Wrong unicode character display for Sinhala Language
I am using notepad++ for my research and collecting large set of Sinhala sentences to build a language model of Sinhala. I just want to type sinhala characters ඍ (unicode 0D8D) and ඎ (0D8E) characters in the editor and copy paste sentences with those characters. Editor is not rendering those characters properly and display them as පෘ and පෲ . When I copy them from the notpad++ editor and put it in windows notepad it correctly displays the character in notepad. Can somebody help me to solve this rendering issue it is much appreciated.
Hello Malinda Punchimudiyanse,
From the official web site of the Unicode Consortium, below :
http://www.unicode.org/charts/
We can get a PDF list of all the Sinhala characters, in the range
[\x{0D80}-\x{0DFF}], from the link, below :http://www.unicode.org/charts/PDF/U0D80.pdf
It’s easy to verify that :
The Unicode value
0D8Dcorresponds to the SINHALA LETTER IRUYANNA ඍ ( = sinhala letter vocalic r ) -
The Unicode value
0D8Ecorresponds to the SINHALA LETTER IRUUYANNA ඎ ( = sinhala letter vocalic rr )
which are, both,
independentvowelsAnd, you’ll also notice that :
- The Unicode value
0DB4corresponds to the SINHALA LETTER ALPAPRAANA PAYANNA ප ( = sinhala letter pa )
which is a
consonantFinally, you’ll remark that :
The Unicode value
0DD8corresponds to the SINHALA VOWEL SIGN GAETTA-PILLA ෘ ( = sinhala vowel sign vocalic r ) -
The Unicode value
0DF2corresponds to the SINHALA VOWEL SIGN DIGA GAETTA-PILLA ෲ ( = sinhala vowel sign vocalic rr )
with a type, different as the above characters, as they are, both, dependent vowel signs
Unfortunately, as I’m French and, as I, absolutely, not used to Asiatic languages, I cannot deduce anything valuable, from these facts :-(( Hope that these tiny hints will make sense, for you !!
Note that you can search for, any of your alphabet character, with the syntax
\x{0Dhh}( where lowercasehstands for an hexdecimal digit )BTW, which encoding do you use ? Look at the right part of the bottom status bar
Also, what is your current font name ?
- Open the menu option Settings - Style Configurator…
- Select the Global Styles language
- Select the Default Style style
- See the current font name, on the right, in the Font style zone
P.S. :
Beware ! The glyphs of the two additional dependent vowel signs, (
\x{0DF2}and\x{0DF3}) in the PDF file, are reversed :-(( -
