Auto-completion dual monitor bug
 If i run notepad++ (full screen) on the left of my two monitors, and use “ctrl+alt+r” (right direction), the autocomplete shows up on the other monitor instead… Attached is a screenshot of the case:
 http://i.stack.imgur.com/bDjlT.jpgThanks,
 Hello wisemike2, currently I don’t have a dual monitor setup but I remember from the past that
 graphic manager software, especially nvidia nview, made some trouble.
 Could this be in your case as well?Cheers
 I do have NVIDIA GeForce GT 610. Any suggestions or special settings to fix that?
 Do you have the nvidia specific manager software installed?
 I don’t talk about the driver, the software which allows you to manage
 multiple monitors formerly known as nview manager. If so,
 there was a possibility to disable the software and rerun the test.Cheers
