    [v.7.8.6] Vertical Edge Settings no longer works with Split Lines (Ctrl-I)
    30 Posts 8 Posters 7.2k Views
    • Matthew AuM
      Matthew Au
      I use Vertical Edge Setting to set the col width to be 80. Then using Ctrl-I I can split long lines. This is a very useful feature.
      But this feature is broken in v.7.8.6.
      Was it a feature drop or bug?
      Michael VincentM dinkumoilD 2 Replies Last reply Reply Quote 0
        Michael Vincent @Matthew Au
        @Matthew-Au
        I believe it is an unintended consequence of the feature add of multiedge support : Preferences => Editing => Vertical Edge Settings.
        Vertical edge is now implemented always as SCI_MULTIEDGEADDLINE(), not as SCI_SETEDGEMODE() / SCI_SETEDGECOLUMN() as previously done. I understood that putting only 1 value in the text box should do the latter, but I have only 80 in that box (for a single vertical edge at column 80) and after N++ is launched, I use NppExec to query the edge mode and get back:
        SCI_SENDMSG SCI_GETEDGEMODE
        ================ READY ================
        ECHO $(MSG_RESULT)
        3
        Which you can see is Multiedge mode.
        I believe this is a “regression” bug where a new feature broke an existing operation. If I manually set to line mode at column 80:
        SCI_SENDMSG SCI_SETEDGEMODE EDGE_LINE
        SCI_SENDMSG SCI_SETEDGECOLUMN 80
        Edit => Line Operations => Split Lines
        now works for me with long lines over 80 columns.
        • Matthew AuM
          Matthew Au
          Thanks for reply. Can this issue be workaround via GUI? And shall I raise this as an issue in N++ Github?
          EkopalypseE Alan KilbornA Michael VincentM 3 Replies Last reply Reply Quote 1
            Ekopalypse @Matthew Au
            @Matthew-Au said in [v.7.8.6] Vertical Edge Settings no longer works with Split Lines (Ctrl-I):
            It seems choosing background mode is working, more or less, like you want.
            If this would be set to EDGE_LINE I assume it would cover previous and current feature set.
              Alan Kilborn @Matthew Au
              I would say YES to this.
                Yes please. And reference / link this discussion please.
                I didn’t notice this because I use NppExec to run a startup script (as soon as N++ launches) and among other things, it force sets Edge Line mode and column 80. I added it after this new release that changed the way vertical edge was done. I hadn’t noticed your issue since I was always forcing Edge Line mode.
                • Matthew AuM
                  Matthew Au
                  @Ekopalypse Thanks, the “background mode” does the job (for now).
                  @Alan-Kilborn I’ve submitted a bug report here.
                    Hello, @matthew-au, @michael-Vincent, @ekopalypse and All,
                    I fully understand the problem ! In order to get the Split Lines feature to work, here is my work-around :
                    • Open the Settings > Preferences... > Editing > Vertical Edge Settings option
                    • If the window contains several column numbers, delete all these numbers
                    • Now, type in an unique column number where you want the lines to be splitted
                    • Tick the Background mode option ( IMPORTANT )
                    • If preferred, you can untick this option, immediately !
                    • Now the Ctrl + I feature should be fucntional, as soon as a selection have been made, whatever the Background or Line mode is chosen ;-))
                    • If you want, you may rewrite all your previous column numbers
                    • But, beware that any subsequent Ctrl + I operation will refer to the unique number noticed while ticking the Background mode option !!
                    Here is my debug info :
                    Notepad++ v7.8.6   (32-bit)
                    Build time : Apr 18 2020 - 22:32:17
                    Path : D:\@@\786\notepad++.exe
                    Local Conf mode : ON
                    OS Name : Microsoft Windows XP (32-bit)
                    OS Build : 2600.0
                    Plugins : Explorer.dll mimeTools.dll NppConverter.dll NppExport.dll
                    Best Regards
                    Alan KilbornA EkopalypseE 2 Replies Last reply Reply Quote 2
                      Alan Kilborn @guy038
                      @guy038 said in [v.7.8.6] Vertical Edge Settings no longer works with Split Lines (Ctrl-I):
                      Hidden feature!! :-)
                        Ekopalypse @guy038
                        @guy038 but works only as long as you don’t restart npp, correct?
                          Hi, @matthew-au, @michael-Vincent, @ekopalypse, @alan-kilborn and All,
                          @ekopalypse, Ah yes ! As soon as I restarted Notepad++, it simply showed the two edge lines that I had previously set ( 30 and 60 )
                          However, remember that, by default, if no vertical setting or several vertical settings are set, then the CTRL + I feature splits lines, roughly, to the windows text width !
                            Hello, @matthew-au, @michael-Vincent, @ekopalypse, @alan-kilborn and All,
                            The last N++ v7.8.6 version now supports the new Vertical Multi-Edge lines feature. Unfortunately, as a consequence, this definitively breaks the native Split Lines feature ( Ctrl + I )
                            A work-around has been found but needs to choose one column number only and tick once on the Background mode option ! But this prevent you from easily using multiple vertical lines, which is a pity :-(
                            So, I imagined a regex S/R, that exactly simulates the N++ Split Lines feature ;-))
                            Just one constraint : If your text contains some tabulation chars, you must run, first, the Edit > BLank Operations > TAB to Space option, in order to change any tab character with the appropriate number of space chars. Indeed, the regex S/R assumes that each character displayed takes the place of exactly one character. !
                            The generic regex S/R, for any splitting column C is :
                            SEARCH (?-s)^(?=.{C})(.{1,C-3}\x20|.{C-1})\K
                            REPLACE \r\n    ( or \n if Unix files )
                            So, let’s suppose that you want to split text, at column C = 80. In that case, the regex S/R must be changed as below :
                            • SEARCH (?-s)^(?=.{80})(.{1,77}\x20|.{79})\K
                            • REPLACE \r\n    ( or \n if Unix files )
                            • Tick the Wrap around option
                            • CLick on Replace All button, exclusively ( Do not use the Replace button ! )
                            After numerous tests, I verified that the split texts are strictly identical :
                            • Whatever the Split Lines option ( Ctrl + I ) or the Regex S/R is used
                            • Whatever the In selection option is set or not, in the Replace dialog
                            • Whatever the Line or Background mode is used, in Settings > Preferences... > Editing > Vertical Edge Settings
                            • Whatever the View > Word wrap option is set or not
                            • Whatever the View > Show Symbol > Show All Characters option is set or not
                            • Whatever the current font used is a MonoSpace or a Proportional font, in the Style Configurator...
                            In case of a proportional font, do not trust the visual vertical edge line, but rely on the real column, indicated in Settings > Preferences... > Editing > Vertical Edge Settings ! BTW, the Line mode is generally recommended for monospace fonts and the Background mode should be preferred for proportional fonts !
                            As a test, we’ll simply use the License.txt file and split its contents at column 80 :
                            • First of all, make sure that the single number 80 is shown in Settings > Preferences... > Editing > Vertical Edge Settings
                            • Copy the License.txt file in two new tabs ( new 1 and new 2 )
                            • In the new 1 file :
                              • Ctrl + A
                              • Ctrl + I ( Split Lines option )
                            • In the new 2 file :
                                • Click on Replace All button, exclusively ( Do not use the Replace button ! )
                            • Now, compare the two tabs with, for instance, the Compare plugin or with an external compare tool => The two tabs should be strictly identical ;-))
                            Remark : Of course, this regex S/R supposed that the splitting vertical line was at position 80. So, adapt the generic regex, above, according to the real column needed !
                              Seems to be relevant to this current discussion: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/7814
                                @guy038
                                Any reason for the capturing group usage?:
                                  Hi, @alan-kilborn and All,
                                  You’re perfectly right about it : No need of a capturing group for that purpose ! So, the generic search regex can be changed as below :
                                  SEARCH (?-s)^(?=.{C})(?:.{1,C-3}\x20|.{C-1})\K
                                  And the corresponding search regex for C = 80 is :
                                  SEARCH (?-s)^(?=.{80})(?:.{1,77}\x20|.{79})\K
                                  Indeed, although the maximum of characters, caught in group 1, not exceeds, either, C-2 or C-1 chars, the fact of using a non-capturing group should speed up the replacement process, in case of huge files !
                                  • Patrick SheppardP
                                    Patrick Sheppard
                                    Not sure this is worth a new thread … I used the following NppExec / Scintilla script to set the vertical edge column to the current column (super useful in my usage). It is now broken. Any recommendations for how to fix is appreciated. I did try what I thought was the obvious update and it didn’t work…
                                    ::NPXEdgeColumSetToCurrent
                                    NPP_CONSOLE ?
                                    SCI_SENDMSG SCI_SETEDGECOLUMN $(CURRENT_COLUMN)
                                      Michael Vincent @Patrick Sheppard
                                      @Patrick-Sheppard said in [v.7.8.6] Vertical Edge Settings no longer works with Split Lines (Ctrl-I):
                                      It is now broken
                                      What version of Notepad++ - please post your debug info (menu ? => Debug Info…). I’ll assume you’re using the new 7.8.6 version as that is an easy fix. As of N++ 7.8.6, the vertical edge mode changed to multiedge by default so you can add multiple edges. You can try:
                                      ECHO $(MSG_RESULT)
                                      1
                                      to verify. I’m assuming you’ll get back “3” as in EDGE_MULTILINE. You can modify your script to be:
                                      NPP_CONSOLE ?
                                      • Patrick SheppardP
                                        Patrick Sheppard
                                        Thanks, Michael.
                                        I had downgraded to 7.8.5 because of this issue and was reluctant to jump back up, but I just did and your modification works a charm.
                                        Appreciated.
                                          Hello, @matthew-au, @i-neuw, @michael-Vincent, @ekopalypse, @alan-kilborn, @peterjones, @terry-r and All,
                                          I revisited my previous posts of that discussion about the new Vertical Multi-Edge lines feature !
                                          I want to insist that the fact of ticking on the Background mode option, then unticking it, is needed to update the sole edge boundary value, displayed ! Even with the last 7.9.0 N++ version, this step is necessary !
                                          Now, I did some additional tests, on, both, the final version of my regex and the native Split Lines N++ feature ( Ctrl + I ), using the license.txt file !
                                          • Using my regex S/R method, to split the lines, we get the same result :
                                            • Whatever the current font used is a MonoSpaced or a Proportional font, in the Style Configurator...
                                          provided that you previously ran the Edit > BLank Operations > TAB to Space option if your file contains some TAB characters !
                                          • Using the native Edit > Line Operations > Split Lines feature, we get the same result
                                          But, unlike what I said in my first post, the results of the Ctrl + I feature are totally different depending on whether :
                                          • The View > Show Symbol > Show All Characters option is set or not
                                          • The current font used is a Monospaced or a Proportional font, in the Style Configurator...
                                          So, regarding my previous argumentation, my regex method and the native Split Lines N++ feature give the same results ONLY IF :
                                          • A monospaced font is currently used
                                          • The EOL symbol ( CRLF ) is not displayed
                                          • The column number is superior to a minimum of about 15 for normal text. When I say “normal”, I refer, for instance, to the license.txt text, from line 28 GNU GENERAL PUBLIC LICENSE Version 2, June 1991 till the end of file !
                                          Note also that, with these hypotheses, the splitting operation of a selection of lines with, both, the regex S/R and the native Split Lines feature gives the same text contents !
                                          IMPORTANT : My regex S/R is built in order to exactly replace the native Split Lines N++ feature, with the hypotheses above. But, of course, you may decide to not follow this rule and use, instead, a more simple search regex as, for instance :
                                          SEARCH (?-s)^.{75,}?\K\x20+
                                          REPLACE \r\n
                                          which would split lines, roughly, after 80 characters
                                          • Michael AldenM
                                            Michael Alden
                                            Posting this in case it’s useful to anyone else. I worked around this issue using this plugin: dail8859/LuaScript: Notepad++ plugin for Lua scripting capabilities. Specifically, I added this code to my Lua startup script.
                                            -- Lua function for Scintilla colors
                                            local function RGB(red, green, blue)
                                                return red | green << 8 | blue << 16
                                            end
                                            -- Teal color value same as default used in Notepad++
                                            local COLOR_TEAL = RGB(128, 255, 255)
                                            -- Set line mode to EDGE_Line at 80 characters with teal color
                                            npp.SendEditor(SCI_SETEDGEMODE, EDGE_LINE)
                                            npp.SendEditor(SCI_SETEDGECOLUMN, 80)
                                            npp.SendEditor(SCI_SETEDGECOLOUR, COLOR_TEAL)
                                            So, every time Notepad++ starts it resets the column marker. This has the same affect as if one were to toggle the “Background mode” setting.
