Need help about encoding UTF-8 without BOM
 Why my notepad ++ don’t have encoding UTF-8 without BOM? How to add this encoding to my notepad ++
 Hi, from my understanding this is the default in npp.
 Check was is set using menu Settings->Preferences->New DocumentCheers
 Hello lala lolo, BTW, this introduction sounds quite well, to my ears :-)) Well, starting with the 6.8.1 N++ version, the UNICODE entries, of the Encoding menu, have been slightly changed ! -
The Encode in / Convert to UTF-8 without BOM entry is changed into Encode in / Convert to UTF-8
The Encode in / Convert to UTF-8 entry is changed into Encode in / Convert to UTF-8 BOM
The Encode in / Convert to UCS-2 Big Endian entry is changed into Encode in / Convert to UCS-2 BE BOM
The Encode in / Convert to UCS-2 Little Endian entry is changed into Encode in / Convert to UCS-2 LE BOM
 However, theirs functionalities are quite identical ! Best Regards, guy038
