    changing font not working in v8.6 (but changing size and color does work)
    25 Posts 11 Posters 21.5k Views 4 Watching
    • bennetthaseltonB Offline
      bennetthaselton
      I am using Notepad++ 8.6 (full debug info below). When I try to change font in Settings->Style Configurator->Global Styles->Default Style, and I changed the font to “FixedSys” (or anything else), the font selection appears to have no effect – the font stays the same. Oddly, when I change the foreground color and the size, those do have an effect, but not changing the font.
      Here you can see where I’ve changed the font to FixedSys, the color to blue and the size to 24:
      and here is a screen shot of the resulting text; you can see the size and the color changed, but the font is definitely not “FixedSys” (the l’s and the m’s are different width):
      Is this a bug?
      Full debug info:
      Notepad++ v8.6 (64-bit)
      Build time : Nov 23 2023 - 16:58:44
      Command Line :
      OS Version : 22H2
      OS Build : 22621.2861
      Plugins :
      mimeTools (2.9)
      NppConverter (4.5)
      NppTextFX (1.4.1)
      T S 2 Replies Last reply Reply Quote 1
      • T Offline
        Terry R @bennetthaselton
        @bennetthaselton
        Show us an image of your Global Styles: Global override panel. I suspect you have enabled some features which will “override” the default style.
        Here’s my panel:
        bennetthaseltonB 1 Reply Last reply Reply Quote 2
        • S Offline
          supasillyass @bennetthaselton
          @bennetthaselton Have you got DirectWrite enabled? (Bitmap fonts are not supported by DirectWrite.)
          bennetthaseltonB 1 Reply Last reply Reply Quote 1
            bennetthaselton @Terry R
            @Terry-R Here are my “Global override” settings. I had the same hunch as you so I tried setting font to Fixedsys here too but it didn’t work. (And note foreground color, background color, and size are still following what is specified in the Default style dialog, not here.)
              bennetthaselton @supasillyass
              @supasillyass assume this is a setting that’s enabled/disabled in Windows, how do I enable/disable it? I googled it but couldn’t find any info about how to tell if I have DirectWrite enabled, or how to turn it on/off.
              S 1 Reply Last reply Reply Quote 0
              • S Offline
                @bennetthaselton Notepad++ Preferences > MISC. > Use DirectWrite
                bennetthaseltonB 1 Reply Last reply Reply Quote 0
                  @supasillyass OK yes, turning off DirectWrite (and restarting Notepad++ as required) fixed the problem.
                  Also, in Notepad++ 8.5.8 DirectWrite was disabled by default so I didn’t run into this issue, but in Notepad 8.6 it is enabled by default.
                  (OK now the problem is solved for me, so it’s up to the devs if they want to try to “solve” it for other users, but – not sure what would be the best way to prevent other users from running into this problem. Perhaps when you switch to a font that is a bitmap font, Notepad++ checks if DirectWrite is enabled and alerts the user that they have to disable DirectWrite if they want to use that font?)
                  Alan KilbornA PeterJonesP 2 Replies Last reply Reply Quote 1
                    Alan Kilborn @bennetthaselton
                    @bennetthaselton said in changing font not working in v8.6 (but changing size and color does work):
                    If Notepad++ devs got deep into all of the potential peculiarities of font issues, they could probably spend all of their time there. Better to expend their efforts on real text editing functionality!
                      PeterJones @bennetthaselton
                      Encourage them to not use fonts that are 40 years old? Bitmap font technology was big in the 80s, but even Microsoft supported True Type fonts starting in Windows 3.1 in 1992.
                      Fixedsys was a bitmap font released in 1985, and used as the default font for Microsoft Notepad through the Windows ME era (~2000). After that, even MS started defaulting to a non-bitmap font (Lucida Console) as the default, due to the superiority of non-bitmap formats for fonts.
                      The fact that Windows still allows people to use bitmap fonts at all in Win 11 and beyond is the extraordinary thing, not the fact that many Windows features (including Direct Write) no longer support using 1980s font technology.
                      mkupperM bennetthaseltonB 2 Replies Last reply Reply Quote 1
                      • mkupperM Offline
                        mkupper @PeterJones
                        @PeterJones said in changing font not working in v8.6 (but changing size and color does work):
                        Yesterday I got a lot of satisfaction out of using a cold chisel and a hammer to deal with a problem that others, using high tech tools, were straining and struggling with all their might to solve. :-)
                        Thank you though as I was wondering why DirectWrite sometimes fails and why for a long time Notepad++ did not make it the default.
                          bennetthaselton @PeterJones
                          @PeterJones well it’s not just FixedSys, the same bug repros with more than half of the available fonts on my system.
                          Enable DirectWrite (and restart if not already enabled), type some text in Notepad++, then go to Global Styles->Default Style, and hit the down arrow keyboard key in the “Font name” dropdown to iterate through the available choices. (The selection takes effect instantly, without having to do Save & Close.) On my system, more than half of the font selections have no effect.
                          Alan KilbornA S 2 Replies Last reply Reply Quote 0
                            Tried this test using N++ 8.6 on a very-lightly customized Win11 Pro. And Notepad++ changed the font every time.
                            • S Offline
                              Most of those are probably not monospaced fonts anyway. You should still have a good selection of nice looking monospaced fonts to choose from or download some more. Or just disable DirectWrite, but it does have other benefits.
                                @supasillyass thanks. I’m not trying to solve the problem for myself now though (I can use FixedSys if I disable DirectWrite), I’m just trying to narrow down the bug in case anyone wants to fix it.
                                  bennetthaselton @Alan Kilborn
                                  @Alan-Kilborn Well now I’m wondering what the pattern is :)
                                  Trying a clump of six fonts that appeared alphabetically in the list, and picking each one, these are the selections that had an effect:
                                  Eras Medium ITC - no
                                  Felix Titling - yes
                                  Fixedsys - no
                                  Footlight MT Light - no
                                  Forte - yes
                                  Franklin Gothic Book - no
                                  Out of the four that didn’t work, presumably they’re not all bitmap fonts (I don’t know much about this, but for all of them except Fixedsys, Control Panel says they are TrueType fonts, which means they are vector fonts and not bitmap, right?). So at least on my system, it’s not just bitmap fonts that it doesn’t work for.
                                  Alan KilbornA T 2 Replies Last reply Reply Quote 0
                                    @bennetthaselton
                                    Well, further experimentation has given me one odd bit:
                                    I looked for the fonts you listed (Eras … Franklin) and I only have Fixedsys. I have Franklin Gothic Medium, so I changed from Fixedsys to that (FGM). The odd thing is that for that change, I saw no change in Notepad++ rendering, i.e., after changing to FGM, it still appears as if I was using Fixedsys.
                                    In short: No ideas. :-)
                                    dr ramaanandD 1 Reply Last reply Reply Quote 0
                                    • dr ramaanandD Offline
                                      dr ramaanand @Alan Kilborn
                                      @Alan-Kilborn @Terry-R @PeterJones @bennetthaselton @guy038 or anybody else, so using these, can I change the color, font or size of just one of the many lines in my file? I want one line to stand out and look different, permanently (that is, even if I switch off the laptop/desktop, the changes should remain the next time I open and see that file).
                                      dr ramaanandD Alan KilbornA 2 Replies Last reply Reply Quote 0
                                        dr ramaanand @dr ramaanand
                                        @dr-ramaanand I was able to change the background color by clicking settings, selecting Global Styles, then Selected text colour, clicking on background color and selecting a different background color. Now I will switch off my system to check if it is a permanent change.
                                          @dr-ramaanand it looks like that changes the background color of whatever is selected. Now, how do I change the background color of a line (when there are multiple lines) permanently? If that is not possible, please let me know how to make a line or two stand out permanently (those lines should stand out and look different, permanently, that is, even if I switch off the laptop/desktop, the changes should remain as they are, the next time I open and see that file)
                                            Alan Kilborn @dr ramaanand
                                            @dr-ramaanand said in changing font not working in v8.6 (but changing size and color does work):
                                            It can’t reasonably be done, and in fact, it isn’t a reasonable expectation for a text editor.
                                            See HERE for further info.
                                            dr ramaanandD 1 Reply Last reply Reply Quote 1
