    RegEx Help with Backreference I think
    58 Posts 4 Posters 6.1k Views
    • Robert Or Janet DiebelR
      Robert Or Janet Diebel @guy038
        @guy038 The MACRO reverses line order.
        I can maybe get the changes done with a number of simpler RegEx’s run after the fact, but I would prefer it totally automated if possible.
        Another alternative is to separate the Numbered books and have a separate RegEx to run against them that would allow a number and {space}
          Hi , @robert-or-janet-diebel,
          Oh… How silly I am ! You’re perfectly right. At first sight, I do not remark this important line, beginning your BookAndVerse macro :
                      <Action type="2" message="0" wParam="42083" lParam="0" sParam="" />
          So, instead of using the ^\u[\u\l -]+ part, for the name, we can use, either, the regexes :
          • ^\w[\w'’ -]+
          or
          • ^[[:alnum:]][[:alnum:]'’ -]+ IF no LOW LINE character ( \x{005F} ) occurs in the name
          Within these two regexes, I also added the two apostrophe syntaxes ['’]. If you do not need them, don’t add them in the character class !
          So, given this example, below :
          My very-Best-Novel
          1 Samwele
          5 L'été de tous les dangers
          5 L’été de tous les dangers
          1_ te_ST
          • The first regex ^\w[\w'’ -]+ would match the five lines above
          • The second regex ^[[:alnum:]][[:alnum:]'’ -]+ would match the first four lines, only
          Thus, If we take the general case, you must change, in your Step 2, the search regex as below :
          • FIND (?-is)\\v (?=(?s:.+?^(\w[\w'’ -]+ \d+$)))
          Robert Or Janet DiebelR 4 Replies Last reply Reply Quote 0
            @guy038 I am so very thankful for your help.
            Sorry I forgot to point out the line order reversal.
            I will give it a try!
            All the best to you and yours.
              @guy038 That is working great! I am so thankful!
              Dare I mention my last failing MACRO that should change the {space} after the Book-Chapter:verse to a TAB?
              Same issue, it works if there is no number.
              I will try to figure it out, but if you have any guidance, it would be appreciated.
                      <Macro name="Space2Tab" Ctrl="no" Alt="no" Shift="no" Key="0">
                          <Action type="3" message="1601" wParam="0" lParam="0" sParam="^(\w+\s\d+:\d+)\s(.*)$" />
                          <Action type="3" message="1602" wParam="0" lParam="0" sParam="$1\t$2" />
                          <Action type="3" message="1702" wParam="0" lParam="512" sParam="" />
                      </Macro>
                @guy038 Got my space-to-tab working.
                Thanx for all your help!
                  @guy038 Spoke too soon. Got it to change numbered book, then failed on non-numbered.
                  I am still working on it.
                    Hello, @robert-or-janet-diebel,
                    I suppose that the following regex S/R should work :
                    • FIND ^([\w ]+\x20\d+:\d+)\x20
                    • REPLACE $1\t
                    Robert Or Janet DiebelR 2 Replies Last reply Reply Quote 0
                      @guy038 This works on numbered, but not unnumbered.
                      Here is what I tried.
                      ^(\d+?\s?\w+\s\d+:\d+)\s(.*)$
                      It worked on numbered, but not unnumbered
                      I thought the “?” would make it optional.
                        @guy038 Sorry, that does work. I somehow slipped in a space before the RegEx in the MACRO
