Need some Help with Filtering out my Text
 I have a screenshot here: http://prntscr.com/9sqct4
 I want to remove everything that comes before “|” as well as the “|” itself. Or keep everything that has http:// and after.
 I’m very new to notepad ++ and would love some help on this issue! Thank you :)
 Hello Aaron-Miller open replace dialog and put the following into find what: (.+|)(?=http.*)leave replace with empty.
 Select Regular expression in Search mode and press replace all.
 Keep a copy of the original data for safety ;-)What it does is .* look for every char until a | appears and if http follows, then make it a group
 to be reported back (known as match).As replace with hasn’t anything in it this group will be replacey with nothing. Hope this makes sense. Cheers
 ClaudiaBtw. I assume that | appears only once and directly before http
 I do understand. It worked. Thank you so much Claudia!
