    functionlist problem
    22 Posts 4 Posters 8.5k Views 3 Watching
    • Andrea DottaA Offline
      Andrea Dotta
      Why functionlist doesn’t recognize vbs file. npp ver. 7.9.5 and later…
      thanks!
      • PeterJonesP Online
        PeterJones @Andrea Dotta
        @Andrea-Dotta ,
        Because no one has created a functionList definition for VBScript / Visual Basic and submitted it to the Notepad++ repository. The developers aren’t necessarily experts in all 80+ languages listed in the Languages menu; for the languages that they don’t actively use, they have to rely on active users of that language to define what’s the best combination of class and function definitions to make a reasonable Function List definition for the language
        If you created vb.xml and put it in the functionList\ , you would have your own Function List definition that works for you. And if you get it working really well, you could even try to submit it to the Notepad++ repository
        UserManual Links on Function List:
        • https://npp-user-manual.org/docs/function-list/
        • https://npp-user-manual.org/docs/config-files/#function-list
        Addendum: the discussion Function list does not Work With VBS-files / VB-Files shows some example vb.xml files that might work for you. I especially recommend trying the first of the two in this post by @guy038 near the end of that discussion.
        • Michael VincentM Offline
          Michael Vincent @PeterJones
          @PeterJones said in functionlist problem:
          @Andrea-Dotta
          The one I use, heavily adapted / ported from @MAPJe71 language repo:
          “Notepad++\functionList\vb.xml”
          |   link:
          <NotepadPlus>
          	<functionList>
                  <parser
                      displayName="Visual Basic (.NET|Script|for Applications)"
                      id         ="vb_function"
                      commentExpr="(?m:((?<=').*?$)|((?i:REM)([\t ].*?)?$))"
                      <classRange
                          mainExpr="(?s:(?<SCOPE>(?i:CLASS|TYPE)).*?(?i:END[\t ]\k<SCOPE>))"
                          displayMode="node" >
                          <className>
                              <nameExpr expr="(?i:CLASS|TYPE)[\t ]+(?:[A-Za-z_][\w]*\b)(?:.*?[\r\n])" />
                              <nameExpr expr="[\t ]+(?:[A-Za-z_][\w]*\b)" />
                              <nameExpr expr="[A-Za-z_][\w]*" />
                          </className>
                          <function
                              mainExpr="(?m:^[\t ]*(?i:(?:(?:PUBLIC|PRIVATE|PROTECTED|FRIEND|PROTECTED FRIEND)[\t ]+)?(?:(?:STATIC|SHARED|SHADOWS|OVERRIDABLE|OVERRIDES|READONLY|WRITEONLY)[\t ]+)?(?:SUB|FUNCTION|PROPERTY)).*?(?:\(|$))" >
                              <functionName>
                                  <funcNameExpr expr="(?i:(?:(?:PUBLIC|PRIVATE|PROTECTED|FRIEND|PROTECTED FRIEND)[\t ]+)?(?:STATIC[\t ]+)?(?:SUB|FUNCTION|PROPERTY)).*?(?:\(|$)"/>
                                  <funcNameExpr expr="(?i:(?:SUB|FUNCTION|PROPERTY)).*?(?:\(|$)"/>
                                  <funcNameExpr expr="(?i:(?:GET|LET|SET)[\t ]+)?[A-Za-z_][\w]*(?=[\t ]*\(|$)"/>
                              </functionName>
                          </function>
                      </classRange>
                      <function
                          mainExpr="^[\t ]*(?i:(?:(?:PUBLIC|PRIVATE|PROTECTED|FRIEND|PROTECTED FRIEND)[\t ]+)?(?:(?:STATIC|(?:DECLARE(?:[\t ]+(ANSI|UNICODE|AUTO))?))[\t ]+)?(?:SUB|FUNCTION|PROPERTY)).*?(?:\(|$)"
                          displayMode="$functionName">
                          <functionName>
                              <nameExpr expr="(?i:(?:(?:PUBLIC|PRIVATE|PROTECTED|FRIEND|PROTECTED FRIEND)[\t ]+)?(?:(?:STATIC|(?:DECLARE(?:[\t ]+(?:ANSI|UNICODE|AUTO))?))[\t ]+)?(?:SUB|FUNCTION|PROPERTY)).*?(?:\(|$)"/>
                              <nameExpr expr="(?i:(?:SUB|FUNCTION|PROPERTY)).*?(?:\(|$)"/>
                              <nameExpr expr="(?i:(?:GET|LET|SET)[\t ]+)?[A-Za-z_][\w]*(?i:[\t ]+(LIB|ALIAS)[\t ]+[\w"\.]+)*(?=[\t ]*\(|$)"/>
                          </functionName>
                      </function>
                  </parser>
          	</functionList>
          </NotepadPlus>
          NOTE: The above code has been updated to reflect the recommended changes by @PeterJones below.
          PeterJonesP Andrea DottaA 2 Replies Last reply Reply Quote 3
            PeterJones @Michael Vincent
            @Michael-Vincent ,
            I just did a compare between your modified vb.xml and the one that Guy fixed the regex for in the other discussion: you might consider on lines 29 and 39 using \(|$) instead of \(), to fix the bug that was mentioned in that previous discussion (for function definitions that don’t have parentheses)
              you might consider on lines 29 and 39 using (|$) instead of (), to fix the bug that was mentioned in that previous discussion (for function definitions that don’t have parentheses)
              Just tested - works! Not that I really ever use VB, but thanks for the update.
              Given the new post edit time limits, should I make the change to the post above so it’ll be “all-in-one” cut / paste (rendering our next 2 posts irrelevant)?
                @Michael-Vincent ,
                To make copy/paste easy, I would say change it (with an italic footnote)
                  Andrea Dotta @Michael Vincent
                  @Michael-Vincent Thanks Michael, I put the vb.xml file in the function list folder but when I open npp the function list window is empty. So I forget something?
                  Andrea DottaA 1 Reply Last reply Reply Quote 0
                    Andrea Dotta @Andrea Dotta
                    @Andrea-Dotta Ok. I tried to copy the second version in the https://community.notepad-plus-plus.org/post/64288 link and now it works!! There is something different into the code. but doesn’t matter.
                    Thanks a lot Peter and Michael!
                    swegmikeS 1 Reply Last reply Reply Quote 1
                    • swegmikeS Offline
                      swegmike @Andrea Dotta
                      Thanks. Can the updated vb.xml be sent in to be made part of the NPP install package? Is there a UDL file that goes with this?
                      I use VB6 and both would be useful.
                        PeterJones @swegmike
                        @swegmike said in functionlist problem:
                        If the owner of that functionList definition for VB decided to submit it to the NPP repo, it could be.
                        No. There is a built-in language for Visual Basic (Language > V > Visual Basic), so there is no need for a UDL (because the builtin lexers have more features available that the UDL cannot replicate).
                        One of the great things about the design philosophy of Notepad++ is that these config files are made as config files, so that you can configure these things yourself, or download from alternate sources, even if Notepad++ doesn’t distribute them in the installer. It’s a one-time action that you can take, based on what was talked about here, that will survive every update/upgrade on your current computer. So if you’ve already added it based on this discussion, you will have it even as Notepad++ continues to be updated – no extra work on your part.
                        swegmikeS 1 Reply Last reply Reply Quote 0
                        • swegmikeS Offline
                          swegmike @PeterJones
                          @PeterJones Sorry, I missed the VB in the language list. I wonder which VB version it supports i.e. VB6 or an older version. I guess one can run it against older versions to see what happens.
                            Probably a mix of versions, including VB6, VBA, VBScript, and similar. The syntax is all quite similar between those… at least similar enough that the essential parsing is probably all the same. (The same is true for C/C++: the same LexCPP source code is used for C, C++, Java, and JavaScript.)
                            That lexer is maintained in Scintilla’s Lexilla project; you might be able to dig into the history there if you want to know more about what versions they claim to support. But you can look at Notepad++'s defaul list of keywords for Visual Basic highlighting in Settings > Style Configurator > VB / VBS > WORD.
                            • swegmikeS Offline
                              @Michael Vincent
                              I copied your modified vb code above and used it against my simple vb program. It will work after the following fixes.
                              1. replace the < and > with &lt; and &gt;
                              commentExpr=“(?x)(?m:((?&lt;=').?$)|((?i:REM)([\t ].?)?$))”
                              mainExpr=“(?s:(?&lt;SCOPE&gt;(?i:CLASS|TYPE)).*?(?i:END[\t ]\k&lt;SCOPE&gt;))”
                              In functionname it complains that it is expecting whitespace.
                              2). remove the " that was in the statement below; otherwise, if the regular expression needs it change it to `&quot;`   I don't know how your regular expression is supposed to work for this step. Is it supposed to do the same thing as the class one that is similar?
                              <nameExpr expr= "(?x)(?i:(?:GET|LET|SET)[\t ]+)?[A-Za-z_][\w]*(?i:[\t ]+(LIB|ALIAS)[\t ]+[\w\.]+)*(?=[\t ]*\(|$)"/>
                              You may want to add (?x) after each expr name so that # comments can be added to document the code.
                              • swegmikeS Offline
                                swegmike @swegmike
                                @swegmike I’m not sure how to get the forum to show the xml equivalent with ampersand and name without it displaying the actual character. The website keeps flagging any variation as spam. For example an ampersand with gt and semicolon or ampersand with lt and semicolon or ampersand with quot and semicolon.
                                When it sees the ampersand symbol by itself it flags as spam.
                                When I use the code block it makes it worse.
                                Peter help fix it.
                                  For me, &lt; and &gt; and &quot; all work find in the forum.
                                  I think your initial was trying to say something like:
                                  commentExpr="(?x)(?m:((?<=').*?$)|((?i:REM)([\t ].*?)?$))"
                                  vs
                                  commentExpr="(?x)(?m:((?&lt;=').*?$)|((?i:REM)([\t ].*?)?$))"
                                    But when I tried to edit that find into fine after posting, the forum editor kindly turned the HTML escapes into the raw characters in the editor window, so I aborted the edit and changed to a reply. I was also going to add that putting markdown between backticks (like this: `&amp;` to render like this: &amp; … or, as I have above, `&lt;` and `&gt;` and `&quot;` to render as &lt; and &gt; and &quot;) works properly (as long as you aren’t editing your post again later).
                                    So now I think maybe your repeated edits were messing things up even more than whatever forum markdown you originally had.
                                    BTW: instead of using " in the regex embedded in XML to try to make the XML convert the entity into the actual character, I might recommend \x22 in the regex to match a literal quote.
                                    • swegmikeS Offline
                                      I think the ability to modify a post til it shows correctly needs to be fixed so that one doesn’t have to get it right on the first post. Some keys on this old company laptop don’t always work and must be redone. Moreover, the back tick comment that shows how to get the xml ampersand codes into a forum post isn’t in the FAQ. So I guessed alot.
                                      Af for the original VB code by mike vincent, there are errors such that npp doesn’t like " or < and > in the regular expression. Thus the vs. part of your post is the correct one for both amperand lt and ampersand gt along with the error in the functionname that has a ". When this is removed, NPP doesn’t complaain on save. Perhaps this was mike vincents typo or if it is needed the regexp needs fixing along with changing it to ampersan quot.
                                      The back ticks seem o work. need to add this to the FAQ.
                                        Where “isn’t in the FAQ” means “has a whole paragraph devoted just to that feature”. Look at https://community.notepad-plus-plus.org/topic/21925/faq-desk-formatting-forum-posts , especially the Red Typewriter Text section.
                                        • swegmikeS Offline
                                          @PeterJones The brief section talks about back ticks and there is some red typewriter text to; however, I wouldn’t have thought that it applied to the xml ampersand strings since I was looking specifically how to encode the ampersand strings. Perhaps you can add this as other examples pertaining to ampersand strings.
                                          I’ve fixed my post above to correct the vb functionlist parser errors to include the ampersand strings; however, mike vincent will need to chime in to say if the functioname required the double quote within the regexp and or fix the error by removing it or marking it as the xml ampersand quote along with any regexpresson processing fixes.
                                          • swegmikeS Offline
                                            swegmike @swegmike
                                            On a side question I have on the functionlist parser is
                                            that my dxl parser regexpression using regex101 tester can find and highlight the following function code. NPP using my regexp can find them to, but will not display the function name found completely, but only the first line for functions add1,2 and add5 to include its parameters.
                                            Is there a way to have the functionlist show multiple lines that describe a given function name with its parameters or where the regexp can manipulate the multiline into one for the functionlist to display it completely? I don’t think regexp in NPP allow me to replace the EOL at the end of the line with null and then stop when { found so that the multilines are joined into one line for display by functionlist.
                                            add0(){{}}
                                            int
                                            add1 (int a, int b
                                            	real add2
                                            	(int c_) {
                                            	return
                                            test
                                            real add3 (int d())
                                            int add4 (int &e[]) { return f }
                                            bool add5(array[] b,
                                                      int c, real d,
                                                      book e_
                                            Array add6 () {
                                            // overload tests with ::
                                            ::do( int a, Skip CP_KOR, 1.5e-04, 'A', "MIKE keyword", a <>)  { //
                                            string ::*(string s, int n) {
                                            :if(a ,b) {
