    Uncomment selection using "ctrl+alt+shift+R" does not work. Taking to some other page in web explorer.
    3 Posts 3 Posters 2.9k Views
    • Ankita DeshmukhA
      Ankita Deshmukh
      Uncomment selection using “ctrl+alt+shift+R” does not work.
      When commented using short cut for comment selection “ctrl+alt+shift+C”.
      • Mayuri DengaleM
        Mayuri Dengale
        Hey Ankita,
        I am also facing same problem with notepad ++… :( :(
        But there is a strong workaround available , you can use “ctrl+shift+Q” for Comment selection and “ctrl+shift+K” to Uncomment selection.
        • gerdb42G
          gerdb42
          CTRL-ALT-SHIFT-Rand CTRL-ALT-SHIFT-C are defined by the XML Tools plugin to do XML(!) commenting and uncommenting.
          Unfortunately CTRL-ALT-SHIFT-R is also bound to the run command “Launch in Chrome” which takes precedence over the plugin-command.
          Also unfortunately NPP does not detect and warn about multiple shortcut assignments. So you need to check your shortcut settings and adjust them to your liking.
