    Multi selection and multi edit
    multiline
    64 Posts 18 Posters 219.7k Views
    • Chandler NewbyC
      Chandler Newby
      I know I can use multi-edit in the following ways:
      • Select something, then hold CTRL and select something else.
      • Hold ALT+SHIFT and use the arrow keys to select multiple lines.
      • Hold ALT and click and drag the mouse to select a block.
      But what I really, really want to be able to do is:
      • Select some text, then hit a keyboard shortcut to find the next copy of that text, and select it along with the first.
      Sublime and Atom do this with CTRL+D. That same shortcut probably won’t work, but the feature would be wonderful.
      Claudia FrankC donhoD 2 Replies Last reply Reply Quote 2
        Claudia Frank @Chandler Newby
        Hello @Chandler-Newby,
        I do have a python script which more or less (because I don’t know what sublime does) does what you want.
        It has 3 modes,
        • replace
        • insert before
        • insert afterwards
        To make this work you need to install the python script plugin (please use msi instead of plugin manager),
        create a new script and put the following into it. Assign a shortcut.
        # this script implements the multi cursor edit functionality
        editor.beginUndoAction()
        _text = editor.getSelText()
        if len(_text) != 0:
            _currentPosition = editor.getCurrentPos()
            _current_line = editor.lineFromPosition(_currentPosition)
            _end_Position = editor.getLength()
            _word_end_pos = 0
            _current_word_start_pos = editor.getLineSelStartPosition(_current_line)
            _current_word_end_pos = editor.getLineSelEndPosition(_current_line)
            incorrect_option = True
            while incorrect_option:
                result = notepad.prompt(' 0 = replace,  1 = before, 2 = afterwards', 'Choose the desired option', '0')
                if result in ['0','1','2']:
                    incorrect_option = False
            if result == '0':
                # replace whole string version
                editor.setEmptySelection(_currentPosition)
                while 1:
                    try:
                        _word_start_pos, _word_end_pos = editor.findText(0, _word_end_pos, _end_Position, _text)
                        if _word_end_pos != _currentPosition and _word_start_pos != _currentPosition:
                            editor.addSelection(_word_start_pos, _word_end_pos)
                    except TypeError, err:
                        break
            elif result == '1':
                # insert before selected string version
                editor.setEmptySelection(_current_word_start_pos)
                while 1:
                    try:
                            editor.addSelection(_word_start_pos, _word_start_pos)
                        else:
                            _current_word_start_pos, _current_word_end_pos = _word_start_pos, _word_start_pos
                        break
            elif result == '2':
                # insert after selected string version
                editor.setEmptySelection(_current_word_end_pos)
                while 1:
                    try:
                            editor.addSelection(_word_end_pos, _word_end_pos)
                        else:
                            _current_word_start_pos, _current_word_end_pos = _word_end_pos, _word_end_pos
                        break
            # now add the current selection
            editor.addSelection(_current_word_start_pos, _current_word_end_pos)
        editor.endUndoAction()
        If you want to modify something in the script, let me know.
        ng khanhN 1 Reply Last reply Reply Quote 1
        • dailD
          dail
          Just FYI if/when Notepad++ updates to a newer version of Scintilla this capability will be built-in by default.
            Claudia Frank @dail
            @dail
            I would vote for an update ;-)
            • dailD
              dail
              Me too. Unfortunately it isn’t updated very often :(
              Vasile CarausV 1 Reply Last reply Reply Quote 0
                Claudia Frank
                Well I can understand as it is a critical component which can break npp I guess.
                But if there is something I can do, like comparing source code to see which functions
                have been modified etc., I would do it.
                • Chandler NewbyC
                  Chandler Newby
                  Thanks for the script @Claudia-Frank! It works well.
                  It sounds like an updated Scintilla is what we need. Is there any timeline on how often the dev updates the Scintilla version used?
                  • dailD
                    dail
                    The new version of Scintilla doesn’t really introduce anything that can’t be done currently with a plugin, it just makes it more convenient. Updates vary between a few months to a few years
                    I understand the caution updating Scintilla but it still seems like there are many advantages that could be taken with updating it more regularly. Don always takes care of updating it himself.
                      Hello Chandler Newby and All,
                      Presently, with current versions of N++, to get the SAME result, you need to perform the five steps below :
                      • Place the cursor, JUST BEFORE the text to search for :
                      • Perform the menu option Edit - Begin/End Select
                      • Select your text ( either a character, a word or a several words string )
                      • Perform the menu option Search - Select and Find Next or use the CTRL + F3 shortcut
                      IMPORTANT : you may run this command several times to get the Nth occurrence of your selected text
                      • Perform, again, the menu option Edit - Begin/End Select
                      => All the area, between the FIRST occurrence of the selected text, included, till the LAST occurrence found, included, is, then, selected
                      Et voilà !
                      • ng khanhN
                        ng khanh @Claudia Frank
                        @Claudia-Frank : Thanks for your script. How need to change if i want to set the range of find and modfication : from line 10 to line 100, it would be best if we can select instead of line number input
                        • Scott SumnerS
                          Scott Sumner @ng khanh
                          @ng-khanh
                          The biggest issue with your desired change is how to specify the range of lines you want to limit it to functioning over. As you said, entering actual line numbers is not ideal (although that would work, and could easily be set in the “prompt” box along with the 0, 1, 2 choice).
                          How about the placement of two bookmarks, one on the first line and one on the last line? This presumes that you currently aren’t using bookmarks for something else when you want to invoke this functionality.
                            Claudia Frank
                            Bookmarks is nice because than it can be used with F2 to jump to.
                            Another, possible way, could be that only the visible area gets changed or
                            if you select the first and the last (by holding ctrl) and everything in between,
                            together with the selected once, get replaced.
                            Or we try to extend it so it does all of this.
                            So with a prompt like
                            a = all, b = bookmarks, s = selected, v = visible,
                            So 0a would mean replace all occurrences and 1b would
                            be insert before selected word within bookmared lines etc…
                              Claudia Frank
                              Below the modified script.
                              Some words to explain its functionality.
                              If you run the script you will be asked for some options,
                              namely the area which should be used and the mode what to do.
                              Mode is either
                              • 0=replace
                              • 1=insert before
                              • 2=insert after
                              Area is either
                              • a=all lines
                              • b=position enclosed by two bookmarks
                              • s=position enclosed by two selected words
                              • v=lines in the view which are currently visible
                              So if one defines 0a it means every occurrence of the selected word gets overwritten with the current word
                              If one chooses 1b then only the selected words within the bookmarks, which are needed to be set first, get modified by
                              inserting the typed chars before the words.
                              2v would mean add additional chars to the end of the selected words, but only for those who are currently visible.
                              Well, this is not exactly true, it means that text gets added to every selected item from first visible line
                              including the last visible line.
                              Example:
                              Line 1-20 is visible
                              Line 21-30 is hidden
                              Line 31-40 is visible
                              Line 41-… exist but is out of view aka non-visible
                              If one selects area v then the words in the lines 21-30 get considered(modified/replaced) too.
                              Area s can only be used if settings->preferences->editing->Multi-Editing has been enabled.
                              Last but not least, there is a variable find_flag which is set to WHOLEWORD per default.
                              If one once to have no restriction set it to 0 or any other value stated in the comment.
                              That’s it.
                              # this script implements the enhanced multi cursor edit functionality
                              def default_positions():
                                  return 0, editor.getLength()
                              def get_pos_of_bookmarks():
                                  npp_bookmark_marker_id_number = 24
                                  npp_bookmark_marker_mask = 1 << npp_bookmark_marker_id_number
                                  _start_position, _end_position = default_positions()
                                  line_nbr = editor.markerNext(_start_position, npp_bookmark_marker_mask)
                                  if line_nbr != -1:
                                      _start_position = editor.positionFromLine(line_nbr)
                                      line_nbr = editor.markerNext(line_nbr + 1, npp_bookmark_marker_mask)
                                      if line_nbr != -1:
                                          _end_position = editor.getLineEndPosition(line_nbr)
                                  return _start_position, _end_position
                              def get_pos_of_visible_lines():
                                  first_visible_line = editor.getFirstVisibleLine()
                                  _start_position = editor.positionFromLine(first_visible_line)
                                  lines_visible = editor.linesOnScreen()
                                  last_visible_line = editor.docLineFromVisible(first_visible_line+lines_visible)
                                  _end_position = editor.getLineEndPosition(last_visible_line)
                              def get_pos_of_selections():
                                  if editor.getSelections() == 2:
                                      _start_position = editor.getSelectionNStart(0)
                                      _end_position = editor.getSelectionNEnd(1)
                              area_dict = {'a':default_positions,
                                           'b':get_pos_of_bookmarks,
                                           's':get_pos_of_selections,
                                           'v':get_pos_of_visible_lines}
                              _text = editor.getTextRange(editor.getSelectionNStart(0), editor.getSelectionNEnd(0))
                              if len(_text) != 0:
                                  _current_position = editor.getCurrentPos()
                                  _current_line = editor.lineFromPosition(_current_position)
                                  find_flag = 2 # 0=DEFAULT, 2=WHOLEWORD 4=MATCHCASE 6=WHOLEWORD | MATCHCASE
                                  mode_options = ' 0=replace,  1=before,  2=afterwards\n'
                                  area_options = ' a=all, b=bookmarks, s=selected, v=visible'
                                  expected_results = [x+y for x in ['0','1','2'] for y in ['a','b','s','v']]
                                  result = notepad.prompt(mode_options + area_options, 'Choose the desired option', '0a')
                                  while result not in expected_results:
                                  chosen_mode, chosen_area = result
                                  area_start_position, area_end_position = area_dict[chosen_area]()
                                  if chosen_mode == '0': # replace whole string version
                                      editor.setEmptySelection(_current_position)
                                      position_tuple = editor.findText(find_flag, area_start_position, area_end_position, _text)
                                      while position_tuple is not None:
                                          if _current_position not in position_tuple:
                                              editor.addSelection(*position_tuple)
                                          position_tuple = editor.findText(find_flag, position_tuple[1], area_end_position, _text)
                                  elif chosen_mode == '1': # insert before selected string version
                                          startpos, endpos = position_tuple
                                          if startpos != _current_position and endpos != _current_position:
                                              editor.addSelection(startpos, startpos)
                                          else:
                                              _current_word_start_pos, _current_word_end_pos = startpos, startpos
                                          position_tuple = editor.findText(find_flag, endpos, area_end_position, _text)
                                  elif chosen_mode == '2': # insert after selected string version
                                              editor.addSelection(endpos, endpos)
                                          else:
                                              _current_word_start_pos, _current_word_end_pos = endpos, endpos
                                Hi, Claudia,
                                Until your recent script, I didn’t interfere, in that discussion, because I thought that a simple S/R, in regex mode, was enough to get the same behaviour. Indeed :
                                • For Replacement : SEARCH = "Searched word" and REPLACEMENT = "Replacement word"
                                • For Insertion before : SEARCH = "Searched word" and REPLACEMENT = "Added word${0}"
                                • For Insertion after : SEARCH = "Searched word" and REPLACEMENT = "${0}Added word"
                                But, your last script, with the different area options, shows, clearly, the advantages of a script ;-)) Your script should satisfy everyone !
                                However, I just noticed a minor bug : if you start the script by mistake, and that you want to stop it, the Cancel button does NOT work. So, the only choice is the Yes button !
                                BTW, if your file is quite important, it can take some seconds, before all the matches are highlighted !!
                                • Vasile CarausV
                                  Vasile Caraus @dail
                                  @dail
                                  agree
                                    Claudia Frank @guy038
                                    @guy038
                                    there is no need for a stop routine as it is a per one time execution script - no callbacks.
                                    You run the script and all it does is to select the different instances of the selected word.
                                    Once everything has been selected it finishes instantly.
                                    You are right, it hasn’t optimized for speed but I think it doesn’t make sense to edit
                                    a huge file and use this little helper to replace all occurrences of a string. Npps
                                    builtin feature is much faster in this way.
                                    • Scott SumnerS
                                      Scott Sumner @Claudia Frank
                                      @Claudia-Frank
                                      I think what @guy038 meant was, what if you start the script running, get the prompt dialog box on the screen, and then change your mind and decide you don’t want to do what you started after all.
                                        Claudia Frank @Scott Sumner
                                        @Scott-Sumner
                                        ahh - ok - yes correct - but just press ok and move cursor.
                                        Nothing changed.
                                          Claudia Frank
                                          finally I understand - the cancel button !! phew – need a cup of coffee!
                                            Claudia Frank
                                            cancel button fix
                                                if line_nbr != -1:
                                                    if line_nbr != -1:
                                            def Main():
                                                if len(_text) != 0:
                                                        if result is None:
                                                            return
                                                            else:
                                                            else:
                                            Main()
