    Use of Python Script plugin to work with FORTRAN project
    21 Posts 4 Posters 3.7k Views
    • Arjan van DijkA
      Arjan van Dijk
      I would like to give Npp some basic IDE functionality for my FORTRAN projects. This means e.g. to run my compile script, to parse the runlog, search it for errors and focus the editor to the exact file, line and column of the first error. I have no experience in Python Script. I run Npp on Windows and my fortran projects are in MinGW/MSYS, where I use the gfortran compiler. Has anyone experience with something like this? And would he/she/they be inclined to share experience with me? Or is there a good set of example code that I can try? A tutorial? All I found so far was not very straightforward. Do I also need other plugins, like NppEventExec or NppExec (and what is their difference)?
        PeterJones @Arjan van Dijk
        @Arjan-van-Dijk ,
        NppExec vs NppEventExec: the NppEventExec is a helper which registers callbacks, but requires that NppExec be installed (as far as I understand; I personally use NppExec, but haven’t used NppEventExec to any serious extent).
        Syntax checking: I have a script for the PythonScript plugin which runs perl -c to check the syntax on my perl code every time I save. If there is a Fortran syntax checker, you could easily modify that script to call fortrancheck.exe or whatever it’s called.
        Compile: for compiling, I tend to use NppExec for that. For example, the following NppExec script will save the current file, compile it with GCC, and run the result:
        npp_save
        cd "$(CURRENT_DIRECTORY)"
        gcc "$(FILE_NAME)" -o "$(NAME_PART)"
        npp_run cmd.exe /k "$(NAME_PART)"
        The Plugins > NppExec > Console Output Filters > Highlight interface allows you to define strings that will parse out FILE, LINE, and CHARacter position from error strings in the NppExec console, and will highlight those error strings, and if you click on them, they will take you to the problem position in your source code. It comes preinstalled with filters that work for many C compilers. And you can edit them, or add your own. For example, I have added one to match perl’s die output, which is ERROR MESSAGE at FILEPATH line NNN… To match this, I have a filter * at %FILE% line %LINE% which colors the line red (FF, 00, 00). And if I got the message FakeError at c:\path\to\script.pl line 6 when I run my script, it will go to line 6 of that file if I double-click that line. These filters work for any text printed into the NppExec console, so if you run your compiler in NppExec, it can find compiler errors/warnings; and you run your program in that same window, it can also find runtime errors/warnings (assuming your language has that concept of printing such runtime messages to the console; given the age of FORTRAN, I am quite confident it does.)
        Arjan van DijkA 1 Reply Last reply Reply Quote 3
        • Arjan van DijkA
          Arjan van Dijk @PeterJones
          @PeterJones : This sounds promising, so I installed NppExec. I have some questions to get things started:
          Is there a way to just write and load/edit/save your own set of scripts directly, instead of copy/pasting them from an Npp text file into a menu window in Plugins > NppExec > Execute NppExec Scripts?
          I have my own utility getdeps.exe that gives a list of dependent source files based on the name of the source file of the main program. So
          getdeps.exe myprogram.f90
          will give a sorted list like e.g.
          libutil.f90 libmath.f90 libdatetime.f90 libmatrix.f90 myprogram.f90
          In the gnu shell, I use the following compile command:
          gfortran getdeps.exe myprogram.f90 -o myprogram.exe
          It seems as if NppExec does not like the construction with the reverse primes, which substitutes the result of the command in reverse primes into the reverse-prime delimited part of the main command. Can I do something similar here? Or should I first run the getdeps command on the main source file and then insert the resulting string in a second command that does compilation? How would I do this, i.e. put the result of
          into a string and then call
          gfortran “$(RESULT_STRING_OF_FIRST_STEP)” -o “$(NAME_PART)”
          And how would I glue extension .exe to the name of the executable? “$(NAME_PART)”.exe or “$(NAME_PART).exe” or “$(NAME_PART.exe)” ? The latter is probably wrong, but I have no clue about why use two types of delimiter in 1 expression (“” and ()).
            Alan Kilborn @Arjan van Dijk
            @Arjan-van-Dijk said in Use of Python Script plugin to work with FORTRAN project:
            I think you meant to include the “reverse primes” in what you showed:
            gfortran `getdeps.exe myprogram.f90` -o myprogram.exe
            but they got lost as they are also formatting characters on this site.
            BTW, I’ve never heard them called reverse-primes before, but I like it. :-) The correct terminology is grave-accent.
            Arjan van DijkA 1 Reply Last reply Reply Quote 0
            • Arjan van DijkA
              Arjan van Dijk @Alan Kilborn
              @Alan-Kilborn : A smile a day keeps the doctor away! So it will become a two-stage rocker then. How? I tried a simple command:
              getdeps.exe NuclideDecay01.f90 > tempfile
              but all the console says is:
              Process started (PID=20132) >>>
              <<< Process finished (PID=20132). (Exit code -1073741515)
              ================ READY ================
              There is no new file named tempfile. How to proceed?
                I never said that, but two steps makes sense.
                If I try a simple test NppExec script:
                cmd /c echo hello >hello123.txt
                then my NppExec console shows:
                Process started (PID=19720) >>>
                <<< Process finished (PID=19720). (Exit code 0)
                and I get a hello123.txt file in the same file as my Notepad++ .exe file. I’m using a portable version of N++, so I don’t know what happens with this example with the installed version.
                If I were you, I’d do a search of your file system for tempfile, or even better, put an absolute path on it in the script, e.g.:
                getdeps.exe NuclideDecay01.f90 >D:\tempfile
                and then see if the file is created in the known path.
                Otherwise, this definitely looks suspicious from your output:
                Arjan van DijkA 1 Reply Last reply Reply Quote 1
                • Arjan van DijkA
                  @Alan-Kilborn : Your example gave a nice file hello123.txt in the latest working directory, so this part works. I found out that part of my problem has to do with the MINGW/MSYS environment from which I generally work. When I call getdeps.exe from Windows, it misses a set of dll’s. I copied them to the same directory as getdeps.exe and now I get an exit code 0 from NppExec when I call getdeps from there.
                  But…
                  When getdeps.exe sees 1 arguement, it only returns the string with the filenames in order of dependency. When it sees 2 arguements, then it first gives debug info logging its intermediate steps finding the dependent files. With
                  getdeps.exe myprogram.f90 > tempfile
                  it considers
                  tempfile
                  as its second and third arguements for getdeps.exe… How can I tell NppExec that “> tempfile” is not part of the commandline arguements for getdeps.exe, but for the shell?
                    I’d try:
                    cmd /c getdeps.exe myprogram.f90 >tempfile
                    • Arjan van DijkA
                      @Alan-Kilborn This works. I get a nice file with the filenames.
                      Now how do I put the content of this file with sorted filenames into a string that I can offer to NppExec? Because when I call
                      gfortran tempfile
                      gfortran thinks that it has to compile tempfile as if it were a source file and not that it contains a list of source filenames…
                      Arjan van DijkA Alan KilbornA 2 Replies Last reply Reply Quote 0
                      • Arjan van DijkA
                        Arjan van Dijk @Arjan van Dijk
                        I tried
                        gfortran < tempfile
                        but that did not work…
                          Well, you’re sort of getting to the bottom of my knowledge about NppExec :-) so perhaps someone else could chime in, but…
                          You could try something like this; no idea if it will work for your exact case or not (worked for a simple trial I did as I don’t have your Fortran setup):
                          cmd /c getdeps.exe myprogram.f90 | clip
                          and then:
                          gfortran $(CLIPBOARD_TEXT) followed by the rest of your gfortran command line…
                          • Arjan van DijkA
                            The construction with the clipboard “does something”, but not completely what I want. To start, I just tried to call gfortran for the set of files listed on the clipboard, without any other option, not even the name of the executable, as there is always a default name. The NppExec line with the call to the compiler seems to get correct instructions from the clipboard, as the console tells me:
                            gfortran libxmath.f90 libutil.f90 libdate.f90 libexponential.f90 libinterval.f90 libtest.f90 test.f90
                            Process started (PID=7852) >>>
                            gfortran: error: test.f90
                            : Invalid argument
                            <<< Process finished (PID=7852). (Exit code 1)
                            But test.f90 is just a normal source file. When I run the same command from MINGW/MSYS, gfortran has no problems and produces a nice executable. How to proceed?
                            Arjan van DijkA Alan KilbornA 2 Replies Last reply Reply Quote 1
                            • Arjan van DijkA
                              Two decades ago, I wrote a set of macro’s that turned NEdit into a full IDE. And then they changed the macro language…
                                Relevance to the subject at hand?
                                  : Invalid argument
                                  How to proceed?
                                  Well, unknown, at least by me. Maybe someone else…
                                  Often such things are solved by continued experimentation by the one that has the specific tools that are giving trouble, i.e., you. :-)
                                  But I realize that you may only want to put a certain amount of effort in.
                                  • Arjan van DijkA
                                    @Alan-Kilborn: Just to demonstrate my level of ambition with this project. And therefore maybe boost your willingness to help.
                                      Well, it sounds like you have it. :-)
                                      It’s not about willingness; it is about ability, of which I’m tapped out on. :-(
                                      • Arjan van DijkA
                                        Thanks for helping me so far, the system at least does something now. I hope now some other expert steps in.
                                          @Arjan-van-Dijk
                                          You paste them in there once, and then hit Save…, and now NppExec has saved the script.
                                          Or you edit %AppData%\Notepad++\plugins\config\npes_saved.txt (which is where NppExec stores its saved scripts), and put the scripts in there. The name of each script is on the :: lines, so the script I showed you above is in npes_saved.txt as
                                          ::gcc-CompileAndRun
                                          NPP_SAVE
                                          gcc -o "$(NAME_PART)" "$(FILE_NAME)"
                                          $(NAME_PART)
                                          After editing npes_saved.txt manually, you will have to restart Notepad++ to get NppExec to see those scripts.
                                          Once you have the scripts in NppExec, if you don’t want to have to go select from the pulldown, you can use Plugins > NppExec > Advanced Options… to put individual scripts into the Macro menu. And once it’s in the Macro menu (and Notepad++ is restarted), you can use Settings > Shortcut Mapper to assign a keyboard shortcut to the script.
                                          Neither does cmd.exe. The “reverse primes” aka “backticks” aka “grave-accents” are a linux thing. I didn’t think they ever worked like that in the Windows environment: I’ve never had them work like that in cmd.exe, and I don’t use powershell enough to know whether they work there or not. Oh, right, you’ve mentioned MINGW/MSYS – Please understand that NppExec isn’t running in your MINGW/MSYS environment; it’s running in something much closer to cmd.exe. So you won’t get all the MINGW/MSYS magic automatically inside NppExec.
                                          As @Alan-Kilborn later said, it might end up in a different directory. There is a reason that nearly every one of my NppExec scripts has cd "$(CURRENT_DIRECTORY)" as one of the first couple lines… because I always want NppExec running relative to the file’s directory, not whatever directory it happens to start in (the notepad++.exe’s directory, or whatever directory the last script happened to leave me in).
                                          gfortran tempfile thinks that it has to compile tempfile as if it were a source file and not that it contains a list of source filenames…
                                          Does the gfortran executable have a command line option for “get the list of source names out of a file”? Many such commands do have that, and that would be the easiest method
                                          You need to figure out the exact sequence of events necessary to run your gfortran command from cmd.exe. Once you figure that out, using that series of commands in NppExec will usually work. Or, if you write a MINGW/MSYS-compatible script file or makefile, and have NppExec call that script or makefile using an appropriate command that launches the MINGW/MSYS environment. (I am not a MINGW/MSYS user, but I believe that they have a bash.exe or similar environment, IIRC. If so, then something like bash.exe fortran-bash-script.sh could be used to call it, or bash make myFortranProjectTargetName or whatever the right syntax is.)
                                          Also, just to confirm: are all of those .f90 files mentioned in the same directory?
                                          It would very much surprise me if there wasn’t a slightly more elegant way of getting the output. @Michael-Vincent is more of an expert in using the details of NppExec than I am, so maybe he’ll have a chance to chime in.
                                          Michael VincentM Alan KilbornA 2 Replies Last reply Reply Quote 1
                                            Michael Vincent @PeterJones
                                            @PeterJones said in Use of Python Script plugin to work with FORTRAN project:
                                            I think between you and @Alan-Kilborn , you got it covered. If I can’t get it work in NppExec, I try to make a Windows Batch file (.bat) do it. If I can get it to run in a batch file, I use NppExec to call the batch file with appropriate command line arguments and then do the Macro menu thing.
                                            For example, I have a Macro menu from NppExec called “Compile” and it “compiles” whatever is in Notepad++, be it Perl (perl -c), Python (pylint), C/C++ (msbuild or gcc depending on if there is a Makefile or .vcxproj or .sln file in an assigned project directory set as an NppExec global variable), JSON (jq), Yang, (pyang), YAML (yamllint -d relaxed), docker-compose… you get the picture. It got way to complicated to create all that logic in NppExec, so this is the NppExec “command”:
                                            ::compile
                                            NPP_CONSOLE on
                                            NPE_CONSOLE -- x+
                                            NPP_SAVE
                                            IF "$(ARGC)"<="1" THEN
                                                NPP_EXEC project check
                                            ENDIF
                                            "$(NPP_DIRECTORY)\plugins\NppExtTasks\NppExtTasks.bat" compile "$(FULL_CURRENT_PATH)"
                                            NPE_CONSOLE -- x-
                                            And the NppExtTasks.bat file does all the magic!
