    Help with search function
    hellosearch
    3 Posts 2 Posters 2.5k Views
    • Hakan VenderlofH
      Hakan Venderlof
      Hello
      I have some problem with the search function in notepad.
      Quite often when i try to find a word, for example “menu”
      the word is not found although its in the textfile in
      several places.
      Is there any place i can check the settings
      for the search function?
      Greetings Hakan
      http://zdubair.com.se/))
      • Jim DaileyJ
        Jim Dailey
        <Ctrl>+f should open the find dialog. Make sure you have not accidentally told NPP to search back/up. I did that once and was sure the editor was broken. I always keep wrap around enabled to I avoid this possibility.
        Also, pay attention to the ignore case, find whole word, and use regular expression settings which can sometimes cause unexpected results.
        • Hakan VenderlofH
          Hakan Venderlof
          Thanx :-)
