What standard for Regular Expressions is Notepad++ using?
 Hi,
 I have been using Notepad++ for occasional general editing for a couple of years, and find it very useful.I am starting to explore regular expressions but I have no reference for the regular expression terms or syntax. Can someone point me at a reference for the regular expressions used in Notepad++? My baseline for Regular Expressions is on Edit/1000 under RTE/A for HP Minicomputers (1985) and early HPUX, but nothing for the last 20 ish years as I only dabble in Unix/Linux … I saw the syntax change quickly in the early days but do not know if it has stabilised into a common format by now … Thanks,
 Tony.
 You will find an exhaustive discussion of the Notepad++ regular expression “flavor” here:
 https://notepad-plus-plus.org/community/topic/9703/is-it-planned-to-switch-to-pcre2Perhaps that contains a deeper treatment than you want/need. Basically N++ currently uses the BOOST implementation, and these TWO links, which are buried in the above link, are very helpful in understanding Notepad++'s regexes: SEARCHING:
 http://www.boost.org/doc/libs/1_55_0/libs/regex/doc/html/boost_regex/syntax/perl_syntax.htmlREPLACING:
 http://www.boost.org/doc/libs/1_55_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
 Hi Scott, Thanks for the help. I have all my editting done except for deleting lines. From the command line I would use something like:
 1$f/^“”/,d
 to search the file, find all occurrences of 2 quotes at the start of a line, and then delete that line. Repeat until end of file.I cannot see if there is a facility to drop into a command line, nor can I find a delete option in the Search/Replace menu. Can you tell me what I am missing? Thanks,
 Tony
 Hello Tony, You can get this action, by two means, with Notepad++ : -
by performing a simple Search and Replace operation, in regular expression mode
by deleting all the bookmarked lines, which contain two double quotes, at the beginning of each line
 First method : -
Open the Replace dialog ( CTRL + H )
SEARCH ^"".*\R
REPLACE Nothing
Check the Wrap around option
Check the Regular expression search mode ( Important )
UNCHECK the .matches newline option, if necessary
Click on the Replace All button
 Notes : -
^is an assertion, that represents the location between the last EOL character of the previous line and the first character of the current line
.*then matches the rest of the line, after the two double quotes
\Rstands for any kind of EOL characters (\r\n, for Windows files,\n, for Unix files or\rfor old Mac files )
As the replacement zone is empty, then, the entire lines, containing "", at beginning of lines are deleted
 Second method : -
Open the Mark dialog ( Menu Search - Mark… )
SEARCH ^""
Check the Bookmark line option
Click on the Mark All button
Select the menu option Search - Bookmark - Cut Bookmark Lines
 Best Regards, guy038
 Hi guy038, I had used part of your first example - I used search for ^“”, but missed the rest of the line. Using the complete expression worked fine. Many thanks, Tony
