i know this must seem simple but i need help with regex (formula)
 I need a formula to find the value of Energy from say 100.0000 and change it to say 999.0000 http://www.filedropper.com/example1 file Is above, If needed.
 ok…nevermind, I finally figured out a crude formula Energy \K.+(?= ) it knocks some spaces out in middle of the lines…but it seems to load up and work for me anyway…I really need help with my other post though… https://notepad-plus-plus.org/community/topic/12129/need-help-with# really HAVE to have help with that issue…
 ok … turns out I was wrong about my crude formula, it doesn’t seem to pick up every energy value ;( … back to square one on this one…need a easy fix…what did I do wrong, what better way is there?
 Ok figured that one out as well…thanks all that helped over these few months
