FINDOPTION.MATCHCASE, e, endPos, word)
                                    editor.callback(callback_sci_UPDATEUI, [SCINTILLANOTIFICATION.UPDATEUI])
                                    • dailD
                                      dail
                                      This is some interesting results. If I get some time I will play around with it as well with Lua. It is odd you are getting this behavior. The example Lua I posted I’ve been using for months just fine. It might be worth looking a bit more into the Notepad++ “smarthilighter” since it does pretty much the same thing but works fine.
                                      This is purely a LuaScript thing. (It doesn’t actually do anything but I recommend returning false from a LuaScript callback for forwards-compatibility reasons).
                                      There is one other caveat to keep in mind. PythonScript callbacks are asynchronous (whereas LuaScript callbacks are purely synchronous). Not sure if this is affecting anything but definitely worth keeping in mind.
                                      • Scott SumnerS
                                        Scott Sumner
                                        The Pythonscript docs say that I can use editor.callbackSync() to make it synchronous, but then it goes on to say that if I do that, I can’t call editor.findText(), which this script uses. :(
                                          Hello Scott,
                                          you are right, using asynchronous callback leads to the update flickering.
                                          I’m not quite sure why this happens.
                                          I’m using the synchronous callback together with the research function and this
                                          seems to work well. Your code would look like
                                          import re
                                              print 'callback_sci_UPDATEUI'
                                              def match_found(m):
                                                  editor.indicatorFillRange(m.span(0)[0], m.span(0)[1] - m.span(0)[0])
                                                  print 'getRangeOnScreen'
                                                  print 'clearIndicatorOnScreen'
                                                  return False
                                              else:
                                                      return False
                                                  else:
                                                      print 'word:{}'.format(word)
                                                      # temp = editor.findText(FINDOPTION.WHOLEWORD | FINDOPTION.MATCHCASE, startPos, endPos, word)
                                                      editor.research(word, match_found, re.IGNORECASE)
                                                      # while temp != None:
                                                          # (s, e) = temp
                                                          # editor.indicatorFillRange(s, e - s)
                                                          # temp = editor.findText(FINDOPTION.WHOLEWORD | FINDOPTION.MATCHCASE, e, endPos, word)
                                          editor.callbackSync(callback_sci_UPDATEUI, [SCINTILLANOTIFICATION.UPDATEUI])
                                          I know you could have done this yourself but thought …
                                          • dailD
                                            dail
                                            I’m not familiar enough with the internal Scintilla code but I think it is making sure it doesn’t get stuck in one of these types of loops. I added a bit of extra code to my plugin to log exactly when notifications are getting received. It shows when it enters and leaves the notifications. As shown below, it enters the SCN_UPDATEUI, at which point it calls my Lua callback which adds 3 indicators, thus the 3 SCN_MODIFIED pairs, then leaves the SCN_UPDATEUI notification.
                                            ->SCN_UPDATEUI
                                            ->SCN_MODIFIED
                                            <-SCN_MODIFIED
                                            ->SCN_MODIFIED
                                            <-SCN_MODIFIED
                                            ->SCN_MODIFIED
                                            <-SCN_MODIFIED
                                            <-SCN_UPDATEUI
                                            I would say between this and the fact that @Claudia-Frank successfully used the synchronous callbacks, means that your code was receiving these notifications out of order due to the asynchronous callbacks (which is a problem I ran into with the PythonScript a while ago).
