    Problem with Margins in PythonScript Plugin and Margins in Distraction Free mode
    27 Posts 4 Posters 13.8k Views 2 Watching
      Alan Kilborn @Neko Nekokovic
      @Neko-Nekokovic
      Oh, wait, it appears I gave bad advice. The “Samples” are considered “machine scripts”. :-(
      Sorry, but I honestly don’t think about this much, because I don’t have such troubles…
      OK, so user scripts are under ...\Config\PythonScript\scripts (note the important part of that is “Config”).
      Machine scripts are NOT under Config.
      The only option I have is this
      So if “this” is a link to a screenshot, don’t do that, just Ctrl+v paste an image directly. Nobody is clicking links that aren’t immediately recognizable.
      But if I go Plugins > Python Script > Configuration every script that I see is under “Machine scripts” and none in “User scripts”.
      You have clicked on this, right?:
      Neko NekokovicN 2 Replies Last reply Reply Quote 0
        @Neko-Nekokovic said in Problem with Margins in PythonScript Plugin and Margins in Distraction Free mode:
        The thing that I’ve found in one of the above linked posts is this. This is exactly what I’ve want and it seems that someone managed to make it that way.
        Again, nobody is clicking on such a “this” link.
        Paste a screenshot right into your posting.
        But the thing that I don’t understand in this picture, or in that post is - A guy below said that it was a feature that was going to be available after v7.9.6 release. Do you know anything about it?
        I can’t answer questions deriving from links I’m not clicking on. :-)
        • Neko NekokovicN Offline
          Neko Nekokovic @Alan Kilborn
          Ah, okay.
          And that was from a post named “Is there a distraction-free writing mode like Vimroom(a plugin of Vim)?” on this website. So if you don’t want to click a link of it, you can go there and find this part.
            Yes. That’s what I meant when I said “User Scripts” is empty.
              Or YOU could have just provided this link.
              Neko NekokovicN 1 Reply Last reply Reply Quote 0
                Alan Kilborn @Alan Kilborn
                @Alan-Kilborn said in Problem with Margins in PythonScript Plugin and Margins in Distraction Free mode:
                That “guy” is the author of Notepad++. :-)
                Turns out after reviewing that other thread that he meant “Distraction free mode” would be available…and that made it into v8.0 (there was no v7.9.6).
                  I guess there is a misunderstanding here.
                  You’ve said earlier:
                  I understand that pictures should have been pasted as images, but either way you cannot know what is on the “link” no matter how I name it. You don’t know if it’s a link to a post or a link to an image. If you’re not clicking “this link” then why would I provide a link in the first place?
                  I guess you can have a preview when you hover over a link, but https://ibb.co/… is a popular domain as far as I know. I’ve seen it many times since many people link images from imgBB website and that is their domain. It’s quite popular so I don’t understand what was the problem.
                  I guess we don’t understand each other here.
                  Ah cool.
                  Oh only Distraction Free mode. :/
                  But in that post, the picture shows exactly what I want to achieve. I guess it is possible, I just don’t know how.
                    I think we do…
                    Yep, which is exactly how I know where links lead, no matter what they say, e.g. a blue/purple this.
                    And it is blocked by my I.T. department since it is so popular.
                    And since I do all of my Notepad++ work on my work PC, in my spare time at work, I can’t click on those links. Well, I can, but they won’t lead anywhere.
                    I think first things first…you need to get beyond problems with putting script files in user scripts folder and having them appear in the Notepad++ menus…are you beyond that?
                      I think we do…
                      Well we haven’t on this very issue then.
                      What does that mean? Which I.T. department? I don’t understand what that means. Why would a link from imgBB be banned or blocked?
                      Is there any other “imageToLink” website that isn’t blocked by anyone and that you would happily open even if it’s a picture in the link? What about Imgur? I’m curious now. I’ve never heard that someone blocks that website. Is there any specific reason? (Well I am sure there is, the question is rather - what is the reason behind the block?)
                      Yeah I agree. Well, no. I’ve managed to make them appear only if I put them in “Machine Scripts”. If I save them in Config/PythonScript/scripts nothing seems to show up.
                      I should fix that first definitely. I hope I’ll find a way. Currently I have no idea how to overcome that.
                      Alan KilbornA EkopalypseE 2 Replies Last reply Reply Quote 0
                        Umm, the one where I am employed?
                        To keep people from going there.
                        Imgur was used here before the forum software got the ability to directly paste images. So, yes, I could access that one.
                        But it is all kind of pointless, because we CAN paste here directly and there is no reason at all to user external sites for such things.
                        Neko NekokovicN 1 Reply Last reply Reply Quote 1
                        • EkopalypseE Offline
                          Ekopalypse @Neko Nekokovic
                          @Neko-Nekokovic
                          I have not read the whole thread but from what I understand you
                          have Npp installed and so I assume your configuration directory
                          is the one in APPDATA, could that be?
                          If not, can you paste your debug information, which is available
                          from the last menu item (the ? menu)?
                            PeterJones @Neko Nekokovic
                            I know this is going back to the beginning, but I’ve been away for a few days.
                            @Neko-Nekokovic originally said,
                            lso is it possible that I can edit Margin values inside of Distraction Free mode? Currently the default is quite a bit “wider” than my 80 characters centered.
                            yes. That’s why there’s a setting for it.
                            On my current monitor, which could handle about 230 characters wide in true full-screen mode (View > Toggle Full Screen): if Settings > Preferences > Margins/Border/Edge > Padding > Distraction Free is at 9 (the widest), I get about 170 characters wide in Distraction Free mode, and at 3 (the narrowest), I get about 70 characters wide; and at the default 4, I get about 110 characters wide.
                            If that’s not enough range for you, then you will have to go through the PythonScript rigamarole, as has already been described to you.
                            As has been described, though I’ll phrase it differently:
                            C:\Program Files\Notepad++\plugins\PythonScript\scripts is for “machine scripts”. For a standard installation, user scripts will go in the %AppData% config directory, which is technically %AppData%\Notepad++\plugins\config\PythonScript\scripts (which you can paste directly into Windows Explorer or the File > Save As dialog) – this will probably resolve to something like C:\users\<your user name here>\AppData\Roaming\Notepad++\plugins\config\PythonScript\scripts, but the infinite number of Windows conifgurations possible means this is not guaranteed – whereas just pasting in the %AppData%-based path will work on any Windows installation I’ve used in the last couple decades. And, as @Ekopalypse said, if you are having trouble finding the user-scripts directory, using the ?-menu’s Debug Info, and copying that debug info and pasting into your reply, will tell us where your user-script location will be.
                            Neko NekokovicN 1 Reply Last reply Reply Quote 2
                              And where are you employed?
                              Oh come on man, that’s circular.
                              “Why is it banned? Because people should not use it.
                              Why should people not use it? Because it’s banned.
                              Why would you want to keep someone from using imgBB or Imgur?
                              It’s really not the problem to paste a picture instead of posting a hyperlink. Sure if that’s “the standard” on this forum I’ll do it. Not a big deal anyway.
                              But I’m curious about the reasons imgBB or imgur are advised not to be used. This is the first time I ever heard of that and I’d like to know the reasoning behind it.
                                Neko Nekokovic @Ekopalypse
                                @Ekopalypse Hi, first thanks for the comment.
                                I understand you have Npp installed and so I assume your configuration directory is the one in APPDATA, could that be?
                                No I don’t have a Configuration directory in %Appdata%/Notepad++ (neither in the parent directory, that is only %Appdata%)
                                If not, can you paste your debug information, which is available from the last menu item (the ? menu)?
                                I sure can. Here it is:
                                Notepad++ v8.4.4   (64-bit)
                                Build time : Jul 15 2022 - 17:54:42
                                Command Line : "C:\Users\krete\Desktop\Alat\Filozof\New Text Document.txt"
                                OS Version : 21H2
                                OS Build : 19044.2006
                                (Don’t know why there is such a big gap below the picture. I’ve tried to Edit, but I cannot make it shorter for some reason. Sorry)
                                  Neko Nekokovic @PeterJones
                                  @PeterJones Thanks for the comment.
                                  No, it’s fine, I’m happy people are eager to help. I appreciate that.
                                  Settings > Preferences > Margins/Border/Edge >Padding > Distraction Free is at 9 (the widest)
                                  I have tried every number from 3 to 9. Every number from 4 onwards is way too wide, while 3 was way to narrow. It’s 63 characters wide.
                                  Aah %Appdata%/Notepad++/plugins/PythonScript/scripts
                                  I was looking for a config directory into %Appdata% itself.
                                  Anyway, the folder %Appdata%/Notepad++/plugins/PythonScript/scripts is empty.
                                  And here is my Debug Info:
                                  OS Version : 21H2
                                  Plugins :
                                      mimeTools (2.8)
                                      NppConverter (4.4)
                                      PythonScript (2)
                                  Thanks for your comment.
                                    Irrelevant. My employer blocks imgBB as well.
                                    Alan didn’t say he wanted to. Alan said his employer blocked the site. And “why” a particular corporation’s IT department blocks something is rather irrelevant to the conversation. The fact is, they do – and many do. (My guess is that image-only sites are blocked because they aren’t often relevant to an employee’s job, and they often contain NSFW pictures, which one shouldn’t be perusing on the company’s dime. I’ve always been surprised that mine allows imgur, to be honest.)
                                    That’s because %AppData%\notepad++ is the configuration directory; there isn’t one called “configuration” in there.
                                    Okay. That is, of course, a personal preference. (i don’t see a significant difference between 3 and 4, so it’s strange that one is way too wide and the other way too narrow. But to each their own.)
                                    That’s not what I said: %AppData%\Notepad++\plugins\config\PythonScript\scripts
                                    But if it’s empty, that just means you don’t have any user scripts yet. That’s where user scripts go, whether or not you currently have any. Once you put one in there, then you will have a user script.
                                    Good luck
                                      NSFW part makes sense but it’s still a bit strange to me. I hope someone will explain it to me since this is the very first time I’ve heard about such a practice.
                                      Ah, okay. Thanks.
                                      Yeah it is strange indeed. 3 is 63 characters wide, while 4 is 97. Maybe that has to do with my weird resolution. That’s why I’m asking for a manual configuration of margin width, I guess I have to try it out manually and see how it appears.
                                      You’re correct, I misstyped. I omitted the “config” directory. Anyway that directory is empty.
                                      I will try to put Python user Script there and hope it will work.
                                      Thanks.
