NppCrypt doesn't work!
 Hi all!
 I’ve got a strange situation. I need to decrypt some text file and have installed (by Plugin Manager) plugin NppCrypt , but it doesn’t work! There are no windows when I call this plugin! Works only menu option “Settings” and nothing more. Can anybody tell me what’s the problem?
 I’ve read here http://www.addictivetips.com/windows-tips/nppcrypt-notepad-plugin-to-encrypt-decrypt-files-selected-text/ how must works this plugin. And even I’ve installed ver.5.9.5 as used in that text. But result is the same: plugin doesn’t work.P.S. Excuse please for my English, but I think it better than Google Translate. :)
 Hello Дмитрий Мощнов, P.S. Excuse please for my English, but I think it better than Google Translate. :) absolutely agreed - I think google translate is good if you try to understand
 but not if you try to say something.The problem sounds like you didn’t select any text, did you? Cheers
