    Notepad++ 8.4 Release - Keep standing up for Ukraine
    25 Posts 10 Posters 18.3k Views 5 Watching
    • donhoD Offline
      donho
      Notepad++ v8.4 Release is available:
      https://notepad-plus-plus.org/news/v84-stand-up-for-ukraine/
      The current external lexer plugins need a little bit more coding effort to work with Notepad++ v8.4 (due to new architecture of Scintilla 5), here’s some information which may help:
      https://community.notepad-plus-plus.org/topic/22866/make-external-lexer-plugin-work-with-v8-4
      1. Update Scintilla from v4.4.6 to v5.2.1 and add Lexilla v5.1.5. (Fix #10504)
      2. Enhance dark mode support (Shortcut Mapper, autocompletion, calltip, Column Editor and Style configurator, Preferences dialog, etc…) (Fix #11530, #11522, #11407, #11514, #11506, #11497)
      3. Fix lossing characters issue after case-conversion (UPPER/lower). (Fix #11463)
      4. Fix “Sort Lines as Integer” not considering negative number issue. (Fix #11023, #2025)
      5. Sort languages alphabetically automatically in Style Configurator. (Fix #11337)
      6. Fix flashing box (autocompletion empty list) appears while typing issue. (Fix #9433)
      7. Scrolling Document List automatically to make the selected tab item visible. (Fix #11204)
      8. Make Find in Files search result line number aligned. (Fix #11119)
      9. Add default A-Z sorting ability in Function list. (Fix #11446)
      10. Add virtual space ability. (Fix #11443, #11444)
      11. Fix document being wronly marked as saved bug after converting its encoding. (Fix #11436)
      12. Fix Document list not sync with tab order after sorting. (Fix #11272)
      13. Fix file saving critical bug under Symantec encryption desktop. (Fix #11339)
      14. Fix cropped text in Shortcut mapper’s status area issue. (Fix #10358)
      15. Enhance installer: Remember the chosen language in the previous installation. (Implement #10582)
      16. Improve Find/Replace Dialog layout. (Fix #11318)
      17. Update NSIS & Inno Setup keyword lists.
      Find some regressions or critical bugs? Post them here please.
      PeterJonesP 1 Reply Last reply Reply Quote 8
      • PeterJonesP Online
        PeterJones @donho
        @donho ,
        I’ve started using this as my primary, and so far nothing has jumped out as being a problem for me.
        Thanks for all the effort from you and the other contributors!
        • Laszlo BotkaL Offline
          Laszlo Botka
          My default style - selected text background color is set to light blue.
          When the tab isn’t in focus, for example in case of Ctrl F dialog, settings popups, multiple documents opened,
          the selected text background color changes to quite dark grey.
          No such color change in previous versions.
          Is this a bug, or there is a setting for this case.
          Notepad++ v8.4 (32-bit)
          Build time : Apr 20 2022 - 03:27:27
          Command Line :
          OS Version : 2009
          OS Build : 19044.1682
          Current ANSI codepage : 1250
          Plugins : AutoCodepage.dll combine.dll ComparePlugin.dll DSpellCheck.dll GotoLineCol.dll LocationNavigate.dll LuaScript.dll mimeTools.dll NppBookmarkManager.dll NppCalc.dll NppConverter.dll NppExport.dll NPPJSONViewer.dll NppSaveAsAdmin.dll NppTextFX.dll PluginManager.dll
          Path : D:\Soft\Notepad++P\notepad++.exe
          Command Line : -multiInst D:\trklist.m3u
          Local Conf mode : ON
          OS Version : 2009
          Plugins : AutoCodepage.dll Combine.dll ComparePlugin.dll DSpellCheck.dll GotoLineCol.dll HexEditor.dll LocationNavigate.dll mimeTools.dll NppBookmarkManager.dll NppCalc.dll NppConverter.dll NppExport.dll NppSaveAsAdmin.dll PluginManager.dll
          The same happens when plugins are disabled on startup
          Command Line : -noPlugin D:\Xnap\DOWNLOAD\aaaa
          OS Version : 2009
          Plugins : none
          • Michael VincentM Online
            Michael Vincent @Laszlo Botka
            @laszlo-botka said in Notepad++ 8.4 Release - Keep standing up for Ukraine:
            It is not a bug, but there is not yet a setting. It’s new from the Scintilla 5 upgrade. See SC_ELEMENT_SELECTION_INACTIVE_BACK.
            Laszlo BotkaL 1 Reply Last reply Reply Quote 4
            • pnedevP Offline
              pnedev
              @donho ,
              Thanks for the effort and for the new version, much appreciated.
              I recently added N++ version check in my plugins and noticed that there is an issue with NPPM_GETNPPVERSION message.
              In Notepad++ v8.3.3 LOWORD(version) gives 33 which is OK but
              in Notepad++ v8.4 LOWORD(version) gives 4 which should be 40 in my understanding.
              Tell me if I should file an issue for that or you will fix it “on the fly”, thanks.
              • pnedevP Offline
                pnedev
                @donho ,
                I see that there is already an issue for that: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/11535.
                Sorry for writing about it here again, it is of course not connected with N++ 8.4 itself.
                donhoD 1 Reply Last reply Reply Quote 3
                  Laszlo Botka @Michael Vincent
                  @michael-vincent
                  What is the next step? Will someone fix it?
                  Michael VincentM donhoD 2 Replies Last reply Reply Quote 0
                    If you think it is a bug, you can create an issue. You could also use a scripting plugin like NppExec or PythonScript to adjust it.
                    • donhoD Offline
                      donho @pnedev
                      @pnedev said in Notepad++ 8.4 Release - Keep standing up for Ukraine:
                      @donho ,
                      Here is my reply:
                      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/11535#issuecomment-1111152543
                      • donhoD Offline
                        donho @Laszlo Botka
                        Please create an issue here:
                        I will see what I can do about it.
                        Laszlo BotkaL 1 Reply Last reply Reply Quote 1
                          Laszlo Botka @donho
                          @donho said in Notepad++ 8.4 Release - Keep standing up for Ukraine:
                          Maybe I don’t understand you, or I did it wrong, but I already created this issue:
                          https://github.com/notepad-plus-plus/notepad-plus-plus/issues/11595
                          • donhoD Offline
                            donho @Laszlo Botka
                            @laszlo-botka
                            Fixed in the master:
                            https://github.com/notepad-plus-plus/notepad-plus-plus/commit/3b0d5242acd23b4a727560ea98139cc5f4a8b88a
                            The fix will be in the next release.
                              Laszlo Botka @donho
                              Thanks. How will it work?
                              • rdipardoR Offline
                                rdipardo
                                Has anyone else noticed that reloading a file with CTRL+R makes the code style and/or fold levels disappear until you refocus the tab?
                                This regression was initially blamed on the NppFTP plugin
                                until I reproduced it myself: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/11585#issuecomment-1111979650
                                  It appears to just keep the same background color of selection with the window in or out of focus. Thanks @donho !
                                    @michael-vincent said in Notepad++ 8.4 Release - Keep standing up for Ukraine:
                                    Thank you!
                                    • Argyle TreesA Offline
                                      Argyle Trees
                                      The user defined syntax colors disappear after reloading the program by pressing Ctrl-R.
                                      I have to click on the language again to make the syntax color active again.
                                      • rdipardoR Offline
                                        rdipardo @Argyle Trees
                                        @argyle-trees,
                                        That will be fixed in the next release: https://github.com/notepad-plus-plus/notepad-plus-plus/commit/9cc01de97c8d2a617c7ada7aba6854a9f7e1426b
                                        • I am connectedI Offline
                                          I am connected
                                          Updated to Notepad++ 8.4 and still cannot save a XML file with ~46000 words - Notepad++ is not responding. When I copy all code and paste it in a new file I can save it. Using Symantec Encryption Desktop on my pc.
                                          @Bugfix 13
                                          • rdipardoR Offline
                                            rdipardo @I am connected
                                            @i-am-connected,
                                            The XML Tools plugin is probably the cause: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/11603#issuecomment-1111879226
