    Project plugin functionality
    22 Posts 5 Posters 8.2k Views 2 Watching
    • General CoderG Offline
      General Coder
      Well I’ve learned reading the treeview is not an easy task especially if you are using C#.
      So I would like to forget it. But what about the functions list in notepad++, can you somehow use that? And can you allow jump to function definition via context menu. I should probably make a new thread about this…
      • PeterJonesP Online
        PeterJones @General Coder
        @General-Coder said in Project plugin functionality:
        Don’t bother.
        Nope. The Function List panel also does not have any messages for a plugin to call, so once again, you would be using the generic Win32 API calls – and IIRC, it’s a TreeView as well, so there’s no benefit of trying to access that over trying the Project or FolderAsWorkspace.
          General Coder
          What about my own context menu entry (that calls my C# function) or custom hovering tooltip type display, are those possible?
          PeterJonesP EkopalypseE 2 Replies Last reply Reply Quote 0
            @General-Coder ,
            I am sure such are possible. I think they are probably done with standard Win32 API calls, but I don’t know for sure. I know that some of the other regulars here have done their own popups and such, so hopefully someone else will be able to give you pointers as where to go next.
            • EkopalypseE Offline
              Ekopalypse @General Coder
              @General-Coder
              If it is the context menu that opens in the Scintilla area, then it is editable via Settings->Edit Popup ContextMenu. See here. But if you’re thinking of having it in other dialogs like FAW, Project Panel, or third-party plugins like NppExec, then you’ll need to subclass the appropriate window message queue and catch the messages you’re interested in, do your own thing, and let the main message handler know that this was done to prevent the main action from being executed.
                General Coder
                I have put my own entry to the context menu via xml but now would like to do that via C# plugin. Is this possible?
                The link you gave me brings up security warning (which is why I haven’t been reading those docs)
                I’m also wondering if it’s possible to use windows form under notepad++ process or do I have to use np++ own window creation commands?
                I was able to create the form but it’s in independent process.
                mkupperM EkopalypseE 2 Replies Last reply Reply Quote 0
                • mkupperM Offline
                  mkupper @General Coder
                  This has been fixed and so https://npp-user-manual.org/docs/config-files/#the-context-menu-contextmenu-xml should now be viewable.
                    … now would like to do that via C# plugin. Is this possible?
                    Yes, you need to subclass the wndproc …
                    … possible to use windows form under notepad++
                    Even though I’m not a C# developer, I can say that yes, you can.
                    The .Net framework is basically a wrapper around the Win32 API.
                    You just need to make sure that you pass the expected values to Npp.
                      General Coder
                      couple questions
                      how do you center the view on line? I used SciMsg.SCI_GOTOLINE to go to the line but it doesn’t center the view
                      also is it possible to get the text under the cursor? i can get selection but this one I havent figured out yet
                      thx
                        Alan Kilborn @General Coder
                        couple questions
                        What you are asking about are some Scintilla functions.
                        The Scintilla docs are HERE.
                          General Coder
                          hey, thx I’m aware of the scintilla docs but they are pain to read so i thought I’d ask scintilla experts here.
                          that’s where I found the SCI_GOTOLINE ;)
                            Nobody here wants to spoon-feed you. Sorry.
