Miss position after switch between tabs
 Hi
 I have a problem with switching between tabs.
 If you switch between any tabs, cursor jump to ** 1:1** position!
 User miss the last position and programmer says hello!
 Hello Alireza-Abedini, checked on Win7 x64 npp 6.8.8. 4 tabs open
 tab1 -> cursor position line 100
 tab2 -> cursor position line 2
 tab3 -> cursor position line 12
 tab4 -> cursor position line 250rapidly switched the documents by clicking the tabs multiple times. ~ 50 times
 Cursor is still in the position where it was.Cheers
 There is a known issue with the XML Tools plugin. There is a certain option you can turn off but I can’t remember which one. I’d suggest updating the plugin.
 Hello, Alireza Abedini and dail, Indeed, this problem occurs, when the XML Tools plugin is installed, in your N++ configuration. Just refer to this old dail’s post : https://notepad-plus-plus.org/community/topic/33/return-to-same-line-when-switching-tabs/3 Best Regards guy038
 A BIG thanks for you and a I wish for you to upgrade to 39 as soon as possible ;)Best Regards,
 Alireza
