code block trigger string doesnt work when first character is ";"
any workaround? my compiler uses ; for comments so making this work would help. my other option is enclose the trigger string into .comment and .endc. tags :/ any help would be much appreciatd. thanks in advance guys. :)
sorry don’t understand your question?
Could you clarify it? Maybe with a screenshot?Cheers
Claudia -
you can define what string you want to use for code folding, you can define what string will trigger the start of a foldable block and what will be the end of it.
if this string starts with “;” then the “+” sign for folding never appears.
so for example “codeblockstart” works but “;clodeblockstart” doesnt.
so you talking about udl, do you?
If so, did you try semicolon followed by a space as folding in comment line open chars?
Seems to work.Cheers
Claudia -
yes, this is for a user defined language. tried now with space still doesnt work. what version you have ? I have v6.9.2. on win 8.1.
btw a few years ago this worked
P PeterJones referenced this topic on
Future Readers,
As mentioned in a 2023 follow-on conversation:
the “problem” was because
;was defined as the start of a comment for comment-highlighting. The UDL parser doesn’t look for Fold in code 1 or Fold in code 2 keywords for folding when they are contained in Comment lines. Instead, if;is defined as the start-of-comment-line in the Comment & Number tab, then on the Folder & Default tab, you can define Folding in comment’s open/close pair, and that will allow a special keyword pair to work for folding using comments to start and end the folding. This is true in 2023’s v8.5.3, and this was true in 2016’s v6.9.2.Follow-up discussion on this should go in the follow-on conversation rather than in this ancient conversation, which is being locked.
P PeterJones locked this topic on
