    Python plugin works in NPP 7.7 but does work in NPP 7.8 upward
    24 Posts 2 Posters 1.9k Views
    • Stier HahnS
      Stier Hahn @Ekopalypse
      @Ekopalypse will check tmr in more details.
      I can tell for sure (99%) I do not have any 64 bit builds of python on my box.
      Ps
      I’m still wondering that it works for me in 7.7 but not in 7.8. Just for my understanding were there any changes that could cause such behavior? Changes in dll lookup order or something
        Starting from 7.8 plugins are allowed to load their own dlls from within the plugin directory.
          Ah - could it be that path is not evaluted anymore? I guess so.
          Stier HahnS 1 Reply Last reply Reply Quote 1
          • Stier HahnS
            @Ekopalypse could you please check if it works for you if python dll is located in path and not in plugin dir
            EkopalypseE 2 Replies Last reply Reply Quote 0
              Ekopalypse @Stier Hahn
              @Stier-Hahn - currently trying
                Ekopalypse @Ekopalypse
                @Stier-Hahn
                Yes, it is not found but then I do get
                  and next window is
                    but npp 7.7 works.
                      @Stier-Hahn
                      I start to remember that I read some conversation about
                      security concerns regarding sideloading dlls.
                      • Stier HahnS
                        @Ekopalypse so, I’ve tested my minimal plugin build in 7.8 with python37.dll inside plugin dir and it works.
                        My question from the top of the thread has been solved.
                        Thank you very much!
                        ps
                        I still need to check if my main plugin will be working…
                        Struggling to upgrade third-party libs and other dependencies…
                          If there is anything we can do to help let us know.
                          Stier HahnS 1 Reply Last reply Reply Quote 0
                          • Stier HahnS
                            @Ekopalypse you are doing great job , thank you !
                            ps
                            I came across a next roadblock , that’s more a pywin32 issue.
                            See https://github.com/mhammond/pywin32/issues/1658
                            May be you would have a hint how to troubleshoot that. as that seems to be sort of related to dependency lookup process.
                            In a nutshell I’ve NPP plugin linked against boost::python which loads at startup some initialization python code. And it’s was working fine under py 3.7 and npp 7.7.
                            Finally ( with your help) I managed to upgrade npp from 7.7 to 7.9
                            and partially from winpython 3.7 to winpython 3.8.
                            My NPP python plugin is loaded at startup, but execution of initialsation python scripts fails to import win32api.
                            Embedded python wrapper is working fine ( I guess ) as import os / import sys and other simple code is working inside my plugin.
                            I’m using win py 3.8 and latest pywin32 ( 300)
                            • Stier HahnS
                              Stier Hahn @Stier Hahn
                              @Stier-Hahn pywin32 is installed sort of correctly as it works from python command line.
                                @Stier-Hahn
                                there is an additional
                                ...\AppData\Roaming\Python\Python38\site-packages
                                path when used by the command line.
                                Maybe give it a try to add it to your sys.path from embedded python.
                                Do you know procmon?
                                It could be used to see what npp and your plugin tries to load with a filter set to path contains whatever
                                If importing pywin32 failed with unable to load dll
                                then one of those
                                can not be found I guess.
                                python38 shouldn’t be the problem but pywintypes38.dll might be in this additional path I’ve mentioned earlier??
                                Stier HahnS 1 Reply Last reply Reply Quote 2
                                • Stier HahnS
                                  @Ekopalypse cool, thanks for advice, turned out to be pywin32_system32 not being searched for some reason
                                  Apparently lookup path was (intentionally screwed up) modified
                                  I managed to fix my problem by placing pywintypes38.dll and pythoncom38.dll to NPP root
